Need unlock HP ProBook 640 G5 8TH
  • hoaca388
    Badcaps
    • Jan 2022
    • 11738
    #121
    Originally posted by Negoti8
    HP pro book 640 G5 Touch
    SN# 5CG94201CP
    PRODID 5EG72AV
    mobo 6050A3028601-MB-A01
    Can someone please help to clear bios password. 16mb and 32mb chip uploaded.
    Unlocked.
    • Negoti8
      • Aug 2023
      • 26
      • United Kingdom
      #122
      Originally posted by shiyab
      hi try
      password still present
      • Negoti8
        • Aug 2023
        • 26
        • United Kingdom
        #123
        Originally posted by hoaca388
        Unlocked.
        file exactly the same as shiyabs but password still present
        • shiyab
          • Sep 2023
          • 1476
          • india
          #124
          post password phothos
          • Negoti8
            • Aug 2023
            • 26
            • United Kingdom
            #125
            Photo attached
            • shiyab
              • Sep 2023
              • 1476
              • india
              #126
              Photo attached
              hi flash both
              • Negoti8
                • Aug 2023
                • 26
                • United Kingdom
                #127
                hi flash both
                asking for password for zip file
                • shiyab
                  • Sep 2023
                  • 1476
                  • india
                  #128
                  hi try
                  • Negoti8
                    • Aug 2023
                    • 26
                    • United Kingdom
                    #129
                    hi try
                    will flash and let you know, does this contain firmware for touch screen as a few dont
                    • Negoti8
                      • Aug 2023
                      • 26
                      • United Kingdom
                      #130
                      hi flash both
                      Stuck at this and then just keeps boot looping
                      • Negoti8
                        • Aug 2023
                        • 26
                        • United Kingdom
                        #131
                        SN# 5CG94201CP
                        PRODID 5EG72AV
                        Please can someone help me extract the MPM info from this bios.
                        • Negoti8
                          • Aug 2023
                          • 26
                          • United Kingdom
                          #132
                          SN# 5CG94201CP
                          PRODID 5EG72AV
                          Update!
                          So after trying some files from members here that never worked i tried some others which sort off worked but since mine was touch screen the other bios dumps did not work. So i spend a couple of days trying diffrent things and the final answer i can give for my specific model (IDS Base Model) was to use both rcunlocker and HPunlocker. HPunlocker on the 32mb chip and for some reason had to use both rcunlocker and hpunlocker on the 16mb chip. (seems each unlocker removed a diffrent part of the nvram section). No need to FFFF the UUID ( thou i would recomend this if someone wants to use HPS BCU to match numbeers on diffrent casings and so on)
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • studdy05
                            Bricked HP Probook 450 G7 Bios questions
                            by studdy05
                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                            Ive got...
                            07-08-2025, 09:24 PM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • Dihpez
                            Need Bios unlock for HP Probook 450 G7
                            by Dihpez
                            Greeting,
                            I would like the bios unlocked and absolute presistance disabled/removed.
                            Thanks upfront for your time....
                            07-29-2025, 07:53 PM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
