Need unlock HP ProBook 640 G5 8TH
hp probook 640 g5
s/n: 2TK02200KN
motherboard model: 6050A2930101-MB-A01(A1)
prodID: 18J48UC*ABA
no disp and fan speed spinning up
thank you advencAttached FilesPremium supporters get full download access and other benefits.
Hello
please help me with 640 g5 working bios file repair
board :6050A3028601-MB-A01
SN:5CG0180990
computer power light keeps blinking . no start up.
backup attached
Hp 640 g5 , i found no power. another engineer erase main bios and ec bios. when i insert this 2 bios display is open. but show message ( hp endpoint security controller problem), When i press ok then restart and again show this message. i tried to insert to bios program by F10 but can't. please solve my problem as soon as possible. please.
product id 6XE24EA#ABU
SN- 5CG9265N00Attached FilesPremium supporters get full download access and other benefits.
hi tryHp 640 g5 , i found no power. another engineer erase main bios and ec bios. when i insert this 2 bios display is open. but show message ( hp endpoint security controller problem), When i press ok then restart and again show this message. i tried to insert to bios program by F10 but can't. please solve my problem as soon as possible. please.
HP ProBook 640 G5 Notebook PCI tried but no display. shiyab. please solve my problem
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
Hi, could some one, please, clean ME?
HP ProBook 640 G5
S/N 5CG0377X5R
ProdID - 7KP75ET#ABU
BuildID - 19WWCODT601#SABU#DABU
Thank you.Attached FilesPremium supporters get full download access and other benefits.
hi;
need unlock bios HP ProBook 640 G5
6050a3028601 mb a01 a1
SN - 5CG014BTC0
ProdID- 7DA75AV
thank you
bios file attatchedAttached FilesPremium supporters get full download access and other benefits.
Please, someone can help me with a BIN BIOS file to fix the below notebook? (This unit have issue in the BIOS, I tried to use from other unit, but not worked because the ME is not clear and show EndPoint error).
HP Probook 640 G5
Serial: BRJ104GXIF
Part:3IL11LP
I apreciatte if someone could share the BIN BIOS files that Works in my unit.
Best Regards,
post the contents of the bios chip even if it is corrupted..Hello,
HP Probook 640 G5
Serial: BRJ104GXIF
Part:3IL11LP
Best Regards,
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
Hello, Peste
Sorry but I erase the chips and not salved the bin because the unit not power more after BIOS update. (As have some bios here that could fix I erase the chips and already appied these bios that a download from attached link. Now the unit power on fine, but have Endpoint controller error....)
I really apreciate if have some good bios that I can fix this unit.
Best Regards,
VilmarComment
try..
Hello, Peste
Best Regards,
Vilmar
https://www.badcaps.net/forum/troubl...er#post3310855If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
Channel: BIOS Requests ONLY!
by studdy05Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
Ive got...07-08-2025, 09:24 PM -
by macabookHello everyone,
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
- Loading...
