Lenovo bios V330-15IKB
Hello ! I need BIOS for my Lenovo V330-15IKB please. Details are :- Lenovo V330 - 15IKB
- Model Name : 81AX
- S/N : R90QBX1V
- MTM : 81AX00ARUK
- MO : R9N0B832301K
- Motherboard : LV315KB MB
- Motherboard : 17807-3
- Motherboard : 448.0DC05.0031
Attached Filesif you find these attachements useful please consider making a small donation to the site
V330-15IKB Laptop (Lenovo) - Type 81AX
https://www.badcaps.net/donateComment
Thanks. For the record, my laptop still doesn't work. The Power and Caps Lock lights are solid on, the CPU fan gradually reaches full speed, and the main power line is at 8.7V without the battery. I wanted to rule out the possibility that it's a BIOS issue.Comment
Hello good people, i need help clearing the bios pass from this dump thanks in advanced <3Attached Filesif you find these attachements useful please consider making a small donation to the site
post S/N, full name and model, motherboard model, TYPE,etc.
read the forum rules..
https://www.badcaps.net/forum/troubl...ore-posting
Every donation made will go towards server fees and maintenance costs.Comment
Lenovo V330-15IKB
Model Name: 81AX
Mfg Date: 19/03/28
S/N: R90TNC2V
MTM: 81AX001BAK
I was able to fix my bios with using a clean bios from here https://www.badcaps.net/forum/troubl...30-15ikb/page5 annd then moving the DMI region to the new.bin file i'll attach it just in case some1 needs it
and thank u peste for pointing out the missing requirments i think the post needs to be merged too again sorry for that
Hi. Can you please fix bios for :
Lenovo v330-15IKB
Type model :81AX
SERIAL : R90SH3Q9
MTM:81AX000DAR
MO;R9N0B8B26018
Hello friends, recently I have read the post flashed some rom, but none has worked for me because of the issue of the slow start of ignition, because it takes 25 seconds, the installed firm does not have a serial number or anything, even if I install some other firm when starting the bios no serial number or model appears in the info of the bios, for this I attach the bios in question, I have tried to edit but I have stayed in the attempt, for this due to your mastery I request your consideration and help and I request a new bios, greetings from Argentina.
Thank You.Attached Filesif you find these attachements useful please consider making a small donation to the site
try post #2,30...Hi. Can you please fix bios for :
Lenovo v330-15IKB
Type model :81AX
SERIAL : R90SH3Q9
MTM:81AX000DAR
MO;R9N0B8B26018
Thank You.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hi, could you fix this BIOS for me? I have a black screen.
Lenovo V330-15IKB
MODEL: 81AX
SERIES: R90SET0FAttached Filesif you find these attachements useful please consider making a small donation to the site
Bios + DMI. Your model 81AX000GAR shipped with no OS .https://psref.lenovo.com/Detail/Leno...B?M=81AX000GARAttached Filesif you find these attachements useful please consider making a small donation to the site
Thanks for the BIOS, but I'm having the same problem. All the coils are properly powered. Do you have another BIOS?
Bios + DMI. Your model 81AX000GAR shipped with no OS .https://psref.lenovo.com/Detail/Leno...B?M=81AX000GARComment
The one i posted is a virgin bios plus your DMI. There are many other working bios versions in this thread. Attach everything to motherboard, daughter bioards,if any , everything apart from the screen. Check via HDMI. It could be a hardware proble, maybe the soldered ram. You can try disabling the ram yourself - https://www.badcaps.net/forum/troubl...20#post3232220Comment
Indeed, there is a problem with the Omboar RAM, I disabled it and it started working normally, thank you very much
Hello Masters. can you fix this bios? laptop turns on with capslock on but blackscreen only.
Lenovo V330-15IBK
SN: R90SAC3K
This file works for me. Only need put my DMI info ( DMI 201000 - 2011FF ).
This BIOS have ME version 11.8.50.3399, updated successful to 11.8.86.3877 with package from Lenovo.
Thanks!Comment
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by gestalt.exeHi everyone,
My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
Laptop stopped booting entirely.
I used a CH341A programmer to dump the corrupted 16MB BIOS.
i then attempted the following:- Downloaded stock BIOS BHCN39WW from Lenovo
- Trimmed it to 16MB
- Extracted the BIOS region from the corrupted dump
- Extracted the BIOS region from the stock 39WW
- Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
- Injected back my LDGB / DMI
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
- Loading...
