Medion MD99090/E6234 need bios 5.06 dump
  • regi
    • Jan 2020
    • 26
    • germany
    it has:
    BIOS Version 503
    VBIOS Version 2130.1I220910.01
    i have the latest bios 5.06 exe but it won´t install as i have no battery for it
    • 22286
    Re: Medion MD99090/E6234 need bios 5.06 dump
    Post your bios backup,and a link to the 5.06 exe
    • regi
      • Jan 2020
      • 26
      • germany
      here the bios link:
      http://cdn.medion.com/downloads/treiber/bioe6234_w8.exe
      here the dump of the 5.03 bios:
        • 22286
        Originally posted by regi
        here the bios link:
        Your backup is mostly empty.Make another one.What programmer are you using
        • regi
          • Jan 2020
          • 26
          • germany
          first of all thank you for your help
          i used a ch341a programmer, i made a new dump
            • 22286
            Try this . Bios version 5.06 merged,extracted from the exe ,and clean ME region.
            • regi
              • Jan 2020
              • 26
              • germany
              doesn´t work, laptop won´t start any more.
              after programming i did a verify, just to be sure.
              bios battery was/is still out.
              power button has 3,3v
              shall i flash the old bios back?
                • 22286
                yes flash the old one back and see if it boots.Your last bios backup had a corrupt ME firmware.There could have been some other corruption in your backup. Are you using a clip or did you desolder the bios.
                • regi
                  • Jan 2020
                  • 26
                  • germany
                  i first used the clip, after you said there was a lot missing i solderd the chip from the board.
                  keyboard is not working with 5.03 and it switches off after 30 minutes, that´s why i wanted to update.
                  i am soldering again...
                  • regi
                    • Jan 2020
                    • 26
                    • germany
                    it starts with the old 5.03 bios
                      • 22286
                      ok ,try these 2 .
                      • regi
                        • Jan 2020
                        • 26
                        • germany
                        sucess
                        i took the first one, bios506new ME CLEAN
                        worked straight away, thank you so much
                          • 22286
                          sucess
                          You`re welcome
                          • mkdj
                            by mkdj
                            Dear all,
                            10-19-2025, 04:41 AM
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • haitham sharabati
                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                            by haitham sharabati
                            Hello engineers 😀,
                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                            🔧 Device Info:
                            - Model: HP 15-da2007ne
                            - Product Number: 8XF55EA#ABV
                            - Serial Number: CND0338P0D
                            - CPU: Intel Celeron N4000
                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                            💀 Problem:😅
                            - Device shows “Administrator Password”...
                            08-07-2025, 04:54 AM
                          • Citymin
                            by Citymin
                            S/N : 5RNK9FFT70...
                            08-05-2025, 05:12 AM
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
