Panasonic CF53 MK4 CF-532S74RMG
Every donation made will go towards server fees and maintenance costs. -
Re: Panasonic CF53 MK4 CF-532S74RMG
i have a toughbook CF-53 mk4
Windows is booting from an USB-Stick, but it is bios locked
Serial: - CF-532nxbymg
Aptio 4 Ami delivers me a 6 MB file
can someone unlock it?
I try to upload it with Aptio4Ami, is that working?
or what is the solution without opening the laptop-case
byeAttached Filesif you find these attachements useful please consider making a small donation to the site
Try the Attachment and report.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello Guys, could you help me please? I have a CF-53 MK4 with an pw.Attached Filesif you find these attachements useful please consider making a small donation to the site
Try the attached file...Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi guys I have a Bios locked Panasonic CF-53 MK4
Model:CF-532SLZACM
S/N: 6CTSA56886
Need Mac Adress to match pleas and ME Firmware to match
If you guys can make it boot with the "Panasonic" logo that would be great too thank you!Attached Filesif you find these attachements useful please consider making a small donation to the site
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
cf-532s74rmg
s/n:5ktca37214Attached Filesif you find these attachements useful please consider making a small donation to the site
try it with a 64 bit windows OS, w10 (64 bits), it solved mine problems working on a cf-19 mk4. Use CH341A Mini Programmer V1.29 with the 64 bit drivers. And be sure the clam on the chip is fitting WELL.Comment
HI Team,
Please help me unlock the panasonic cf-52 i5 vpro
below is the details of the laptop
Model no: CF-52VACBYDE
Serial no: 4LTCA86903
Thanks in advance.Attached Filesif you find these attachements useful please consider making a small donation to the site
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
Channel: BIOS Requests ONLY!
by aa10aa10Good day,
I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....-
by macabookHello everyone,
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
- Loading...
