HP EliteBook 845 G7 BIOS Pass
  • GabyCR
    • Mar 2015
    • 31
    • España
    #61
    Re: HP EliteBook 845 G7 BIOS Pass
    Originally posted by peste
    yes..this has two 33 Mb..write only on this the first one stays the same ..
    It works!!! Thank you very very much!!!!!
    • kangajoe
      • Jun 2022
      I have a HP EliteBook 845 G7 with a bios password enabled that I have lost.
      The mainboard has a Winbond 25Q256JVEN chip on top (this chip has 8 legs visible).
      On the underside is another Winbond 25Q256JVEN (this chip has NO legs visible).
      I have read most of the posts here and would like to confirm the following:
      1. Do I need to remove both of these chips or just the bottom chip for re-programming?
      2. Would the EZP203 be OK for the reading and re-programming work? (see link below)
      https://www.aliexpress.com/item/1005003634077363.html
      3. Do I need to upload the BIN file here to have it modified by a specialist or would some of the files already shared here be adequate to unlock the bios?
      Thank you in advance for any help you may be able to share with me!
      • sh4rp
        • Apr 2021
        • 8
        • Slovensko
        #63
        Originally posted by SMDFlea
        Wipe the dust off and try this bios,flash it only to the bottom one. Set bios defaults as soon as it boots
        Took me almost a year, but alas I did as instructed.
        The pc said someting about doing a bios backup and then it says HP Endpoint Security Controller Problem (Pic 1 in attachment)
        I can press enter okay and then I'm back at the familiar despised Power-On Authentication (Pic 2 in attachment)
        I spent more time repairing this notebook than using it...
        So what next?
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #64
          Originally posted by sh4rp
          So what next?
          Next - program both spi chips with the corresponding files from the attached archive and you're good to go.
          Become a Badcaps supporter
          Thanks to all supporters.
          • kangajoe
            • Jun 2022
            I have found that much of the information in many forums around this problem have been missing a lot of vital information.
            After my own research and experience I have documented exactly what worked for me.
            I hope that others may find this helpful.
            How to remove HP Elite 845 G7 bios password.
            The tools you will need are:
            EZP2023+ chip programmer (with 12 adaptors kit)
            This one has the WSON8x6 adaptor board
            Hxd (Hex editor free software)
            Hot air gun with small nozzle or better still a soldering station with hot air
            (I used a Dewalt heat gun with digital temp adjustment)
            Small soldering iron if you don’t have a soldering station
            Flux (I used Craig rosin flux from Jaycar)
            Magnifier or electronics microscope (best option!)
            Large steel tweezers to grip the chip
            Blunt, long steel probe (or similar)
            Alcohol and cotton tips for cleaning up after soldering
            1. Remove the back panel of the laptop and carefully remove the battery and motherboard
            a. Note: Take some photos to ensure you know where all of the connectors go before you start!
            2. On the underside of the motherboard identify the chip adjacent to the m/board labels U365 and U366. Make sure you identify pin 1 orientation of the chip onto the M/board (a small dot on chip above pin 1)
            a. Note: This is usually a Winbond 25Q256JVEN WSON8x6 chip with no legs
            b. This chip is the EC (Embedded Controller) chip and NOT the main bios chip found on the top of the board that is labelled U367 inside a white square. The U367 main bios chip does NOT need to be removed! You may find that the main bios chip is also a Winbond 25Q256JVEN, but with legs (SOP8).
            3. Using a hot air gun with a small nozzle, set temperature to 400C and test on scrap 0.7mm solder to ensure it is hot enough to melt solder quickly. Don’t exceed 420C if you need to go higher and the keep air flow to a low / medium rate
            4. Install the EZP2023+ chip reader/programmer software and driver on another Windows PC
            a. I found it easier to install the driver in Device Manager
            5. Mount the removed EC chip onto WSON8x6 adaptor board (soldered) and insert board into EZP2023+ chip reader/programmer.
            a. You will need the 0.7mm solder and quality rosin solder flux.
            b. The magnifying device will be very helpful for all soldering and checking. Make sure you don’t have any bridging solder pads!
            c. Note: The adaptor board should be mounted closest to the lever handle with the solder mounted chip on left side (closest to the power light)
            d. This is important otherwise you can cook the chip!
            6. Plug-in the EZP2023+ hardware unit via USB connector, open the software and press the ‘Test’ button. The EC chip should be instantly recognised, if not check your soldering!
            7. Once the chip has been recognised press the ‘Read’ button.
            a. Note: You will need to read the chip at least 3 times. Save each .BIN file with a different name. (3 separate back-ups)
            8. Open HxD (Hex editor software) and load the first two .BIN files.
            9. Use the Compare tool (Analysis >Data Comparison>Compare) to ensure that both files are exactly the same.
            a. Note: If all three .BIN files are not exactly the same, keep re-reading the chip and saving until you get identical files, this is important.
            10. Do the same with the third file, comparing with the first etc.
            11. If all files are identical move to the next step.
            12. In Hxd, search for NvramActiveRegn, usually at line 37000 in your .BIN file
            13. Using the edit tool, select all data from line 37000 to 37380 (or sometimes a bit further down, select all of the data in this block) and fill with no data (FF)
            a. Note: This is the area of data where the bios password is stored.
            14. Save this file as your new .BIN file (with no password)
            15. Using the EZP2023+ software Erase the contents of the chip.
            a. Note: Set the Fill function to Word (16bits) FFFF before you start erasing.
