Ec Bios dump for DELL LA-F401P REV 1.0 A00
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    Hi I need bios EC for DELL LA-F401P REV 1.0 A00
    My old is deleted, i try some files in forum but all corrupted
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: Ec Bios dump for DELL LA-F401P REV 1.0 A00
    What's your laptop model / serial
    • digitalpc
      • Jun 2016
      • 305
      • .DLL
      s/n 79x6rq2
      reg model p72g
      I upload main bios here orginal one
      EC bin is all clear
      • digitalpc
        • Jun 2016
        • 305
        • .DLL
        Any Help..
          • 22282
          Deleted from where , which chip is it deleted from. This board has an MEC5105 doesn`t it ?
          • digitalpc
            • Jun 2016
            • 305
            • .DLL
            Board have another chip
            chip 1 is bios I upload here
            chip 2 is empty inside
              • 22282
              Whats the part number on chip 2 ,it should be a small size,maybe for the thunderbolt firmware.It could be for the EC ,not sure
              • digitalpc
                • Jun 2016
                • 305
                • .DLL
                25q80csig
                • kjchatman
                  • Dec 2012
                  • 213
                  • united states
                  i have a this same board and the super IO (mec5105) needs replacing because it causes a short on rtc_cell . how do you reprogram these chips?
                  • mtechtop
                    • Oct 2020
                    • 4
                    • gabon
                    i have same problem my EC bin is all clear . any help ? Ec Bios dump for DELL LA-F401P REV 1.0 A00
                    • peste
                      • Dec 2016
                      • 13924
                      • ROMANIA
                      post S/T, full name and model,post the contents of the bios chip even if it is corrupted.. ,etc.
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • Loli Popu
                        DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                        by Loli Popu
                        Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                        12-13-2024, 08:29 AM
                      • capoplays
                        Help with BIOS update on Dell G15 5515 after chip replacement
                        by capoplays
                        Hey everyone,
                        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                        When I check the BIOS using the F12 menu Flash...
                        10-24-2025, 06:53 AM
                      • wwbielsko
                        Dell latitude 5320 corrupted bios repair
                        by wwbielsko
                        I got corrupted bios bin file, which way is correct to repair.
                        File puts errors on Me Analyzer and cannot open in FIT.
                        To open in FIT I made:
                        1. Extract MFS and EFS using MEAnalyzer from other bios file with the same parameters
                        2. put it in HxD to my file
                        3. MEAnalyzer shows 1 error after that
                        4. file opens in FIT
                        and:
                        A:
                        1. extract current dell bios on website
                        2. put System BIOS with BiosGuard v1.30.0.bin using FIT
                        3. MEAnalyzer OK no errors
                        (this version shows only logo at bootup - freezeing)...
                        04-23-2024, 06:16 PM
                      • Akhlz001
                        by Akhlz001
                        09-20-2025, 07:15 PM
