EPK50 LA-G073P Bios dump need
  • mesta83
    • Nov 2015
    • 75
    • merseyside
    #81
    Thanks, tried doing this, transfered in hex editor but now laptop is not turning on
    • peste
      • Dec 2016
      • 12254
      • ROMANIA
      #82
      try..
      • mesta83
        • Nov 2015
        • 75
        • merseyside
        #83
        It's weird. Laptop turned on, displayed a message about manufacture mode and then when attempted to enter bios asked for administrator pass anyways
        any more ideas? Thank you for all your help so far
        • madz9999
          • Sep 2011
          • 8
          #84
          I have same issue heres my backup file.. 5-3 blinks
          Sn: CND8265G0N
          • peste
            • Dec 2016
            • 12254
            • ROMANIA
            #85
            Sn: CND8265G0N
            you have everything you need at post #15....084AA
            https://www.badcaps.net/forum/troubl...-0#post3267525
            • aladin2l
              • Sep 2020
              • 22
              • phillipines
              #86
              Please need help i already check all the posbile voltage problem even ram slot already soldered but same error 3 long blink 2 shor blink maybe bios is corrupted kindly fix my bios
              heres the model and dum
              model: hp 15-da0348tu
              serila number : CND9055VSX
              hoping this will be notice
              and adavnce thanks who can help
              • peste
                • Dec 2016
                • 12254
                • ROMANIA
                #87
                see the post above...
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • DynaxSC
                  by DynaxSC
                  11-17-2023, 10:56 AM
                • grimacelord
                  Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                  by grimacelord
                  This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                  Motherboard model number: DA0PAMB46A1 REV: A
                  Secondary motherboard model number: 0PAB
                  SKU: 685K4UA
                  Serial number is: 5CD3223BJP
                  Recently reflashed this laptop with latest BIOS and once...
                  05-07-2024, 08:06 AM
                • DynaxSC
                  Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                  by DynaxSC
                  I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                  It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                  I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                  11-06-2022, 05:22 PM
                • vinaypundith
                  Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                  by vinaypundith
                  I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                  So, I'm looking for a BIOS dump for this machine - a 16MB one....
                  08-03-2024, 12:32 PM
