Panasonic CF53 MK4 CF-532S74RMG
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1253
    • France
    #41
    Re: Panasonic CF53 MK4 CF-532S74RMG
    Originally posted by imranromi
    Try my file will see what happen.
    Originally posted by LenBios
    with your File no Panasonic Logo on Boot + same problem after defaults settings asking for password
    at the end of the string there is 01. Do not change it to 00. Otherwise Panasonic logo at boot will go away.
    https://mhhauto.com/Thread-Toughbook...804#pid1647804
      • 21446
      Originally posted by Maxpower3
      you have cleaned well
      but there are still 2 occurrences
      0xA80328 :
      0xADAD8E :
      I forgot to zero fill the first one at 0xA80328 .I used the bios from post #16 ,copied the DMI and GBE region and cleaned the ME FW .I don`t think the other occurrence at 0xADAD8E would make any difference after setting bios defaults .
      • LenBios
        • 122
        • Ker
        #43
        If the SMD FLEA file doesn't work
        try those
        thank you very much
        first file is working well
        from winzip the first one not working, the second one is working but has the SN like #16
        • LenBios
          • 122
          • Ker
          #44
          Originally posted by SMDFlea
          Try this one .
          thank you but not working
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1253
            • France
            #45
            thank you very much
            use winrar for my file
            first dump is original
            for second dump
            as SMDflea indicates, just remove a 0xA80328 for "smdflea file" or 0xA802EE for your original + AMITSEtup, it should work normally
            • LenBios
              • 122
              • Ker
              #46
              winrar file is working well
              Winzip File= first file not working, second file is working but SN is like the post #16
                • 21446
                thank you very much
                Try this one,it should be ok,with the SN ,key and mac address .
                • LenBios
                  • 122
                  • Ker
                  #48
                  working but SN is like #16
                  • LenBios
                    • 122
                    • Ker
                    #49
                    this one is working with orig
                    @Maxpower what did you change in this file from the original?
                    Can you please send pictures which line have to fill zero etc?
                    Thank you
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1253
                      • France
                      #50
                      Thank you
                      I removed all keys written in the dump 5B ..... AA 44 05 D8 60 6B
                      can be written a hundred times with 00
                      • LenBios
                        • 122
                        • Ker
                        #51
                        for second dump
                        which lines are AMITSEtup?
                        Thank you very much
                          • 21446
                          The DMI was copied from the bios at post #26 !!!
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1253
                            • France
                            #53
                            Thank you very much
                            0xAB3B12 and 0xAF3B14
                            do an AMITSESetup text search with hxd
                            Thank you
                            Just compare your file with hxd program , look around now, i've done all the work for you already
                            • LenBios
                              • 122
                              • Ker
                              #54
                              the SN in #26 is 5KTCA36745
                              in the post#16 is: 5JTCA30882
                              • LenBios
                                • 122
                                • Ker
                                #55
                                thank you very very much for your help.
                                if in the future i have same panasonic model can be done in this way?
                                Thank you
                                • LenBios
                                  • 122
                                  • Ker
                                  #56
                                  Thank you for all your help
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1253
                                    • France
                                    #57
                                    look
                                    • LenBios
                                      • 122
                                      • Ker
                                      #58
                                      look
                                      yes correct
                                      can i change the SN with Hex editor?
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1253
                                        • France
                                        #59
                                        yes but written many times in several ways and I don't know if any checksum to verify.
                                        My original patched file is working fine?
                                        So better to start from an original file and modify it my way if you have other pc to do. You keep the original file like that
                                        • LenBios
                                          • 122
                                          • Ker
                                          #60
                                          yes your file is working very good
                                          • AquaMan Ua
                                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                                            by AquaMan Ua
                                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                            05-17-2025, 09:40 AM
                                          • aa10aa10
                                            Panasonic Toughbook CF-33 mk1 BIOS repair
                                            by aa10aa10
                                            Good day,
                                            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                            01-21-2025, 06:13 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • James Jackson
                                            Panasonic CF-20G0247VM BIOS Bad Flash Help
                                            by James Jackson
                                            I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
                                            Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
                                            05-01-2025, 11:28 AM
