Hp Elitebook 840 g6 error on update me version
  • Traud25
    • Apr 2020
    • 27
    • Portugal
    I got this unit slow start fan always spining loud then got error there is a problem hp endpoint. I try update bios got error on update me version. Any info on this?
    • 20855
    Re: Hp Elitebook 840 g6 error on update me version
    The ME firmware version is showing 0.0.0.0 .Post your bios backups and someone will try to fix the bios with new ME firmware .
    • Traud25
      • Apr 2020
      • 27
      • Portugal
      do i need to read only the main 32mb? or need the 16mb?
        • 20855
        Just the 32MB for now.
        • Traud25
          • Apr 2020
          • 27
          • Portugal
          i added bin on other post
          • peste
            • Dec 2016
            • 12787
            • ROMANIA
            try..
            • Traud25
              • Apr 2020
              • 27
              • Portugal
              Originally posted by peste
              try..
              now fan spin keyboard ligth than power of
              • qayyum786
                • Aug 2018
                • 1933
                • INDIA
                send both bios main 32mb? and 16mb
                and if possible send your original backup not that you have clean me already
                • Traud25
                  • Apr 2020
                  • 27
                  • Portugal
                  Tks to all but unfortunately because some covid 19 restriction, customer came get pc to do telework. I write back bios backup and give to him will se if he brings it on some time later
                  • sellit
                    • Jun 2017
                    • 104
                    • Latvia
                    Please, help fix BIOS. Updated BIOS and stuck in ME firmware update. It Updates till 50% and then restarts shows error updating ME firmware ant again till 50%. Tried to inspect with ME analyzer but shows errors.
                    • peste
                      • Dec 2016
                      • 12787
                      • ROMANIA
                      the bios is corrupt..post more data about the laptop..full name and model, motherboard model, etc ..
                        • 20855
                        If the bios has MEAnalyzer errors and won`t open with FIT, extract the ME region from your bios at post #6 using UEFITool ,right click on ME Region select "extract as-is" or "Extract body" ,open in hxd check file length , select same file length for ME region in bad bios,paste over.It will open with no errors in MEAnalyzer. Can clean the ME again if needed.
                        • peste
                          • Dec 2016
                          • 12787
                          • ROMANIA
                          ok, good idea..it should work ..
                          • imranromi
                            • Jan 2015
                            • 1288
                            • Pakistan
                            In bios update inside also have Me region data.Copy and paste in bios file.
                            • sellit
                              • Jun 2017
                              • 104
                              • Latvia
                              Thanks for help!
                              Tried your bin file. This time it restarted few times and then showed "Last step of BIOS update", then the same cycle of ME firmware update. Not fixed.
                              • RethoricalCheese
                                • Mar 2013
                                • 1518
                                • Estonia
                                Clean files, main and EC. You must write them both. When you get into BIOS, enter DMI info (they are on motherboard and on bottom cover stickers). Then restart laptop about 30 times or so.
                                • sellit
                                  • Jun 2017
                                  • 104
                                  • Latvia
                                  Thank you everyone for help!
                                  It is now fixed. Problem was ME firmware stuck loop with current SSD. Used other SSD and it booted correctly and updated BIOS from manufacturer threw Windows. Now it works fine with First SSD too.
                                  • Sus256
                                    HISENSE 65E7KQ PRO - no boot
                                    by Sus256
                                    Hi all!
                                    HISENSE 65E7KQ PRO
                                    RSAG7.820.13512 - chassis
                                    MT9618BAATAB - cpu
                                    RSAG7.820.12059 - power
                                    HD650Y3U77 - panel
                                    KLM8G1GETF - emmc
                                    The TV does not turn on, the standby indicator is on. All voltages are present.
                                    Emms is dead. Not readable, not detected.
                                    Replaced emmc.
                                    But with another dump there is no launch
                                    Terminal log
                                    UART
                                    AC_ON
                                    RPMB key is not yet programmed
                                    HASH1_VERSION=0x00000000 64bit
                                    E-B
                                    FDE enabled
                                    layout pattern onebin by SAR7,0...
                                    06-01-2025, 02:11 AM
                                  • TheUser
                                    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                    by TheUser
                                    Hello to everyone ,
                                    This is my first post here, and i would like to share with you a small story in case you can help me.
                                    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                    02-10-2024, 02:07 PM
                                  • sikocan
                                    Lenovo X1 Carbon 9th Gen Black Screen
                                    by sikocan
                                    I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                                    SN: PF3G1REP
                                    MODEL: 20KW-00J1AU
                                    PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                                    Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                                    06-24-2025, 09:01 PM
                                  • medinfo
                                    Mac T2 after update(There was an error activating your device)
                                    by medinfo
                                    Macbook Pro 2019 T2
                                    iCloud OFF
                                    MDM unlocked by changing Serial Number
                                    worked fine but after latest update see (There was an error activating your device. Please try again).
                                    Erased and boot in internet recovery, same error.
                                    changed to original serial number (iCloud OFF & MDM ON), same error.
                                    tested with others serial number, same error.
                                    tested (CMD+R), (Option+CMD+R), (Shift+Option+CMD+R), same error
                                    Revived and restored by Apple Configurator and same error.
                                    Any help ?
                                    12-31-2023, 02:04 PM
                                    HP EliteBook NOTEBOOK BUNDEL (6XD79EA + 2UK37AA) Elitebook 850 G6 + Thunderbolt Dock G2 Notebook 800 Specification for Upgrade or Repair
                                    This specification for the HP EliteBook NOTEBOOK BUNDEL (6XD79EA + 2UK37AA) Elitebook 850 G6 + Thunderbolt Dock G2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NOTEBOOK BUNDEL (6XD79EA + 2UK37AA) Elitebook 850 G6 + Thunderbolt Dock G2 boardview and NOTEBOOK BUNDEL (6XD79EA + 2UK37AA) Elitebook 850 G6 + Thunderbolt Dock G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                    09-06-2024, 09:37 AM
