EPK50 LA-G073P Bios dump need
  • kadi144
    • Aug 2015
    • 690
    • algerie
    #61
    Re: HP15-da0081nk bios
    Originally posted by peste
    select an equivalent chip from the programmer's database...or change the bios chip..
    I want read it for BID ؟
    • Infinity13197
      • Sep 2020
      • 20
      • Nigeria
      #62
      Re: epk50 la-g073p rev 1.0 bios size 4mb needed
      Originally posted by gsm_doctor
      epk50 la-g073p rev 1.0 bios i need 4mb of size...thank you
      i have same problem
      • peste
        • 13420
        • ROMANIA
        #63
        Re: EPK50 LA-G073P Bios dump need
        Originally posted by talentueux
        BONJOUR CHER TOUS BESOIN DU BIOS HP da0004nk EPK50 LA G073P REV1.0 PROCESSEUR CELERON MERCI
        read this..
        • Technosoft
          Absolute Noob
          • Jul 2023
          • 7
          • The worlds backyard
          #64
          Hello, hopefully someone can help me with my problem.
          I have a motherboard EPK50 LA-G073P Rev.1.0, HP model 250 G7.
          I have read the forum and from what I can understand my BID is 42 49 44 so Post #46 should work for me (084AA).
          My CHIP is an XMP XM25QU64A
          The only BIOS reading tool that I have is a CH341A MinProgrammer.
          I have attached the Original BIOS.
          My problem is that the only available software that recognizes the chip is NeoProgrammer V2.2.0.10
          Whenever I write the BIOS it ends successfully but on verification I get "Verification error on address: 0x00000000, Device: 0x01"
          Can I flash this BIOS with my current tool, do I need another software?
          My skills are almost 0% on BIOS recovering so I hope I can get some feedback.
          Thanks in advance!
        • BIOSSASI
          Creator 💀
          • Dec 2023
          • 33
          • SRILANKA
          #65
          Hi friends! I have an HP 15 Da-0004tu , I read the bios and when clear the chip and re write The Bios Verify Failing. Im using the same file and same chip That i backed up. Bios Chip - XMC QH64AHIG
          and im using Ch341A Programmer. Anyone Can help me for the bios File
          LapModel- Hp 15- Da0004tu
          Mb - EPK50 LA-G07DP
          Rev 1.0
          XmC Chip Inside - Xmc HQ64AHIG
          Thanks In Advance
        • Technosoft
          Absolute Noob
          • Jul 2023
          • 7
          #66
          My CHIP is an XMC XM25QU64A
          Thanks in advance!
          Yes, I am sorry about that, I forgot about that part.
          In these darn HP Models its even hard to read them right from the way they are imprinted.
          HP Model: HP 250 G7, Product ID: 6EB60EA#ABB, Serial Number: CND9101JJT
          Edit: My XMC Chip under a microscope reads XMC QU64AHIG
          • Technosoft
            Absolute Noob
            • Jul 2023
            • 7
            #67
            Just a bump for posts 64 & 66.
            Hopefully someone can help me. With the bin file "084AA, without any modification" I can Read, Erase, Write, BlankCheck successfully but when Verifying I always get "Verification error on address: 0x00000001, Device: 0xFF, Buffer: 0x78"
              SMDFlea commented
              Editing a comment
              Replace the bios chip
            • Technosoft
              Technosoft commented
              Editing a comment
              Thanks for the response!
          • niwantha
            • Nov 2020
            • 11
            • Sri Lanka
            #68
            Originally posted by lapfix
            Re: Hp 15-da epk50 la-g073p
            Try and give feedback
            This works perfectly. Thanx.
            • valin7900
              • Jan 2019
              • Orizaba
              #69
              i´ve the same problem, i find the correct bios, it´s for la-g073p rev. 1.0
              • peste
                • 13420
                • ROMANIA
                #70
                post S/N...
                read..https://www.badcaps.net/forum/troubl...before-posting
                • zurvanielle
                  • Feb 2017
                  • 137
                  • Philippines
                  #71
                  thanks for sharing...^_~
                  • Manasseh Mukuwa
                    • Nov 2021
                    • Zambia
                    #72
                    If you are using a ch432 or a ezp 2010-2019+ or any other small writing device that cant detect the bios... Please use select any type of chip in your writing software that has 8mb and then write using 6MHZ or 3MHZ but preferably 6MHZ.... That's when it'll work... Anything like 12MHZ or the rest won't work... I suffered for two days and now it's working...
                    Another thing if you have Intel Celeron, use the 084AA Bin.
                    Thank you and happy recoveries
                    • epoy
                      • Jun 2016
                      • 43
                      • phillipines
                      #73
                      can some one clean my bios file
                      Hp 15-da0348tu
                      EPK50 LA-G073P
                      REV:1.0
                      2018-03-09
                      I attach my old one
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12268
                        #74
                        Hp 15-da0348tu
                        EPK50 LA-G073P
                        REV:1.0
                        2018-03-09
                        I attach my old one
                        Where is your serial number ? This is forums' rule
                        • epoy
                          • Jun 2016
                          • 43
                          • phillipines
                          #75
                          heres my old dump
                          same us on the 1st post
                            • 21676
                            heres my old dump
                            Thread merged. You were not asked to post the same bios backup again, you were asked for the laptop serial number.
                            • epoy
                              • Jun 2016
                              • 43
                              • phillipines
                              #77
                              .Heres my SN# CND9020KHF
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12268
                                #78
                                HP Notebook - 15-da0348tu
                                • mesta83
                                  • Nov 2015
                                  • 75
                                  • merseyside
                                  #79
                                  Hi I have a HP EPK50 LA-G073P Rev:1.0 with a bios administrator password. Can anyone unlock please? SN: CND01742G2
                                  • peste
                                    • 13420
                                    • ROMANIA
                                    #80
                                    use the 084AA bios from post #15..and there you also have the DMI information range...transfer the information from your bios to the virgin bios from post #15..
                                    https://www.badcaps.net/forum/troubl...-0#post3267525
                                    • Ahari
                                      by Ahari
                                      I...
                                      08-13-2025, 06:12 AM
                                    • Habble7
                                      by Habble7
                                      Suspected Cause:
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
                                    • haitham sharabati
                                      by haitham sharabati
                                      Hello engineers 😀,
                                      🔧 Device Info:
                                      - Model: HP 15-da2007ne
                                      - Product Number: 8XF55EA#ABV
                                      - Serial Number: CND0338P0D
                                      - CPU: Intel Celeron N4000
                                      💀 Problem:😅
                                      08-07-2025, 04:54 AM
                                    • Citymin
                                      by Citymin
                                      S/N : 5RNK9FFT70...
                                      08-05-2025, 05:12 AM
                                    • DynaxSC
                                      by DynaxSC
                                      11-17-2023, 10:56 AM
