T2 Chip Programmer Tool
This topic is closed.
+ More Options
Posts
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    I was curious if the T2 chip serial being changed would allow cracking the Firmware lock and icloud lock of a device? We came across the T2 Rom Tool and this allows the use of changing the serial which in our experience would allow removal of MDM on older models (2017-and older). Would that isolate the icloud bypass since it is married to the serial of the T2 chip? Curious since we are close to pulling the trigger on a wholesale lot and we anticipate iCloud devices in MacBooks etc. Piernov or anyone have thoughts on this?
    Update: People are saying yes and no. If you change the serial you would have to change the UUID? Apple looks at the serial and the UUID in the rom. I know we could figure this out some how some way.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: T2 Chip Programmer Tool
    The serial can be changed in the T2 ROM without too much trouble. It's a 25-series 1.8V SPI ROM so a decent programmer can deal with it (it's a 3x4mm package so smaller than usual though). Serial number should show up in the dump after "mNrS" string.
    I don't know what are the repercussions. I'm probably at least 5 years away from seeing a T2 machine in front of me.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Yeah I feel thats the difficult part...taking that risk on . T2. I mean worst case scenario we just have to RUN DFU lol
      sigpic
      • Nico Latour
        Banned
        • Sep 2019
        • 52
        • france
        change serial on a t2 machine only works for mdm, mdm is linked on serial and icloud is linked on serial, wifi adres,bleutooth adres, so change serial not solved the problem, even the serial is not stored in the t2 chip and cant change it with software, the serial is in a small chip (4mb) and need to solder before can read write
        • curiositymaster
          • Apr 2021
          • 45
          • Nigeria
          Of course you need to remove the chip to reprogram it. I have used this to change the serial number on T2 twice. The programmer I used was purchased on aliexpress and it came with the bin file and bypass software.
          • sanmlis
            • Jan 2020
            • Россия
            Please share bin files, it would be interesting to study them
            • curiositymaster
              • Apr 2021
              • 45
              • Nigeria
              I hope it helps
              • andriyd1
                • Dec 2013
                • 7
                How do you identify WiFi address and Bluetooth address in the dump read from small bt and WiFi rom chips?
                • RethoricalCheese
                  • Mar 2013
                  • 1517
                  • Estonia
                  Hey! Could you upload the whole USB stick content? Software and other files.
                  • imranromi
                    • Jan 2015
                    • 1288
                    • Pakistan
                    For which purpose you want to find?
                    • andriyd1
                      • Dec 2013
                      • 7
                      Activation locks
                      • curiositymaster
                        • Apr 2021
                        • 45
                        • Nigeria
                        Activation locks
                        You can't unlock simply by changing values on the dump file.
                        • stevie
                          • Apr 2010
                          • 30
                          attached are the bin files from the T2 activation
                          you can run the mina activation tool by putting the MacBook Pro in DFU Mode
                          but unless you pay the unreasonable $90 to $120 that mina resellers
                          want for letting you submit the serial you want to use
                          it will come up with the message "serial no authorised"
                          you can use the tool with the bin files with the tool but although
                          successful it will give wrong summary details in about this mac
                          ie: displays that it is a 13" when it should state its a 16" etc
                          • toto2020
                            • Sep 2021
                            thanks for the valuable files. i downloaded and i will test it asap !
                            • Bb68
                              • Jul 2017
                              • 15
                              • South Africa
                              Please could you send me these files , the one on the original link are corrupt
                              • zinnou
                                • Dec 2016
                                • 35
                                • algeria
                                hello After write file macbook air 2018 A1932 dead now only DFU mode
                                restored put all time dfu mode
                                • anhbanxoi
                                  • Sep 2021
                                  • 170
                                  • VN
                                  In the video they also run some script (checkm8 i think) to be able to bypass and activate the machine.
                                  • Bb68
                                    • Jul 2017
                                    • 15
                                    • South Africa
                                    Hi Im having the same problem, Flashed the rom with the A1932 unlock bin file and the unit is stuck in dfu mode. Anyone has a solution on this ?
                                    • MughalG
                                      • Aug 2012
                                      • 9
                                      • Pakistan
                                      i Think rom chip is not soldered well
                                      • Bb68
                                        • Jul 2017
                                        • 15
                                        • South Africa
                                        Originally posted by MughalG
                                        i have good working Activation_Lock bin files for all models with same configuration as per model
                                        of course method is not for free
                                        How do I purchase ?
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • baletak
                                          Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
                                          by baletak
                                          had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
                                          I have updated laptop model number.
                                          1) I did not find the way to update laptop serial number - I have this one.
                                          2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
                                          Hope to find someone to help me with this as I am hitting dead end at the moment.
                                          Many thanks
                                          Miro
                                          05-23-2025, 01:21 AM
                                          How to add chip support to NeoProgrammer software for the CH341A Programmer
                                          by SMDFlea
                                          Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                          and once you do find them there`s a few crucial steps missing.
                                          Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                          Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                          After adding the chip save the xml file and copy it to the root directory of the...
                                          05-26-2024, 07:15 AM
                                          by SMDFlea
                                          Bad...
                                          09-02-2021, 04:40 PM
                                        • BMCappelletti
                                          Asus Chromebox CN62 - wrong chip put on BIOS reader
                                          by BMCappelletti
                                          Long story short:
                                          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                          - gave the computer to his son a couple years later
                                          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                          (seems like the story was not that short)
                                          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                          01-08-2025, 07:27 PM
