Re: T2 Chip Programmer Tool
Bypass method is not permanent why would anyone want to do that when changing the serial is 100% never coming back even if you DFU restore it?
Also to answer the other guy when he changes the serial it gives activation error, this means it's iCloud locked and not MDM lock which means the T2 chip is the culprit, MDM locks do not use the T2 to communicate to verify. It goes like this
Apple Server checks in these steps.
1. Apple server checks Serial number , if it kicks back as MDM it follows up with two scenarios, you either get into Os Install or you get the company email lock.
2. Apple server checks T2 chip serial after step 1. So if step one is a serial that is changed and then checks to see if the T2 chip is assigned correctly, which in return will give Activation Server Error messages.
So in theory if you change the serial of an MDM device to new serial then you sign into your device with your iCloud after OS install and say you DFU reset it, that serial is now assigned to your iCloud with the T2 chip until you remove it.
Hope this helps
This topic is closed.
But when i try to install os on mdm lock after serial change it give activation error.Leave a comment:
right activation lock is based on email - be it personal or company
mdm lock is based on user profiles defined by company
therefore you can't be mdm locked on a wiped computer since there is no os with profiles installed on it.
if the activation lock email is the company email it doesn't make it a mdm lock.Leave a comment:
Not true. MDM can still have Activation lock to the company email. Changing the serial will solve this issue and remove the lock for good. Even with iBridge 6+Leave a comment:
it has to be there for the use cases that require itLeave a comment:
it is not mdm locked if it is wiped and with activation lock. mdm gets installed during os installation.Leave a comment:
I have some MacBooks that don't boot as I can't get past activation.
I can't bring up the terminal so the method you gave won't work.Leave a comment:
here
Use this command in terminal:
profiles status -type enrollment
Depending on your MDM enrollment status, you may see one of the following statuses shown below:
No MDM enrollment
computername:~ username$ profiles status -type enrollment
Enrolled via DEP: No
MDM enrollment: No
MDM enrolled, without user-approved MDM enable
MDM enrollment: Yes
MDM enrolled, with user-approved MDM enablee
MDM enrollment: Yes (User Approved)
DEP Enrolled
Enrolled via DEP: Yes
computername:~ username$Last edited by SMDFlea; 07-13-2022, 08:36 AM.Leave a comment:
I've done quite a lot of searching to easily find out whether a MacBook is MDM locked, but failed.
What's the easiest way to find if it's MDM activated on a MacBook that's been reset, i.e. no operating system.
Is it the availability of the option in the Recovery Assistant -> Activate with MDM key?Leave a comment:
i have only one board witрout fmmLeave a comment:
One guy sent me a video where one Chinese guy replaces T2 and make it work..Last edited by LevanGood; 07-05-2022, 02:33 PM.Leave a comment:
but a2141 and a2179 have different flex of touch id. i want make fully worked board. but all my a2179 have dead cpu too. Sorry I have one chip set for experimentLast edited by mich6el; 07-05-2022, 01:32 PM.Leave a comment:
Or you can sell me that ICs
P.S. I think that NANDs are not necessary to replace. But I still can be wrong.Last edited by LevanGood; 07-05-2022, 09:52 AM.Leave a comment:
Hello! I have successfully completed the reballing of chips (T2, Nand, Wi-Fi) removed from the dead processor board. When I get the Activation Locked Board, I will be able to experimentLeave a comment:
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by baletakHi,
had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
I have updated laptop model number.
1) I did not find the way to update laptop serial number - I have this one.
2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
Hope to find someone to help me with this as I am hitting dead end at the moment.
Many thanks
Miro-
Channel: BIOS Requests ONLY!
by SMDFleaAdding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
and once you do find them there`s a few crucial steps missing.
Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
After adding the chip save the xml file and copy it to the root directory of the...-
by SMDFleaCommon SPI bios chip programming Questions and Answers
Bad...-
09-02-2021, 04:40 PM -
Long story short:
- dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
- gave the computer to his son a couple years later
- son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
- too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
(seems like the story was not that short)
He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8... - Loading...
