Lenovo Thinkpad L15 (CPU 10th Gen) Supervisor Password
  • Redion
    • Nov 2010
    • 59
    Re: Lenovo Thinkpad L15 (CPU 10th Gen) Supervisor Password
    Originally posted by RethoricalCheese
    NPCE68BPA1DX I unlocked with vertyanov. It was a LAR-2 board. The problem was that the provided config was a bit wrong there.
    Could you upload the correct config? <3
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      #62
      changed left to right and 36 to 32.
      • Redion
        • Nov 2010
        • 59
        Ahh, I already did that, and I get 000 or Ffff or 7f .... Hm....
        • Redion
          • Nov 2010
          • 59
          Can you please upload the config string?
          • r12x2
            • Apr 2015
            • 20
            • Ukraine
            #65
            Originally posted by farouk_1994
            i have the latest update qs you can see in the picture and i upload the file that i got after reading the io
            Try to read it with the battery attached
            • rbvndonh
              • Mar 2021
              • 162
              • B
              #66
              No solution for RT809H?
              Can you post picture with pinout connection on motherboard?
              • rbvndonh
                • Mar 2021
                • 162
                • B
                #67
                Originally posted by diego2019
                yes, with svod4, you have to update to be able to read that ec, it is also 256 not 128. in the end I was able to do it.
                Can you please upload full config and connection from SVOD?
                I will try to connect using RT809H
                • rbvndonh
                  • Mar 2021
                  • 162
                  • B
                  #68
                  I found a Vertyanow successor NM-C631 KB_pins=40 LEFT DOWN 05MM FLASH=256 JENK=7 TCK=13 TMS=11 TDI=14 TDO=17 CHIP=NPCE68APA0DX 0x0FE2201F (evserv)
                  This will allow to connect using RT809H?
                  • just_bios
                    • Mar 2021
                    • 39
                    • Netherland
                    #69
                    hey guys..
                    which programmer supports npce68bpa1dx..? can u pls give me a link..?
                    • diego2019
                      • Mar 2018
                      • 30
                      • peru
                      #70
                      hello friends, first you have to do is update your svod4, ask the manufacturer for that, second the steps are in the note, and third you have to connect the battery and charger. I leave the clean files of the ec.
                      • hardwareserwis
                        • May 2016
                        • 10
                        • poland
                        #71
                        does reading from svod 3.0 work for you ?
                        • Redion
                          • Nov 2010
                          • 59
                          Why is the extracted EC file not 256kb?
                          • hardwareserwis
                            • May 2016
                            • 10
                            • poland
                            #73
                            will i read svod 3.0 ?
                            • adiasterix81
                              • Aug 2017
                              • 40
                              #74
                              how did u read the chip? through the keybord cable or desolder it ?
                              • 7Ironhide7
                                • Jun 2018
                                • 19
                                • Ukraina
                                #75
                                Originally posted by Redion
                                So did anyone had any luck using SVOD4 or vertynov?
                                From SVOD i keep getting empty reading and cant write or erase or verify.
                                Has anyone had any luck?
                                SVOD and VERTYANOV are proofreading the firmware, ABOVE POSTED A CLEAN, READING CONSISTS IN THE CORRECT CONNECTION !!!!!
                                • dhan
                                  • Jun 2018
                                  • 134
                                  • hp
                                  #76
                                  please remove password of this EC.
                                  ryzen build
                                  nm-c741
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #77
                                    ryzen build
                                    nm-c741
                                    Read the rules before posting:
                                    You MUST:
                                    Become a Badcaps supporter
                                    Thanks to all supporters.
                                    • rbvndonh
                                      • Mar 2021
                                      • 162
                                      • B
                                      #78
                                      Please help with connection of RT809H.
                                      With auto-ISP it shall connect without problem?
                                      RST cable shall be connected?
                                      There is somwere 10K resistor to switch to able programming?
                                      I made schematic fot ISP/JTAG, can someone confirm?
                                      reupload with small image
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #79
                                        Provide the full machine model number, serial number (or Service tag, SNID), EC chip model number, and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                                        • rbvndonh
                                          • Mar 2021
                                          • 162
                                          • B
                                          #80
                                          Vesko,
                                          Author of this topic ask about password and how to recover it. Seems he made a post in wrong part of forum, as he didn't made bios request, but password removal help.
                                          I continue discussion of how to remove password.
                                          I didn't upload bios file at all, so i think this is missunderstanding.
                                          • Andreasandreou
                                            Lenovo Thinkpad T14s GEN 4 Supervisor Password Bypass
                                            by Andreasandreou
                                            Hello, I have Lenovo Thinkpad T14s GEN 4 serial number GM-0FK2ER laptop. It was brought to me by a customer to reinstall windows. The problem is it is locked with a superviser password. Can anyone please give instructions on how to reset the bios or bypass the supervisor password? Thank you.
                                            09-02-2025, 09:45 AM
                                          • lrservicios
                                            Lenovo Thinkpad X12 Detachable 1st GEN Supervisor Password
                                            by lrservicios
                                            Hi !
                                            I have a Lenovo Thinkpad X12 Detachable 1st GEN with Supervisor Password - Type 20UV-S2Q100 Serial Number: PW-01NB9P - PW01NB9P
                                            I attach Bios 2 Chip reading Bin, please can you try to clear it for me ?...
                                            05-02-2025, 12:35 PM
                                          • AppleLover123
                                            Lenovo Yoga X380 22LH Supervisor Password removal
                                            by AppleLover123
                                            Hey guys,
                                            have a laptop here that has a supervisor Password (dump in Attachements).
                                            Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
                                            the laptop works but everytime it wants me to type a supervisor password i never set.
                                            I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
                                            Anyway i wanted to ask what of the two chips is the ec bios because on the left...
                                            04-17-2025, 03:42 PM
                                          • RMDUiFT
                                            Should I buy a Lenovo Thinkpad E495 with bios password?
                                            by RMDUiFT
                                            Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                            I have a few questions:
                                            • If I would buy this laptop and have
                                            08-25-2024, 09:00 AM
                                          • kuraimangetsu
                                            LENOVO ThinkPad E14 E15 JE442 NM-E211 bios supervisor password remove
                                            by kuraimangetsu
                                            Hi
                                            LENOVO ThinkPad E14 E15 JE442 NM-E211 bios supervisor password remove...
                                            03-31-2024, 07:25 AM
