Medion MD99090/E6234 need bios 5.06 dump
    it has:
    BIOS Version 503
    VBIOS Version 2130.1I220910.01
    i have the latest bios 5.06 exe but it won´t install as i have no battery for it
    Re: Medion MD99090/E6234 need bios 5.06 dump
    Post your bios backup,and a link to the 5.06 exe
      here the bios link:
      http://cdn.medion.com/downloads/treiber/bioe6234_w8.exe
      here the dump of the 5.03 bios:
        Originally posted by regi View Post
        here the bios link:
        Your backup is mostly empty.Make another one.What programmer are you using
          first of all thank you for your help
          i used a ch341a programmer, i made a new dump
            Try this . Bios version 5.06 merged,extracted from the exe ,and clean ME region.
              doesn´t work, laptop won´t start any more.
              after programming i did a verify, just to be sure.
              bios battery was/is still out.
              power button has 3,3v
              shall i flash the old bios back?
                yes flash the old one back and see if it boots.Your last bios backup had a corrupt ME firmware.There could have been some other corruption in your backup. Are you using a clip or did you desolder the bios.
                  i first used the clip, after you said there was a lot missing i solderd the chip from the board.
                  keyboard is not working with 5.03 and it switches off after 30 minutes, that´s why i wanted to update.
                  i am soldering again...
                    it starts with the old 5.03 bios
                      ok ,try these 2 .
                        sucess
                        i took the first one, bios506new ME CLEAN
                        worked straight away, thank you so much
                          sucess
                          You`re welcome
