Need unlock HP ProBook 640 G5 8TH
https://www.badcaps.net/donate -
hi tryAttached FilesComment
So after trying some files from members here that never worked i tried some others which sort off worked but since mine was touch screen the other bios dumps did not work. So i spend a couple of days trying diffrent things and the final answer i can give for my specific model (IDS Base Model) was to use both rcunlocker and HPunlocker. HPunlocker on the 32mb chip and for some reason had to use both rcunlocker and hpunlocker on the 16mb chip. (seems each unlocker removed a diffrent part of the nvram section). No need to FFFF the UUID ( thou i would recomend this if someone wants to use HPS BCU to match numbeers on diffrent casings and so on)Comment
good morning, unlock this bios please
HP 640 G5
SN: 5CG84231ZT
Try to unlock it yourself with RCUnlocker - https://www.badcaps.net/forum/troubl...23#post1622423Comment
Every donation made will go towards server fees and maintenance costs.Comment
Channel: BIOS Requests ONLY!
by studdy05Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
Ive got...07-08-2025, 09:24 PM -
by macabookHello everyone,
07-24-2025, 02:17 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
- Loading...
