LENOVO T490 (ft490/ft492/ft590/fp531 nm-b901 rev 1.0)
  • peste
    • Dec 2016
    • 12859
    • ROMANIA
    Originally posted by ktvdung89@gmail.com
    hello friend
    i need help bios lenovo P53s
    serial number:PF-1RLNEX
    type number: 20N6-001UUS​
    post full name and model, motherboard model, etc.
    • ifaztech1
      • Feb 2025
      • srilanka
      I have also problem with BIOS (power LED blinks 3 times, laptop does not turn on).
      Lenovo T490, Type 20N3-S70A00, SN PF-26DD3V 20/03, motherboard NM-B901 rev 1.0
      BIOS is in attachement.
      Can anyone help me?​
        SMDFlea commented
        Editing a comment
        try post 15
    • kingkong computers
      • Sep 2018
      • 190
      • pakistan
      no power on my laptop on this bios
      lenovo thinkpad t490
      nm-b901
      type 20n3-s88u0f
      s/n pf-1x8pfj 20/01
      another bios work ok but sound not working
      • hoaca388
        Badcaps
        • Jan 2022
        • 11802
        nm-b901
        type 20n3-s88u0f
        s/n pf-1x8pfj 20/01
        Here
          • Sep 2018
          • 190
          • pakistan
          Originally posted by hoaca388
          Here
          thankyou so much dear
          • IsraLorandi
            • Mar 2021
            • 12
            • Brasil
            #26
            Good afternoon, I need help with my BIOS. From what I've seen, this laptop's BIOS has already been tweaked. It came on without any video, the Capslock, Numlock, and Wi-Fi LEDs blink, and it beeps a few times. I tested the BIOS from post 15 and the power LED blinks three times, but it doesn't do anything else. I'll send you the BIOS that came with the laptop.
            ThinkPad T490
            Model: 20N3
            S/N: PE05GWGQ
            MTM: 20N3SCBJ00
            Motherboard: FT490/FT492/FT590/FP531 NM-B901 REV1.0
            • Robin21
              LENOVO T490 High quality photo of CPU area needed
              by Robin21
              Does anyone have a motherboard from the Lenovo T490 model FT490/FT492/FT590/FT531 NM-B901 and could take a picture of the CPU area, including all the components around it? I would be very grateful.
              During the CPU replacement process, I messed up all the resistors and capacitors, and now I can't get it to work again. The motherboard was powering up before, but now it doesn't, even with the newly installed CPU. All voltages are okay, and I don't have any shorts, so I'm assuming I'm missing one of the resistors.
              I've also followed the schematic and Broadview,...
              09-25-2024, 06:55 AM
            • huzo
              LENOVO T590 not turning on
              by huzo
              The board is:
              FT490/ FT492/FT590/FT591 NM-B901
              So when i press the power button, the keyboard , the power button, caps lock, numlock lights up for a second, fan spins , and it turns back off, that's it ...
              Ok, so i opened it, i have 3.3V,5V,1.05V when charger or battery is connected, when i press power button, i get all the voltages on all the coils for a second, except VCCGFXCORE_I , if i read the schematics correctly there should be 1.2V,i don't know if this is or isn't important,because i don't know the sequence and is it a condition for...
              07-06-2023, 09:27 AM
            • huzo
              Lenovo T590 bios
              by huzo
              hello guys, can someone check the dump?
              when power button is pressed, the keyboard and caps and power button went on for a second, and then died... then i tried flashing dumps i found, and now only gives 3 power light flashes when charger connected... i even restored original dump, and it only lights up power button 3 times....no keyboard light or caps or anything...
              the chip is 25Q256JVEQ, 3.3V
              the board is FT490/ FT492/FT590/FT591 NM-B901
              the original dump is in the attachment...
              07-04-2023, 02:54 PM
            • jeffl1980
              Unable to repair damaged PCB on Lenovo T590
              by jeffl1980
              Lenovo T590
              Model 20N5S0W300
              SN PF1BXUWM
              Mobo FP531
              In a poorly executed attempt to re-program BIOS, I believe I knocked off SMD resistors near the BIOS chip (MACRONIX MX25L25673G) pins 1, 2 and 5. Since the resistors were low values, I attempted to make the repairs using solder blobs. I am inexperienced and the workmanship is admittedly poor. I programmed the BIOS chip with the initial firmware read I performed. In other words, I believe the BIOS firmware currently matches what it was prior to any work I performed.
              Here are my current observations.
              • Board
              01-23-2025, 11:46 AM
            • rkawa
              Benq fp531 monitor q5t3
              by rkawa
              hi all! Greetings!
              1 .- I do not ON, nor led stanby.
              Check in tl1451acn ic751
              no voltage pin 5
              pin 10 is 14 volts ...
              any information on this
              I would appreciate each other, help...
              12-02-2010, 09:15 PM
