DELL Inspiron 15-5575 CAL51 LA-F121P Unlock BIOS
  • Sickboy311
    • May 2022
    • 8
    Re: DELL Inspiron 15-5575 CAL51 LA-F121P Unlock BIOS
    Btw I appreciate it immensely to anyone who can help me out. I've searched for a couple days when I have time but everyone is charging to give out the passwords. And in having no luck whatsoever with any of the generators idk if I'm using os for 0s or ls for 1s or what but it's not doing anything productive for me. Su yeah worked be super stoked I need this laptop to work so i have something for school. Thanks again.
    • AAAC
      • Jan 2020
      • 457
      • Mexico
      @Sickboy311
      Please READ the instructions, start with NEW, give it 3 tries and then use OLD instructions if it does not work.
      NEW Instructions:
      - Reboot or power-on computer.
      - Enter calculated password, press and hold left CTRL key down, press ENTER key twice (CTRL-ENTER-ENTER).
      IMPORTANT: Give it at least 3 tries before continuing with OLD instructions, as some newer models require this alternate procedure to properly clear the system passwords.
      OLD Instructions:
      - Enter calculated password and press ENTER key.
      master.password = 66368207
      Dell, System Disable: [CE05D3261050C090]
      Inspiron 5575, 3X17LR2
      • Sickboy311
        • May 2022
        • 8
        I get a new box that says:
        harddisk security
        SATA PORT 0 ST1000LM035-1RK177. LOCK (HIGHLIGHTED)
        • AAAC
          • Jan 2020
          • 457
          • Mexico
          @Sickboy311
          Type any password 3 times, to see if you get a new System Disabled code.
          • Sickboy311
            • May 2022
            • 8
            I did in at work right now but when I get home I'll send it
            • Sickboy311
              • May 2022
              • 8
              System Disable [DB4CAA026BBA2AF5]
              Service Tag [3X17LR2]
              hts failad 3 times
              • AAAC
                • Jan 2020
                • 457
                • Mexico
                #27
                Try each of the passwords 2-3 times using NEW INSTRUCTIONS, then proceed with OLD instructions if password still remain.
                NEW Instructions:
                IMPORTANT: Give it at least 3 tries before continuing with old instructions, as some newer models require this alternate procedure to properly clear the system passwords.
                OLD Instructions:
                master password = 29936009
                master.password = 98272704
                Dell, System Disable: [DB4CAA026BBA2AF5]
                • Sickboy311
                  • May 2022
                  • 8
                  You my friend are a life saver I appreciate you more than you could imagine....
                  • Sickboy311
                    • May 2022
                    • 8
                    Can you do this with a latitude 5520?
                      • 20356
                      Off topic. The latitude 5520 password thread is here -> https://www.badcaps.net/forum/showthread.php?t=103534
                      • Pascal Komlassan
                        • Jan 2017
                        • 806
                        • TOGO
                        #31
                        Originally posted by onizzbox
                        Password : 98231710
                        In laptop: Type the unlock password and press <Enter>.
                        please generate a password for me
                        dell 16 digit hex bios password
                        3E1FEE8D57633DCA
                        Service Tag: C6C11X1
                        thank you in advance
                        • imranromi
                          • Jan 2015
                          • 1288
                          • Pakistan
                          #32
                          3E1FEE8D57633DCA
                          Password:51642496
                          • Pascal Komlassan
                            • Jan 2017
                            • 806
                            • TOGO
                            #33
                            Originally posted by imranromi
                            Password:51642496
                            THANK YOU CHIEF YOU'RE THE BEST
                            • vignesharivuslm
                              • Nov 2014
                              • 31
                              • India
                              #34
                              System Disable F08FB43D6A8789A2
                              Service tag JTLRBV2
                              dell 5575 unlock password please
                              • volinakis
                                • Jan 2021
                                • 2648
                                • N/A
                                #35
                                Originally posted by vignesharivuslm
                                system disable f08fb43d6a8789a2
                                service tag jtlrbv2
                                82305612
                                • MegaKela
                                  • Nov 2023
                                  • 3
                                  Hi! It's a real pleasure to discover this post! So many times I try to find the solution to this lock on my computer. I don't understand why the BIOS is locked because I made Bios updates before but after this release, no more possible.
                                  System Disable: 33D3DABC0974B8DE
                                  Service tag: JSBJXQ2
                                  regards!
                                  • MegaKela
                                    • Nov 2023
                                    • 3
                                    dell 5575 unlock password please!
                                    Service tag: JSBJXQ2​
                                    • hlokhand
                                      • Apr 2016
                                      • 17
                                      • india
                                      #38
                                      PLZ HELP BIOS PASSWORD UNLOCK NEED MASTER PASSWORD URGENT
                                      DELL CAL51 LA-F121P
                                      SYSTEM DISABLE :- D0F9E9D4B222F203
                                      SERVICE TAG:- CX5TDP2
                                      • hlokhand
                                        • Apr 2016
                                        • 17
                                        • india
                                        #39
                                        EF00D0C74BD81403
                                        Service Tag: CX5TDP2
                                        thank you in advance​
                                        • theck40
                                          • Nov 2024
                                          • canada
                                          #40
                                          Hi! Need help for unlock me password bios for me :
                                          Dell Insiron 15 model : 33308
                                          EXPRESS SERVICE CODE : 18477000758
                                          SERVICE TAG(S/N): 8HKQ912
                                          Thx very much !
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • Jeff'sTech
                                            Dell Latitude 7420 BIOS Unlock Gone Wrong
                                            by Jeff'sTech
                                            Hello everyone.
                                            I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                                            11-08-2023, 03:30 PM
                                          • remizbushka
                                            Dell inspirion 5775 bios "Unlock Setup fail"
                                            by remizbushka
                                            Hi sirs. please help
                                            Dell Inspiron 5775 bios locked "Unlock Setup fail"
                                            After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                                            What I did:
                                            I read the bios dump.
                                            Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                                            03-24-2025, 09:07 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
