T2 Chip Programmer Tool
This topic is closed.
+ More Options
Posts
  • alerm
    • Mar 2022
    • 16
    • Deutschland
    #121
    Re: T2 Chip Programmer Tool
    Does someone know what apple uses to recognize that the Mac is linked to an Apple Id? I know it's not only the Serial Number.
    And I managed to get an Apple Business account, what can I do to MDM my MacBook?
    • kevingill
      • Jun 2013
      • 152
      • England
      #122
      The serial number, wifi and bluetooth MAC addresses are used to identify a Mac.
      I don't know about how a business account can help, but I have an MDM locked Mac if you want to try.
      • Abdou128
        • Apr 2022
        • algerie
        #123
        thanks
        • blacky0425
          • Feb 2019
          • 9
          • usa
          #124
          I have an a1932 that has mdm lock. Can someone provide me steps on what needs to be done to unlock. I have a programmer and am good at soldering / bga rework. Am used to dealing with non t2 macbooks. Any guidance would be greatly appreciated. Thanks
          • kevingill
            • Jun 2013
            • 152
            • England
            #125
            Someone posted a method to remove MDM lock on a different thread:
            https://www.badcaps.net/forum/showpo...&postcount=116
            • blacky0425
              • Feb 2019
              • 9
              • usa
              #126
              I guess i can give this a try but not sure if this works for t2 macbooks as the guide is for m1 macbooks
              • abi98
                • Nov 2019
                • 13
                • mass
                #127
                It should work the same. As far as i understand it just reroutes the MDM and DEP requests to a null IP.
                usually for MDM I just set up without an internet connection and the rest seems to be fine. my 2019 16" MacBook pro has been going great, no MDM lock, and was able to do an OTA update.
                • curiositymaster
                  • Apr 2021
                  • 45
                  • Nigeria
                  #128
                  This is just a temporary bypass and not “removal”, but it's worth the try.
                  • fontecno
                    • Jul 2021
                    • 7
                    • España
                    #129
                    Originally posted by Stephen
                    I usually just change the last digit. In most cases
                    Pls I have this MacBook pro 2018, that I have restore it but it don't boot up. So my question is, is the MacBook block with icloud or eff password I have send the pic down thanks
                    • alerm
                      • Mar 2022
                      • 16
                      • Deutschland
                      #130
                      Will Apple Support unlock your locked Mac if it finds it in your Apple Account?
                      • kevingill
                        • Jun 2013
                        • 152
                        • England
                        #131
                        I presume you're talking about activation lock?
                        How are you planning to get the Mac into your Apple account if you can't get past the activation screen? Are you thinking of registering a dummy Mac with the same serial?
                        Or something else?
                        I like the 'outside the box' thinking
                        • alerm
                          • Mar 2022
                          • 16
                          • Deutschland
                          #132
                          Or something else?
                          Yeah I managed to create a Mac in my Apple account with same model and samer serial and same Mac Address. Looks as if it was the same.
                          Only thing I cant change the Bluettoth Address, otherwise I would have a Mac in my Apple Account with same Model, Serial, Mac and Bluetooth Address.
                          • fontecno
                            • Jul 2021
                            • 7
                            • España
                            #133
                            Or something else?
                            Pls is there any solution to my problem up there that I just posted, I have the T2 program but I don't know it it will help my problem
                            • kevingill
                              • Jun 2013
                              • 152
                              • England
                              #134
                              I tried something similar with an earlier 2015 MBA, but it didn't work
                              So I guess, you'll ask Apple to sort out the strange issue? Wouldn't they just ask you to restore the Mac and sign in again? I do wonder if Apple will eventually work out what we're upto and close our Apple accounts...
                              Regarding the BT and WIFI MAC addresses, are these stored in the WIFI EEPROM (U3710) and BT FLASH (U3750) on an Intel MBA 2020?
                              • fontecno
                                • Jul 2021
                                • 7
                                • España
                                #135
                                Can the T2 programmer tool remove the 6 pin lock fot the MacBook A1989
                                • kevingill
                                  • Jun 2013
                                  • 152
                                  • England
                                  #136
                                  I'd search through this fantastic forum first to see what others have done.
                                  Otherwise, I've previously done a brute force attack with a Teensy microcontroller, but that was with 4 digits, not 6. Might take a while, but you could try birthdays first.
                                  • TrumanHW
                                    TrumanHW
                                    • Jun 2021
                                    • 52
                                    Originally posted by Pedro147
                                    Thanks for the comprehensive reply and I'll have a look and see if I can get a handle on it sometime. Appreciate the effort TrumanHW
                                    This community is just beyond talented ... and generous with info they could easily treat as "dark arts" and hoard.
                                    I can't do enough to pull my weight & express my reciprocal gratitude as it is.
                                    LMK if you run into any snags; I'll be glad to help.
                                    • TrumanHW
                                      TrumanHW
                                      • Jun 2021
                                      • 52
                                      Right, that's the problem with those 6-digit pins; they take 100x longer for brute-force attack.
                                      I'll look and see if I can infer the location in the rom of a PW I create (either the Hx000000) or if there's ASCII info) to help you find it using the J6100 connector (if you have an interface for it).
                                      If you don't, I have a suggestion for alibaba that I think is the CHEAPEST on there ($38 for L2013+)
                                      • kevingill
                                        • Jun 2013
                                        • 152
                                        • England
                                        #139
                                        It's doable if you leave it running for a week.
                                        I wrote my own version that tries 5 times (I think), then restarts the Mac and tries again.
                                        • TrumanHW
                                          TrumanHW
                                          • Jun 2021
                                          • 52
                                          Okay, this is exclusively for T2, yes..?
                                          Any luck with M1 devices ..?
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • baletak
                                            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
                                            by baletak
                                            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
                                            I have updated laptop model number.
                                            1) I did not find the way to update laptop serial number - I have this one.
                                            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
                                            Hope to find someone to help me with this as I am hitting dead end at the moment.
                                            Many thanks
                                            Miro
                                            05-23-2025, 01:21 AM
                                            How to add chip support to NeoProgrammer software for the CH341A Programmer
                                            by SMDFlea
                                            Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                            and once you do find them there`s a few crucial steps missing.
                                            Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                            Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                            After adding the chip save the xml file and copy it to the root directory of the...
                                            05-26-2024, 07:15 AM
                                            by SMDFlea
                                            Bad...
                                            09-02-2021, 04:40 PM
                                          • BMCappelletti
                                            Asus Chromebox CN62 - wrong chip put on BIOS reader
                                            by BMCappelletti
                                            Long story short:
                                            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                            - gave the computer to his son a couple years later
                                            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                            (seems like the story was not that short)
                                            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                            01-08-2025, 07:27 PM
