T2 Chip Programmer Tool
This topic is closed.
  • LevanGood
    replied
    Re: T2 Chip Programmer Tool
    Originally posted by mich6el
    Hi! Glory to Ukraine? Did you manage to replace the chipset? I also have 2 2338 boards and I don't know which set to change: WI-FI, NAND, M1, SPI
    Hi) still can't find A2141 unlocked logic board to use in as a donor…
  • lamo
    replied
    Originally posted by pumemule
    I have a remove activation lock(MDM)
    Can i remove it? Or only bypass and how?
    mdm connected to serial number. I think you'll find a solution how to change serial number in t2 rom.
    good luck
  • pumemule
    replied
  • lamo
    replied
    pardon, 3 spi? but motherboard have 1 spi chip (SOC rom)
    a2338 board has 3 roms. all of them needs to be replaced. just look into schematic file.
  • mich6el
    replied
    Originally posted by lamo
    Glory to Heroes!
    yes. it can. but be careful when replacing chips. the procedure is too complicated.
    yes. i know man)
  • mich6el
    replied
    all above mentioned needs to be replaced: cpu, nand, wi-fi, spi(3 rom ic's).
  • mich6el
    replied
    Originally posted by ugamazing
    Theoretically, but MUCH easier said than done. Go try to pull a T2 and come back here once you've done so lol.
    Replace t2 not a problem. Will the laptop be activated with the original serial number and ssd? after replays ONLY t2 chip?
  • mferna14
    replied
    Thanks "Iamo" for the reply... so is there any other solution for this., can anyone shed a light on this issue of mine??? Thanks in advance
  • lamo
    replied
    Originally posted by mferna14
    Hi I was reading this Thread. Then I downloaded T2 Unlock Data Mina 1.4. My Model is MacBook Air A1932, but could not find A1932 T2 Unlock Data. I am getting error:21 - 0x15 (21) in DFU mode when I coonect to my other MacBook. Can I use the closet model or is there a separate Unlock Bin file for A1932 EMC 3184 2018??? Any help would be much appreciated., Thanks
    mina isn't working anyway.
  • mferna14
    replied
  • lamo
    replied
  • lamo
    replied
    Hi! Glory to Ukraine! If I have two boards 2179 with icloud and water damaget without icloud. replays t2 chip witout ssd and spi can fix activation lock?
    Glory to Heroes!
  • ugamazing
    replied
  • kevingill
    replied
    Has your spare board got an older, jailbreak capable bridgeOS?
    There's some information in this thread to work out if you have older or newer bridgeOS based on the screenshot of it booting into recovery.
  • mich6el
    replied
    according to my investigations, there're no useful information, except machine serial number and board number in t2 rom. t2 rom only need to boot into dfu. also, all known methods of jailbreak won't work, because of usb-c firmware patch in t2 chip. t2 chip also have small rom-memory inside. the only way to remove icloud lock is to modify ECID of t2. this operation isn't possible for current moment.
  • mich6el
    replied
    Originally posted by LevanGood
    Hey guys!
    Sorry for my english. I know it's poor cuz I'm from Ukraine))
    Look, I've got AppleID locked MB Pro A2141 and I wonder if I can unlock it.
    As I know Apple blocked jailbreak ability on the last MacOS.
    I've got another A2141 logic board with issues and it has FMM OFF.
    So I wonder if it's possible to replace some IC's from the defective logic board with FMM off to my locked board? Has anybody done this before?
    Should I replace T2 itself + SPI or should I replace WIFI+NANDs additionaly?
    Thanks in advance!
  • lamo
    replied
    Originally posted by Terry011
    Lots of talk about swapping components from unlocked boards, does anyone think a new jailbreak won't be released?
    as far as i know, it won't. apple fixed the security flaw with usb-c controllers.
  • ugamazing
    replied
    Of course, cuz activation lock is initially a hardware problem
    Yup. Hardware-only unlock imo.
  • LevanGood
    replied
    I personally do not think a true (and permanent--without exceptions) software-based bypass/unlock (as everyone thinks of it) will ever be released for the T2 models. That's my opinion.
  • ugamazing
    replied
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • baletak
    Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
    by baletak
    had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
    I have updated laptop model number.
    1) I did not find the way to update laptop serial number - I have this one.
    2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
    Hope to find someone to help me with this as I am hitting dead end at the moment.
    Many thanks
    Miro
    05-23-2025, 01:21 AM
    How to add chip support to NeoProgrammer software for the CH341A Programmer
    by SMDFlea
    Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
    and once you do find them there`s a few crucial steps missing.
    Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
    Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
    After adding the chip save the xml file and copy it to the root directory of the...
    05-26-2024, 07:15 AM
    by SMDFlea
    Bad...
    09-02-2021, 04:40 PM
  • BMCappelletti
    Asus Chromebox CN62 - wrong chip put on BIOS reader
    by BMCappelletti
    Long story short:
    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
    - gave the computer to his son a couple years later
    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
    (seems like the story was not that short)
    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
    01-08-2025, 07:27 PM
