LENOVO T490 (ft490/ft492/ft590/fp531 nm-b901 rev 1.0)
  • peste
    • 13630
    • ROMANIA
    Originally posted by ktvdung89@gmail.com
    hello friend
    i need help bios lenovo P53s
    serial number:PF-1RLNEX
    type number: 20N6-001UUS​
    post full name and model, motherboard model, etc.
    • ifaztech1
      • Feb 2025
      • 20
      • srilanka
      I have also problem with BIOS (power LED blinks 3 times, laptop does not turn on).
      Lenovo T490, Type 20N3-S70A00, SN PF-26DD3V 20/03, motherboard NM-B901 rev 1.0
      BIOS is in attachement.
      Can anyone help me?​
        SMDFlea commented
        Editing a comment
        try post 15
    • kingkong computers
      • Sep 2018
      • 211
      • pakistan
      no power on my laptop on this bios
      lenovo thinkpad t490
      nm-b901
      type 20n3-s88u0f
      s/n pf-1x8pfj 20/01
      another bios work ok but sound not working
      • hoaca388
        Badcaps
        • Jan 2022
        • 12333
        nm-b901
        type 20n3-s88u0f
        s/n pf-1x8pfj 20/01
        Here
          • Sep 2018
          • 211
          • pakistan
          Originally posted by hoaca388
          Here
          thankyou so much dear
          • IsraLorandi
            • Mar 2021
            • 15
            • Brasil
            #26
            Good afternoon, I need help with my BIOS. From what I've seen, this laptop's BIOS has already been tweaked. It came on without any video, the Capslock, Numlock, and Wi-Fi LEDs blink, and it beeps a few times. I tested the BIOS from post 15 and the power LED blinks three times, but it doesn't do anything else. I'll send you the BIOS that came with the laptop.
            ThinkPad T490
            Model: 20N3
            S/N: PE05GWGQ
            MTM: 20N3SCBJ00
            Motherboard: FT490/FT492/FT590/FP531 NM-B901 REV1.0
            • Dzony83
              • Feb 2021
              • 17
              • Sweden
              #27
              I have two Lenovo T490 that doesn't have an administrator password but has Autopilot. Is it possible to remove Autopilot?
              Thanks a lot for your help!
              Laptop 1:
              Lenovo T490
              Board: L1HF9C201BV
              SN: PF20X204
              Laptop 2:
              Lenovo T490
              Board: L1HF9AF07A9
              SN: PF1ZS605
              • Dzony83
                • Feb 2021
                • 17
                • Sweden
                #28
                OK, I've managed to remove Autopilot from both computers by invalidating an entry.
                Originally posted by volinakis
                I explained how it works in this thread. It's simple to open bios with UEFITool and see how it can be invalidated an entry, depends by bios platform.
                Click image for larger version Name:	Screen Shot 2025-02-06 at 21.41.40.png Views:	0 Size:	104.9 KB ID:	3565962
                Click image for larger version Name:	Screen Shot 2025-02-06 at 21.39.11.png Views:	3 Size:	130.8 KB ID:	3565960
                • volinakis
                  • Jan 2021
                  • 2874
                  • N/A
                  #29
                  good job, it's nice to see someone learning how to do it himself.
                  • Dzony83
                    • Feb 2021
                    • 17
                    • Sweden
                    #30
                    I am always happy to share my knowledge and help others. I'm glad when others do the same. Thank you for that!
                    • Robin21
                      LENOVO T490 High quality photo of CPU area needed
                      by Robin21
                      Does anyone have a motherboard from the Lenovo T490 model FT490/FT492/FT590/FT531 NM-B901 and could take a picture of the CPU area, including all the components around it? I would be very grateful.
                      During the CPU replacement process, I messed up all the resistors and capacitors, and now I can't get it to work again. The motherboard was powering up before, but now it doesn't, even with the newly installed CPU. All voltages are okay, and I don't have any shorts, so I'm assuming I'm missing one of the resistors.
                      I've also followed the schematic and Broadview,...
                      09-25-2024, 06:55 AM
                    • huzo
                      LENOVO T590 not turning on
                      by huzo
                      The board is:
                      FT490/ FT492/FT590/FT591 NM-B901
                      So when i press the power button, the keyboard , the power button, caps lock, numlock lights up for a second, fan spins , and it turns back off, that's it ...
                      Ok, so i opened it, i have 3.3V,5V,1.05V when charger or battery is connected, when i press power button, i get all the voltages on all the coils for a second, except VCCGFXCORE_I , if i read the schematics correctly there should be 1.2V,i don't know if this is or isn't important,because i don't know the sequence and is it a condition for...
                      07-06-2023, 09:27 AM
                    • huzo
                      Lenovo T590 bios
                      by huzo
                      hello guys, can someone check the dump?
                      when power button is pressed, the keyboard and caps and power button went on for a second, and then died... then i tried flashing dumps i found, and now only gives 3 power light flashes when charger connected... i even restored original dump, and it only lights up power button 3 times....no keyboard light or caps or anything...
                      the chip is 25Q256JVEQ, 3.3V
                      the board is FT490/ FT492/FT590/FT591 NM-B901
                      the original dump is in the attachment...
                      07-04-2023, 02:54 PM
                    • jeffl1980
                      Unable to repair damaged PCB on Lenovo T590
                      by jeffl1980
                      Lenovo T590
                      Model 20N5S0W300
                      SN PF1BXUWM
                      Mobo FP531
                      In a poorly executed attempt to re-program BIOS, I believe I knocked off SMD resistors near the BIOS chip (MACRONIX MX25L25673G) pins 1, 2 and 5. Since the resistors were low values, I attempted to make the repairs using solder blobs. I am inexperienced and the workmanship is admittedly poor. I programmed the BIOS chip with the initial firmware read I performed. In other words, I believe the BIOS firmware currently matches what it was prior to any work I performed.
                      Here are my current observations.
                      • Board
                      01-23-2025, 11:46 AM
                    • rkawa
                      Benq fp531 monitor q5t3
                      by rkawa
                      hi all! Greetings!
                      1 .- I do not ON, nor led stanby.
                      Check in tl1451acn ic751
                      no voltage pin 5
                      pin 10 is 14 volts ...
                      any information on this
                      I would appreciate each other, help...
                      12-02-2010, 09:15 PM
