LENOVO T490 (ft490/ft492/ft590/fp531 nm-b901 rev 1.0)
  • peste
    • Dec 2016
    • 12742
    • ROMANIA
    Originally posted by ktvdung89@gmail.com
    hello friend
    i need help bios lenovo P53s
    serial number:PF-1RLNEX
    type number: 20N6-001UUS​
    post full name and model, motherboard model, etc.
    • ifaztech1
      • Feb 2025
      • srilanka
      I have also problem with BIOS (power LED blinks 3 times, laptop does not turn on).
      Lenovo T490, Type 20N3-S70A00, SN PF-26DD3V 20/03, motherboard NM-B901 rev 1.0
      BIOS is in attachement.
      Can anyone help me?​
        SMDFlea commented
        Editing a comment
        try post 15
    • kingkong computers
      • Sep 2018
      • 188
      • pakistan
      no power on my laptop on this bios
      lenovo thinkpad t490
      nm-b901
      type 20n3-s88u0f
      s/n pf-1x8pfj 20/01
      another bios work ok but sound not working
      • hoaca388
        Badcaps
        • Jan 2022
        • 11709
        nm-b901
        type 20n3-s88u0f
        s/n pf-1x8pfj 20/01
        Here
          • Sep 2018
          • 188
          • pakistan
          Originally posted by hoaca388
          Here
          thankyou so much dear
          • Robin21
            LENOVO T490 High quality photo of CPU area needed
            by Robin21
            Does anyone have a motherboard from the Lenovo T490 model FT490/FT492/FT590/FT531 NM-B901 and could take a picture of the CPU area, including all the components around it? I would be very grateful.
            During the CPU replacement process, I messed up all the resistors and capacitors, and now I can't get it to work again. The motherboard was powering up before, but now it doesn't, even with the newly installed CPU. All voltages are okay, and I don't have any shorts, so I'm assuming I'm missing one of the resistors.
            I've also followed the schematic and Broadview,...
            09-25-2024, 06:55 AM
          • huzo
            LENOVO T590 not turning on
            by huzo
            The board is:
            FT490/ FT492/FT590/FT591 NM-B901
            So when i press the power button, the keyboard , the power button, caps lock, numlock lights up for a second, fan spins , and it turns back off, that's it ...
            Ok, so i opened it, i have 3.3V,5V,1.05V when charger or battery is connected, when i press power button, i get all the voltages on all the coils for a second, except VCCGFXCORE_I , if i read the schematics correctly there should be 1.2V,i don't know if this is or isn't important,because i don't know the sequence and is it a condition for...
            07-06-2023, 09:27 AM
          • huzo
            Lenovo T590 bios
            by huzo
            hello guys, can someone check the dump?
            when power button is pressed, the keyboard and caps and power button went on for a second, and then died... then i tried flashing dumps i found, and now only gives 3 power light flashes when charger connected... i even restored original dump, and it only lights up power button 3 times....no keyboard light or caps or anything...
            the chip is 25Q256JVEQ, 3.3V
            the board is FT490/ FT492/FT590/FT591 NM-B901
            the original dump is in the attachment...
            07-04-2023, 02:54 PM
          • jeffl1980
            Unable to repair damaged PCB on Lenovo T590
            by jeffl1980
            Lenovo T590
            Model 20N5S0W300
            SN PF1BXUWM
            Mobo FP531
            In a poorly executed attempt to re-program BIOS, I believe I knocked off SMD resistors near the BIOS chip (MACRONIX MX25L25673G) pins 1, 2 and 5. Since the resistors were low values, I attempted to make the repairs using solder blobs. I am inexperienced and the workmanship is admittedly poor. I programmed the BIOS chip with the initial firmware read I performed. In other words, I believe the BIOS firmware currently matches what it was prior to any work I performed.
            Here are my current observations.
            • Board
            01-23-2025, 11:46 AM
          • rkawa
            Benq fp531 monitor q5t3
            by rkawa
            hi all! Greetings!
            1 .- I do not ON, nor led stanby.
            Check in tl1451acn ic751
            no voltage pin 5
            pin 10 is 14 volts ...
            any information on this
            I would appreciate each other, help...
            12-02-2010, 09:15 PM
