I also attached the old Bios
Need Bios for Asus X409UB rev 2.0
Re: Need Bios for Asus X409UB rev 2.0
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
tryAttached FilesComment
Asus x409ua orig bios from laptop;;;Attached FilesComment
x409ub rev 2.0 kbc bios
motherboard x409ub rev 2.0 kbc bios
safe code x509u
The keyboard is not working properly. I would appreciate it if KBC and BIOS could share what they have.Comment
Re: x409ub rev 2.0 kbc bios
You MUST:- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
.Comment
try this and post#3..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hey guys! I have asus X409UB rev 2.0 with no display, fan not spinning but the cpu is getting hot. Can someone have good bios on this kind of model. I also attached back up bios I extracted from bios chip.Attached FilesComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by lrouw84Hi there,
I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....-
by ferah831208I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
by DynaxSCHi,
Usually on ASUS boards it worked...-
- Loading...
