Need Bios for Asus X409UB rev 2.0
  • peste
    • Dec 2016
    • 13430
    • ROMANIA
    Originally posted by rafniox0059
    Hey guys! I have asus X409UB rev 2.0 with no display, fan not spinning but the cpu is getting hot. Can someone have good bios on this kind of model. I also attached back up bios I extracted from bios chip.
    try post#3
    • SmartServiceX
      • May 2021
      • Chile
      Hi everyone. Could someone help me with this password protected BIOS?
      I have tried other dumps and it has problems with the keyboard and fan spining very fast
      I also tried the EC dump and the keyboard problem still exists
      If someone could remove the password from this file I would appreciate it​
      • volinakis
        • Jan 2021
        • 2872
        • N/A
        serial number? Read the rules of this forum.
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • lrouw84
          by lrouw84
          Hi there,
          01-28-2023, 01:31 PM
        • ferah831208
          help with bios decompose for Asus s5506ma
          by ferah831208
          I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
          08-24-2025, 05:35 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
