Sorry for the late reply, I've been busy with some work. YES! This one worked!! 😁 But... Windows installations are as unstable as they were before the botched Bios update, and some Linux distros do install but it takes a lot of effort to make it happen. I believe this motherboard may be broken after all, but in such a weird way that I can't pinpoint exactly how, and sadly we can't refund it anymore. Still, thanks everyone involved for your time and support, I learned a lot from this!
Lenovo Thinkpad T480 BIOS and EEPROM request
I have a Lenovo T480 that is locked with an administrator password.
I tried Auto-Patcher, and while it worked perfectly on some computers, on this one, I only get beeping and a black screen. What am I doing wrong?
Lenovo T480
Board: L1HF89T0373
SN: PF1F28LPAttached Filesif you find these attachements useful please consider making a small donation to the site
HI IN LENOVO T480 HAS BIOS PASSWORD PLS HELP ME OUT
SN - PF-1MMQ2U
MODEL - T480 LENOVO
PN- SL10R03187
https://www.badcaps.net/donateComment
SMDFlea - Thank you for your help, but when I try that file, the BIOS remains locked.
For example, with the original BIOS, I can skip the login and enter the BIOS (of course, I can't change anything), but with this BIOS, I don't even have that option.
1 PhotoComment
That bios still needs patching
For example, with the original BIOS, I can skip the login and enter the BIOS (of course, I can't change anything), but with this BIOS, I don't even have that option.Comment
Honestly, I'm a little embarrassed that it didn't occur to me at all
But we are still learning, it will get better over time with fewer silly questions
Of course I managed to remove the password when I did the patch... And of course, now I have another problem, which is Autopilot. On a couple of computers, I successfully removed Autopilot by following the instructions from volinakis, but on this one I don't see that Autopilot exists at all, and yet when I install Windows 11, it's still tied to the company. I assume something else needs to be changed, but I don't know what exactly?
1 PhotoComment
Perhaps volinakis or maxpower3 or someone else can help with that, i`m not sure what to do
Of course I managed to remove the password when I did the patch... And of course, now I have another problem, which is Autopilot. On a couple of computers, I successfully removed Autopilot by following the instructions from volinakis, but on this one I don't see that Autopilot exists at all, and yet when I install Windows 11, it's still tied to the company. I assume something else needs to be changed, but I don't know what exactly?Comment
Please try this modded (1 byte diff) bios for autopilot disable...if it's not working then probably you need to rewrite the SIO chip.
Of course I managed to remove the password when I did the patch... And of course, now I have another problem, which is Autopilot. On a couple of computers, I successfully removed Autopilot by following the instructions from volinakis, but on this one I don't see that Autopilot exists at all, and yet when I install Windows 11, it's still tied to the company. I assume something else needs to be changed, but I don't know what exactly?Attached Filesif you find these attachements useful please consider making a small donation to the site
It actually works perfectly! Autopilot has been successfully removed.
Thanks for the help! I would be grateful if you could write down exactly what you changed, so I can try to do it myself in the future
I also want to thank SMDFlea for the selfless help! Well done, guys!
Hello, I bricked my bios when the spi flasher disconncted mid libreboot install. I've tried multiple bios files from this thread and changing the mac address etc but nothing works, the power button just blinks 3 times when connecting charger, any help with getting a working bios would be much appreciated.
Thinkpad T480 i7-8550u
Board: 20L5-CTO1WW
S/N: PF-1596D1
I lost the original dumps but these are the current ones on the board, let me know if more info is needed.
Thanks in advance
lenovo t450
serial no is not available on sticker
nm-b501
no display BLACK SCREEN...TURN OFF AFTER 30 SECOND
helpAttached Filesif you find these attachements useful please consider making a small donation to the site
This thread does not seem to be very active anymore but if any knowledgeable person ends up reading this even a simple attempt to point me in the right direction would make me eternally grateful.Hello, I bricked my bios when the spi flasher disconncted mid libreboot install. I've tried multiple bios files from this thread and changing the mac address etc but nothing works, the power button just blinks 3 times when connecting charger, any help with getting a working bios would be much appreciated.
Board: 20L5-CTO1WW
S/N: PF-1596D1
Thanks in advance
At this point I've tried a couple BIOSes posted in this thread and also extracting their bios region, replacing the mac address with the one i backed up before i bricked the computer (using hexedit) and stitching it to the BIOS region of my bios dump but nothing has worked. All i get is a black screen and the powerbutton blinks 3 times when i plug it in, but does not react to presses.
I'm completely out of ideas at this point so if anyone knows a potential fix or if there is further modification needed to the bios before flashing or something like that, Ill try anything at this point.
Wizards of badcaps.net I call upon thee
Did you try this dump ?
First read and backup your existing bios content as is the whole W25Q128JV chip content I mean...
Then write the file I have sent as is.
Your DMI info it's in EC so it should work as is.Comment
Unfortunately no result, i'll tell you exactly what I did.
1. removed external battery
2. open chassi
3. disconnected internal battery
4. connected ch341a spi flasher to W25Q128JV chip
5. read the chip using flashrom:
6. flashed the file you suggested using flashrom:Code:sudo flashrom -p ch341a_spi -c "W25Q128.V" -r backup.bin flashrom v1.5.1 on Linux 6.12.47 (x86_64) flashrom is free software, get the source code at https://flashrom.org Found Winbond flash chip "W25Q128.V" (16384 kB, SPI) on ch341a_spi. Reading flash... done.
Then i removed the spi flasher, reconnected internal battery, closed chassi, reconnected external battery and plugged in to power. Still black screen and power button flashes 3 times. No luck it seems. Unfortunately i lost the original BIOS dumps from before bricking the system so the ones i uploaded in my first post never worked and might contain wrong data. May I ask, what is the DMI info? I'm not familiar with the term. A shot in the dark but could the issue have something to do with the other SOIC8 chip containing the thunderbolt firmware maby?Code:sudo flashrom -p ch341a_spi -c "W25Q128.V" -w Lenovo_T480_ME_Clean.bin flashrom v1.5.1 on Linux 6.12.47 (x86_64) flashrom is free software, get the source code at https://flashrom.org Found Winbond flash chip "W25Q128.V" (16384 kB, SPI) on ch341a_spi. Reading old flash chip contents... done. Updating flash chip contents... Erase/write done from 0 to ffffff Verifying flash... VERIFIED.
(The file i upload is the dump from reading the chip at step 5)Attached Filesif you find these attachements useful please consider making a small donation to the site
The Desktop Management Interface (DMI) is a standard industry framework for managing and tracking components in a laptop/PC and it contains all sort of data about the hardware like laptop serial number, main-board serial number, model number, etc and the computer boots, but with a lot of errors if this data is missing or is incomplete...
2. open chassi
You did everything ok...I think...I'm not a Linux fan...but I see there are no errors on read/write.
What I can suggest is to try more dumps (attached) .
This dumps worked on other T480 hardware....we don't know exactly what's yours because of the bricked backup.
Good luck!
Yes the write seems to working at least (if i can trust flashrom hehe), so I'll keep trying dumps like you said. Ugh I feel so stupid that I overwrote the original backups but thank you very much for trying to help, I feel more hopeful now knowing it is most likely just about finding the right bios dump for my hardware. Cheers!
Good luck!Comment
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 03:21 PM
This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 02:34 PM
This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 02:28 PM
- Loading...