            16. After erasing read the contents of the chip and check that it is completely empty (all FFs), if it is not empty run erase again. Once the chip is empty of data it is then ready for the new .BIN file (you can check file in HxD to ensure there is only FFs from top to bottom).
            17. In the EZP2013+ software Open the new .BIN file with no password and then select Write.
            18. Once the writing to the chip is complete read the contents of the chip and once again compare with new .BIN file using the HxD (Hex editor), ensuring that the files match exactly!
            19. If the files match exactly, de-solder the chip from the adaptor and re-mount onto the motherboard using a hot-air gun set at 420c.
            a. Note: Be careful to have very little solder on the central pad under the chip otherwise getting it to melt is difficult
            b. Pre-fill the pads of the m/board and chip with a tiny amount of fresh solder before you attempt to join the two with solder. Apply a generous amount of flux and gently hold the chip in place with a long blunt tipped metal probe (make sure this is not too large as it will siphon heat away from the chip and hinder soldering)
            c. Use the white position lines on the motherboard to assist with chip alignment.
            d. Once the chip is fixed, apply more flux and gently and quickly run a small soldering iron along each side of the visible pads (4 each side) to smooth the pad mounds.
            e. Check that there is no bridging between the pads (excess solder).
            f. Clean the work area with alcohol on cotton tips or small brush
            20. This process requires some reasonable soldering skills and practicing on an old motherboard can help to develop the required skills.
            • sh4rp
              • Apr 2021
              • 8
              • Slovensko
              #66
              Works like a charm! Thanks alot!
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #67
                You're welcome. You had to wait a really long time to solve the problem, but at the end your patience was rewarded. Have fun!
                • airblade
                  • Jan 2019
                  • 58
                  • Home
                  #68
                  need unlock 845 g7 please, 2nd bios
                  • airblade
                    • Jan 2019
                    • 58
                    • Home
                    #69
                    already unlocked but error on startup.. how can i remove this?
                    thanks
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12422
                      #70
                      thanks
                      Read and repost both bios and EC chips here.
                      • airblade
                        • Jan 2019
                        • 58
                        • Home
                        #71
                        here sir
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12422
                          #72
                          here sir
                          HP EliteBook 845 G7 Notebook PC (8VZ06AV)
                          • airblade
                            • Jan 2019
                            • 58
                            • Home
                            #73
                            working 100% thank you
                            • dhan
                              • Jun 2018
                              • 134
                              • hp
                              #74
                              hello..
                              asking help again.
                              I have this now.
                              but the problem is the firmware is already erased.
                              it does not boot anymore.
                              I tried to use other bin file from this thread.
                              it does not help.
                              still does not boot.
                              please help
                              thank you
                              • ricka2021
                                • Jan 2021
                                • 26
                                • usa
                                #75
                                Hi everone,
                                I have HP EliteBook 845G7 bios locked and mdm.
                                Can someone please help me clear it?
                                I attached both upper and lower bios dump files.
                                Thank you
                                • mbreges
                                  • Nov 2017
                                  • 4
                                  • Russia
                                  #76
                                  Hello!
                                  Could anyone help me to remove the bios password from these bin files, please?
                                  Thanks in advance
                                  • hardware1
                                    • Sep 2021
                                    • 2949
                                    • N/A
                                    #77
                                    Originally posted by mbreges
                                    Hello!
                                    Thanks in advance
                                    Here's your Unlocked Bios, Program the both chips together.
                                    In the first boot go to BIOS Menu and disable security options (Default).
                                    all donations are welcome,
                                    • Svyatpro
                                      • May 2016
                                      • 12
                                      • Ukraine
                                      #78
                                      Hello folks! Can anyone help me unlocking my BIOS for 845 G7?
                                      Here are both dump roms.
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12422
                                        #79
                                        Unlocked
                                        • kpassako
                                          • 9
                                          • ivory coast
                                          #80
                                          Re: HP BIOS unlock tool
                                          can someone help me with this ?
                                          elitebook 845 G7
                                          THANKS
                                          • STKR123
                                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                            by STKR123
                                            Greetings badcaps community,
                                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                            I learned that desoldering...
                                            10-29-2024, 06:03 AM
                                          • Wutru
                                            HP Elitebook 820 G4 BIOS repair assistance required
                                            by Wutru
                                            Hi guys,
                                            If someone would be able to provide some expertise, I'd be very grateful.
                                            BIOS Corruption - Cause
                                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                            09-06-2025, 10:32 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • jotati7062
                                            Hp Elitebook 860 G10 Admin/bios Pass
                                            by jotati7062
                                            Hello guys, I saw your posts of "hoaca388" on this fourm helping others which is very nice of him,
                                            i do have an HP 860 G10 LOCKED, i looked at the bytes he change after an unlock and applied the same on my bios file but i get error that "bios was recovered from EC chip due to data mismatch, do you guys think you can help? if so here is my main bios backup, if i have to backup EC chip, i will, Thank you so much...
                                            08-13-2025, 04:33 AM
                                          • zlr8r
                                            looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                            by zlr8r
                                            looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                            cheers
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                            Attached;
                                            1. My saved bios using a programmer
                                            2. Dells Bios updater .exe (v1.16)
                                            3. Dells Bios recovery file
                                            4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                            5. Image of ME...
                                            12-18-2023, 03:08 PM
