Lenovo bios V330-15IKB
  • hoaca388
    Badcaps
    • Jan 2022
    • 12526
    #61
    Re: Lenovo bios V330-15IKB
    Originally posted by YellowJacket
    So do you mean, that firmware, which linked hoaca388, should work, right?
    That's right. Your computer has a hardware error.
    • YellowJacket
      • Dec 2020
      • 107
      • Slovakia
      #62
      Thank you
      • gigasi
        • 98
        • Argentina
        #63
        Hello, I have a lenovo v330-15ikb, I have tried several bios but it takes a while to turn on and then turns off after being on. I leave the old bios in case anyone has a solution. thank you so much.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12526
          #64
          Originally posted by gigasi
          hello, i have a lenovo v330-15ikb, i have tried several bios but it takes a while to turn on and then turns off after being on. I leave the old bios in case anyone has a solution. Thank you so much.
          vvvvvv
          • gigasi
            gigasi commented
            Editing a comment
            Works Fine!
        • yvzasl
          • Feb 2022
          • 16
          • Türkiye
          #65
          https://www.badcaps.net/forum/showth...ios+V330-15IKB
          thank you, it works smoothly
          • fredo
            • Aug 2016
            • 84
            • syria
            #66
            Lenovo v330-15ikb
            s n: R90syee2
            17807-3m
            model 81ax
            There is no image, please help
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #67
              Originally posted by fredo
              Lenovo v330-15ikb
              s n: R90syee2
              17807-3m
              model 81ax
              Use the bios attached at post 69, transfer DMI data from your bios - offsets are shown in post 51.
              Become a Badcaps supporter
              Thanks to all supporters.
              • hoaca388
                Badcaps
                • Jan 2022
                • 12526
                #68
                Lenovo v330-15ikb
                s n: R90syee2
                17807-3m
                model 81ax
                CCCCC
                • HaDRFakrrr
                  • Mar 2024
                  • Česko
                  #69
                  Hello, help me with Lenovo V330-15IKB 81AX bios dump please🙏after update bad display, fan spin, and caps lock on. In attached files is original BIOS backup.
                  Thank you very much for any help.
                  Full machine model number LENOVO V330-15IKB 81AX
                  MTM 81AX00SWCK
                  Serial number R90T6HPJ
                  UUID Number ED735400-89F3-43A2-A7C2-FC9192965677
                  BIOS Version 6SCN54WW
                  EC Version 6SEC21WW
                  MO R9N0B922000F​
                  • peste
                    • 14052
                    • ROMANIA
                    #70
                    try post#29..
                    • HaDRFakrrr
                      • Mar 2024
                      • Česko
                      #71
                      thank you peste. I try BIOS from post#29 and problems are unfortunately same
                      • Martin Vavera
                        • Mar 2024
                        • 5
                        • Czechia
                        #72
                        Hello, i have Lenovo V330-15IKB
                        Product name
                        Lenovo V330-15IKB
                        EC version 6SEC21WW
                        MTM 81AX00SWCK
                        sn: R90SH1C1
                        My laptop only sees the original 128GB SSD in the M.2 slot, it doesn't see any other SSD. Now I bought an SSD directly from Lonovo parts, with the fact that it was fitted to this model, but the ntb doesn't see it either. So I can't upgrade. Probably a bug in the FW
                        I tried factory reset bios. The disk is ok, other PCs can see it immediately. Any advice please?​
                        • peste
                          • 14052
                          • ROMANIA
                          #73
                          Product name
                          Lenovo V330-15IKB
                          EC version 6SEC21WW
                          MTM 81AX00SWCK
                          sn: R90SH1C1
                          Try post #29, don't forget to make a copy of the original bios before writing...next time post the bios here too, even if it's corrupted...
                          • Martin Vavera
                            • Mar 2024
                            • 5
                            • Czechia
                            #74
                            thank you i will try please, how to update and previous bios backup? Somehow I didn't read how to do it. Thank you for the advice.​
                            • Martin Vavera
                              • Mar 2024
                              • 5
                              • Czechia
                              #75
                              I have downloaded the bin file and it is on a USB flash drive, I found it in post 17, I assume that I have a USB at startup and press Fn+R - this is for upgrading, but I didn't find how to backup the bios first. I want to try it, I want a bigger disk. I have a disc that doesn't work for me, so I'd like to give it a try before I return it to the dealer. :-) Thanks
                              • peste
                                • 14052
                                • ROMANIA
                                #76
                                You need an SPI programmer.. watch a video here for information..
                                https://www.youtube.com/watch?v=DWWigscuQDY
                                • Martin Vavera
                                  • Mar 2024
                                  • 5
                                  • Czechia
                                  #77
                                  I watched the video, so I don't know, I probably won't give it. The chip must be desoldered, or it can be left on the board and connected with the terminals supplied with the programmer
                                  Thank you​
                                  • peste
                                    • 14052
                                    • ROMANIA
                                    #78
                                    Thank you​
                                    the chip must be desolder from the motherboard, and solder to the programmer, or soldered wires, between the chip and the programmer.. do not use the clip, you will have errors..
                                    • Martin Vavera
                                      • Mar 2024
                                      • 5
                                      • Czechia
                                      #79
                                      thank you very much for the advice. Unfortunately, I don't disconnect the chip and I haven't found anyone who can. So unfortunately I have to leave the laptop as it is :-(, I was hoping for some Fn+r boot method, but this is beyond my abilities. Thanks again.​
                                      • bouny56
                                        • Jan 2023
                                        • 68
                                        • france
                                        #80
                                        Hello can you help me with a clean Me for a lenovo v330-15ikb please?
                                        Slow boot
                                        Lenovo v330-15IKB
                                        Model : 81AX
                                        Sn : R90PLFK5
                                        thx
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • gestalt.exe
                                          Lenovo Legion Y540 – Need help repairing BIOS after bad downgrade
                                          by gestalt.exe
                                          My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
                                          Laptop stopped booting entirely.
                                          I used a CH341A programmer to dump the corrupted 16MB BIOS.
                                          i then attempted the following:
                                          1. Downloaded stock BIOS BHCN39WW from Lenovo
                                          2. Trimmed it to 16MB
                                          3. Extracted the BIOS region from the corrupted dump
                                          4. Extracted the BIOS region from the stock 39WW
                                          5. Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
                                          6. Injected back my LDGB / DMI
                                          11-30-2025, 10:38 AM
                                        • grimacelord
                                          by grimacelord
                                          Hello there.
                                          History:
                                          03-15-2023, 03:29 PM
                                        • to5it0
                                          by to5it0
                                          10-24-2025, 01:35 AM
