Lenovo Thinkpad L15 (CPU 10th Gen) Supervisor Password
  • Paficator
    • Mar 2020
    • 13
    • France
    Hello All,
    I recently acquired a new Lenovo Thinkpad L15 Gen 1 with a i3 10110U.
    - MB: GL4A0/GL5A0 NM-C631
    But the issue is, after opening and dismantling it to clean it / changing the thermal paste, I realized that there is a Supervisor Password.
    As this serie is quite new, I don't know is there is a solution to remove it ?
    I can give you every information I have in my possession if needed specially the Bios Dump.
    Thanking you 1 million times in advance
    Regards
  • Paficator
    • Mar 2020
    • 13
    • France
    Re: Lenovo Thinkpad L15 (CPU 10th Gen) Supervisor Password
    So, I extracted the bios dump, and uploaded here
    The Bios chips is a MXIC MX25L8006E.
    Don't hesitate to ask any informations, I'll do my best to answer it.
    Thanks again ^^
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      Yeah, no, it is not
      • Paficator
        • Mar 2020
        • 13
        • France
        Originally posted by RethoricalCheese
        Yeah, no, it is not
        Are you sure this it not the bios chip ? (Security chip ?)
        There is no other chip like this on the MB.
        • Paficator
          • Mar 2020
          • 13
          • France
          Here is some pictures of the Motherboard.
          I'm not used to work on it
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            MX25L8006E is for sure thunderbolt 3 chip, nothing to do with bios/supervisor lock.
            Your bios chip is right next to wifi card. But the password is not there either. It's most likely in nuvoton chip.
            • Paficator
              • Mar 2020
              • 13
              • France
              Oh, I didn't know that, thank you for the information.
              So I imagine that it's gonna be quite complicated to reprogram the chip with this format ^^
              Is there any solution to delete the supervisor lock ?
              • Pcmot
                • Sep 2021
                • United Kingdom
                yes i got the same issue with this board, any way around it. Is there a standard board dump for this.
                • imranromi
                  • Jan 2015
                  • 1290
                  • Pakistan
                  Yet not have solution bios or via Programmer.For programmer you need to config file in nuvoton npce68apa0dx.
                  But now not have schematic so very hard for unlock.
                  • iTec
                    • Oct 2017
                    • 29
                    I can confirm that also, the chip is NPCE68APA0DX, I'm almost 99% positive that it does have different pin out than previous models. No keyboard settings worked, nor offline reading 👇🏼. The unit I'm working on is Ryzen.
                    The picture below is before I had placed the 2 10k resistors on designated pads.
                    No luck before or after.
                    • Karol
                      • May 2016
                      • 90
                      • Romania
                      I find the config, the problem is that the chip have different protocol for read/write operation. So the developer of the software programmers (SVOD, Vertyanov, RT809H, etc.) need to come with a software update.
                      For the moment everybody is stuck !
                      Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
                      • imranromi
                        • Jan 2015
                        • 1290
                        • Pakistan
                        Can you share config file i try to read
                        • TopMan007
                          • Dec 2020
                          • 8
                          • Czechia
                          Hi Karol,
                          everybody is stuck until you share programming data sheet...
                          • Karol
                            • May 2016
                            • 90
                            • Romania
                            Do you know something what I don't know ?
                            I'm available for exchange of information. But I think you will be stuck to.
                            • evserv
                              • Jun 2014
                              • 361
                              • Russia
                              NPCE68APA0DX
                              Not one of the programmers available to us can work with this chip yet.
                              The problem is not with the config file, this chip uses a different protocol for reading and writing.
                              We just have to wait for the programmer's author to add an algorithm to his programmer to work with this chip!
                              • TopMan007
                                • Dec 2020
                                • 8
                                • Czechia
                                Originally posted by evserv
                                NPCE68APA0DX
                                Evserv,
                                do you know when the author of programmer will update this one?
                                Thanks!!!
                                • evserv
                                  • Jun 2014
                                  • 361
                                  • Russia
                                  To support this chip, you need documentation describing the programming algorithm ...
                                  If anyone has this documentation please share with me.
                                  • TPuser
                                    • Sep 2021
                                    • Ukraine
                                    NPCE68APA0DX
                                    So what if i just replace the nuovoton chip. Can it help?
                                      • 21649
                                      There are 2 dediprog programmers that have added support for the chip (july 2021). StarProg-U is the cheapest at $750 ,the adapter costs around 150 .Don`t know about the algorithm but you can find the chip ID if you search through the programmer software xml files .Maybe its downloaded from the dediprog server ?
                                      • maksoft121
                                        • Oct 2019
                                        • india
                                        There is another bios chip beside processor. i have the same issue lost the file in that chip.
                                        please upload file from main bios.
                                        the size may vary from 24mb to 30mb.
                                        the file from second bios is 1 mb .
                                        both needed to run the laptop.
                                        lost one. please upload it for me.
                                        thank you in advance .
                                        • Andreasandreou
                                          Lenovo Thinkpad T14s GEN 4 Supervisor Password Bypass
                                          by Andreasandreou
                                          Hello, I have Lenovo Thinkpad T14s GEN 4 serial number GM-0FK2ER laptop. It was brought to me by a customer to reinstall windows. The problem is it is locked with a superviser password. Can anyone please give instructions on how to reset the bios or bypass the supervisor password? Thank you.
                                          09-02-2025, 09:45 AM
                                        • lrservicios
                                          Lenovo Thinkpad X12 Detachable 1st GEN Supervisor Password
                                          by lrservicios
                                          Hi !
                                          I have a Lenovo Thinkpad X12 Detachable 1st GEN with Supervisor Password - Type 20UV-S2Q100 Serial Number: PW-01NB9P - PW01NB9P
                                          I attach Bios 2 Chip reading Bin, please can you try to clear it for me ?...
                                          05-02-2025, 12:35 PM
                                        • AppleLover123
                                          Lenovo Yoga X380 22LH Supervisor Password removal
                                          by AppleLover123
                                          Hey guys,
                                          have a laptop here that has a supervisor Password (dump in Attachements).
                                          Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
                                          the laptop works but everytime it wants me to type a supervisor password i never set.
                                          I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
                                          Anyway i wanted to ask what of the two chips is the ec bios because on the left...
                                          04-17-2025, 03:42 PM
                                        • RMDUiFT
                                          Should I buy a Lenovo Thinkpad E495 with bios password?
                                          by RMDUiFT
                                          Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                          I have a few questions:
                                          • If I would buy this laptop and have
                                          08-25-2024, 09:00 AM
                                        • kuraimangetsu
                                          LENOVO ThinkPad E14 E15 JE442 NM-E211 bios supervisor password remove
                                          by kuraimangetsu
                                          Hi
                                          LENOVO ThinkPad E14 E15 JE442 NM-E211 bios supervisor password remove...
                                          03-31-2024, 07:25 AM
