Lenovo Thinkpad T480 BIOS and EEPROM request
Pls help me to fix no boot/black screen(melody) on my T480 i7/mx150.
Type 20L6-S29D08 S/N: PF-1J954M
Few months ago it was purchased as dead. Some dump from here was helped but now its not booting just melody
Attached Filesif you find these attachements useful please consider making a small donation to the site
T480 Laptop (ThinkPad) - Type 20L6
https://www.badcaps.net/donateComment
How about this dump?
Test and provide feedback.Attached Filesif you find these attachements useful please consider making a small donation to the site
error 0001. Connected to board only wlan module and ram stick. Using original charger from T15 gen2.Comment
Has anyone tried shorting eeprom chip of t480 laptop.? i heard that on older models shorting just before bios setup removes bios pasword, like in this video https://www.youtube.com/watch?v=FW-RLkzjAS8Comment
https://www.badcaps.net/forum/troubl...-ec-pwd-bypassHas anyone tried shorting eeprom chip of t480 laptop.? i heard that on older models shorting just before bios setup removes bios pasword, like in this video https://www.youtube.com/watch?v=FW-RLkzjAS8Comment
T480
info from bios
M 20L6S38300
S/N PF-159HEV
M/B L1HF88t003h
intel i7 8th gen
please Help
i got a bricked T480 and got my self a ch341a and flash the bios that I have attached this did not work and after trying different .bin files I tried to flash heads this work and then after re-flashing with the attached bios it worked and have done a USB bios utility update which worked since then have done a full Lenovo Diagnostics which found nothing wrong. Though, I think the PCIe cable is broken. So I have tied to boot form USB and two things have happened when I used balenaetcher is says error file '/boot/' not found and when using Ventoy and using normal boot it most often it is just blank with a _ in the top left of the screen when using grub2 and don't select anything after a few seconds it goes to Ubuntu loading screen but nothing happens if you actively select you get a load of text that according to Google Lens means something about security_inode_alloc I have also had xz corrupted data come up once have i flashed the bios wrong or is it the TB 3 flashing that is coursing it. After pressing the ESC key when Ubuntu is stuck loading, this comes up
Thanks in advance
FAttached Filesif you find these attachements useful please consider making a small donation to the site
S-L-O-W boot times.
I recently acquired a ThinkPad T480 - Type 20L6-S0HG00, Build date: 18/05, S/N: PF17SPX4, Intel i7 - 8th generation with a locked / supervisor password protected BIOS. I successfully patched the BIOS using the autopatch instructions I found on here. BIG thanks to Knucklegrumble!
After patching and flashing, per the instructions I set BIOS settings to their default and then updated the old BIOS that it came installed with (dated 2018) to the newest 03.2025 BIOS from Lenovo's official site. I now experience unusually long boot times that take 19 seconds just to get to the red LENOVO logo and 68 seconds to get to the Linux Mint logon screen. This is with a NVMe SSD and 32GB RAM. I have read about cleaning the ME Region. Could this be the answer to the horribly long boot times?Comment
Hello! My Aliexpress-bought motherboard was very problematic when trying to get any stable Windows installation on it, so I tried updating the bios in case it was the culprit but the process failed miserably and now it just sings Error code 0285. Managed to read the Winbond 25Q128JVSQ chip by desoldering it (otherwise it would crash my CH341A) but I did it under the "25Q128JV" label that AsProgrammer lists, so I wonder if it's a valid bios dump even?
Model: T480
Bios Version(suspected to crash Windows?): N24ET49W (1.24 )
board No: ET480 NM-B501 (2018)
s/n: PF-1JGUWZ 18/12
System Board serial number: L1HF8CC01TT
Machine Type: 20L6-S3PV00
CPU: Intel Core i5-8350U
Requesting a working Bios to recover functionality of the machine, and also so I can confirm the old one crashed Windows or not.Attached Filesif you find these attachements useful please consider making a small donation to the site
T480 Laptop (ThinkPad) - Type 20L6Hello! My Aliexpress-bought motherboard was very problematic when trying to get any stable Windows installation on it, so I tried updating the bios in case it was the culprit but the process failed miserably and now it just sings Error code 0285. Managed to read the Winbond 25Q128JVSQ chip by desoldering it (otherwise it would crash my CH341A) but I did it under the "25Q128JV" label that AsProgrammer lists, so I wonder if it's a valid bios dump even?
Model: T480
...and how about this dump?
It had worked on 2-3 other laptops that i fixed...Attached Filesif you find these attachements useful please consider making a small donation to the site
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 03:21 PM
This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 02:34 PM
This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 02:28 PM
- Loading...
