Medion MD99090/E6234 need bios 5.06 dump
  • regi
    • Jan 2020
    • 26
    • germany
    it has:
    BIOS Version 503
    VBIOS Version 2130.1I220910.01
    i have the latest bios 5.06 exe but it won´t install as i have no battery for it
    • 20795
    Re: Medion MD99090/E6234 need bios 5.06 dump
    Post your bios backup,and a link to the 5.06 exe
    • regi
      • Jan 2020
      • 26
      • germany
      here the bios link:
      http://cdn.medion.com/downloads/treiber/bioe6234_w8.exe
      here the dump of the 5.03 bios:
        • 20795
        Originally posted by regi
        here the bios link:
        Your backup is mostly empty.Make another one.What programmer are you using
        • regi
          • Jan 2020
          • 26
          • germany
          first of all thank you for your help
          i used a ch341a programmer, i made a new dump
            • 20795
            Try this . Bios version 5.06 merged,extracted from the exe ,and clean ME region.
            • regi
              • Jan 2020
              • 26
              • germany
              doesn´t work, laptop won´t start any more.
              after programming i did a verify, just to be sure.
              bios battery was/is still out.
              power button has 3,3v
              shall i flash the old bios back?
                • 20795
                yes flash the old one back and see if it boots.Your last bios backup had a corrupt ME firmware.There could have been some other corruption in your backup. Are you using a clip or did you desolder the bios.
                • regi
                  • Jan 2020
                  • 26
                  • germany
                  i first used the clip, after you said there was a lot missing i solderd the chip from the board.
                  keyboard is not working with 5.03 and it switches off after 30 minutes, that´s why i wanted to update.
                  i am soldering again...
                  • regi
                    • Jan 2020
                    • 26
                    • germany
                    it starts with the old 5.03 bios
                      • 20795
                      ok ,try these 2 .
                      • regi
                        • Jan 2020
                        • 26
                        • germany
                        sucess
                        i took the first one, bios506new ME CLEAN
                        worked straight away, thank you so much
                          • 20795
                          sucess
                          You`re welcome
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
                          • MDSI
                            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                            by MDSI
                            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                            Details:
                            Model : HP OMEN 17-an012nf
                            Motherboard Part Number : DAG3BAMBAF0 REV : F
                            Serial Number (S/N) : 5CD7280D51
                            BIOS chip : Winbond W25Q64VSIQ
                            Programmer : EZP2023+
                            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                            I already...
                            Yesterday, 07:11 AM
                          • DynaxSC
                            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                            by DynaxSC
                            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                            11-06-2022, 05:22 PM
                          • TacticalFahrrad
                            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                            by TacticalFahrrad
                            I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                            BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                            06-30-2025, 04:09 AM
