Panasonic CF53 MK4 CF-532S74RMG
    • 20763
    Re: Panasonic CF53 MK4 CF-532S74RMG
    Originally posted by Maxpower3
    yes but written many times in several ways and I don't know if any checksum to verify.
    My original patched file is working fine?
    So better to start from an original file and modify it my way if you have other pc to do. You keep the original file like that
    The serial is stored in the ME region in one of the partitions.
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1224
      • France
      #62
      yes but search and look just with text 5KTCA or 5JTCA
      there are lots of little bits of serial everywhere
      the last digits are coded on 16bits little-endian to ascii
      look at the number of times found serial on my picture
      • noumenon
        • Aug 2021
        • 12
        • germany
        #63
        hello,
        one question: is it possible to flash the bios with AFUWIN or any other tool without external programer? Or if not, is there any tutorial? I have the skills for bonding and using MC's but here I'am newbee
        My problem: I have a CF-532S74RMG with bios inside where the WLAN and WWAN function isn't enabled and no option inside the bios to change that.
        Maybe you know where I can enable this funktion in the hex-dump?
        with kind regards
        Mike
        • noumenon
          • Aug 2021
          • 12
          • germany
          #64
          hello,
          I read and learned a lot here. Many Thanks for that!
          Now I'am at the point, that the book is working fine, wireless switch is activated and WWAN detected. WLAN I will change soon, I think it is defect.
          I flash with CH341a and clip without any soldering an other bios from here, what in description was free of PW, BUT:
          ----- just 4 info -----------
          I had an PW in the old bios set and I think that was reading out from somewhere in the book, so If I try to enter the BIOS I was not able to go in, because the "data" in bios was clear and the "data" from somewhere not, both missmatch...
          I read out my backup from original bios and set the same values inside the new bios and that it works..easy for you but for me something learnd
          Now I enable all menu with the "magic string" and have working book..so far so good, BUT:
          Question: is it possible to enable ME? I have only "n/a" as info in BIOS and no skills to understand for what is ME usefull, is it problem to work without?
          with kind regards
          Mike
          • noumenon
            • Aug 2021
            • 12
            • germany
            #65
            Now I try new WLAN Card and still no option/function/Finding
            Is it maybe problem with the base (532S74RMG) or the option "2.LAN" that WLAn is not possible?
            best regards Mike
              • 20763
              best regards Mike
              Post your original backup, the one before you made any changes to it .
              • noumenon
                • Aug 2021
                • 12
                • germany
                #67
                The last file I used is now here. ME is working, WWAN is working, still no WLAN but I buy two other Types and will test next time...
                with kind regards
                Mike
                • noumenon
                  • Aug 2021
                  • 12
                  • germany
                  #68
                  hello,
                  I'am back from holiday. I tested 6235, 7260 and 7265Intel unbranded cards and nothing is regonized, still no WLAN
                  Any hints?
                  With kind regards
                  Mike
                    • 20763
                    hello,
                    Any hints?
                    With kind regards
                    Mike
                    i assume you`ve turned the wireless switch on
                    • noumenon
                      • Aug 2021
                      • 12
                      • germany
                      #70
                      hello,
                      yes, the mechanical switch at side of book is on and also the LED is working. With switch I can enable WWAN on/off or like it called "flightmode on/off". So it seems to be ok.
                      Still the WLAn card's will not regonize in any way, not bios, not windows. In BIOS I have menu for WWAN (enable/disable) but nothing for WLAN, thats curiouse
                      with kind regards
                      Mike
                        • 20763
                        hello,
                        with kind regards
                        Mike
                        Are you sure youve got the exact same model as in the thread title. Do you have a copy of the Original backup .
                        • noumenon
                          • Aug 2021
                          • 12
                          • germany
                          #72
                          hello,
                          at the book are label: CF-532S74RMG with serial: 5JTCA29901
                          as I buy it there was in BIOS (V4.00L18 M91 the Serial: 5KTCA37037
                          so I think there was some mod before me and the WWAN and WLAN does not work. Wireless switch was disabled and not working (also LED still off).
                          I search a lot of ROM here and test...a lot of them enables the wireless switch but only WWAN comes on
                          here the original backup ROM from book at first day (with PW and wireless switch disabled!).
                          with kind regards
                          Mike
                          • noumenon
                            • Aug 2021
                            • 12
                            • germany
                            #73
                            hello,
                            do you have any hints? Maybe a BIOS Rom for this book with guarantee WLAN option in BIOS?
                            with kind regards
                            Mike
                              • 20763
                              hello,
                              with kind regards
                              Mike
                              The wireless card will be whitelisted in the bios.Use a genuine card and it should be ok, or request a modified bios to remove the whitelist over at bios-mods.com
                              • noumenon
                                • Aug 2021
                                • 12
                                • germany
                                #75
                                hmm,
                                all cards I tested are original Panasonic genuide and the 7260NGW was original sell with the book. Thats why I'am a little bit confused and think there is something missing in my bios.
                                Thats why it may be possible to get a dumb from a working MK4 BIOS with wlan working for testing. But all dumb I found were without info about working wlan or for other MK's
                                with kind regards
                                Mike
                                • noumenon
                                  • Aug 2021
                                  • 12
                                  • germany
                                  #76
                                  Good morning,
                                  has anybody a WLAN testet BIOS ROM for CF-53 MK4? I think model number is not a reason for the hardware.
                                  thanks
                                  Mike
                                  • ponchik123
                                    • Sep 2020
                                    • 7
                                    • Ukraine
                                    #77
                                    hi guys, here is my bios file (from CF-53 MK-4). is it possible to remove the bios password? many thanks in advance.
                                    • peste
                                      • 12719
                                      • ROMANIA
                                      #78
                                      try..
                                      • ponchik123
                                        • Sep 2020
                                        • 7
                                        • Ukraine
                                        #79
                                        Originally posted by peste
                                        try..
                                        Everything worked 100%. I am very happy and very grateful.
                                        • Lucke
                                          • Apr 2022
                                          • Italy
                                          #80
                                          Hi guys, I have a CF-53 mk4 identical to that of ponchik123 (post 77), with PW. Can I use the mod released by peste also for mine?
                                          • AquaMan Ua
                                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                                            by AquaMan Ua
                                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                            05-17-2025, 09:40 AM
                                          • aa10aa10
                                            Panasonic Toughbook CF-33 mk1 BIOS repair
                                            by aa10aa10
                                            Good day,
                                            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                            01-21-2025, 06:13 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • James Jackson
                                            Panasonic CF-20G0247VM BIOS Bad Flash Help
                                            by James Jackson
                                            I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
                                            Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
                                            05-01-2025, 11:28 AM
