DELL Inspiron 15-5575 CAL51 LA-F121P Unlock BIOS
  • Sickboy311
    • May 2022
    • 8
    Re: DELL Inspiron 15-5575 CAL51 LA-F121P Unlock BIOS
    Btw I appreciate it immensely to anyone who can help me out. I've searched for a couple days when I have time but everyone is charging to give out the passwords. And in having no luck whatsoever with any of the generators idk if I'm using os for 0s or ls for 1s or what but it's not doing anything productive for me. Su yeah worked be super stoked I need this laptop to work so i have something for school. Thanks again.
    • AAAC
      • Jan 2020
      • 459
      • Mexico
      • PLC's, uControllers, FPGA's, RE...
      @Sickboy311
      Please READ the instructions, start with NEW, give it 3 tries and then use OLD instructions if it does not work.
      NEW Instructions:
      - Reboot or power-on computer.
      - Enter calculated password, press and hold left CTRL key down, press ENTER key twice (CTRL-ENTER-ENTER).
      IMPORTANT: Give it at least 3 tries before continuing with OLD instructions, as some newer models require this alternate procedure to properly clear the system passwords.
      OLD Instructions:
      - Enter calculated password and press ENTER key.
      master.password = 66368207
      Dell, System Disable: [CE05D3261050C090]
      Inspiron 5575, 3X17LR2
      • Sickboy311
        • May 2022
        • 8
        I get a new box that says:
        harddisk security
        SATA PORT 0 ST1000LM035-1RK177. LOCK (HIGHLIGHTED)
        • AAAC
          • Jan 2020
          • 459
          • Mexico
          @Sickboy311
          Type any password 3 times, to see if you get a new System Disabled code.
          • Sickboy311
            • May 2022
            • 8
            I did in at work right now but when I get home I'll send it
            • Sickboy311
              • May 2022
              • 8
              System Disable [DB4CAA026BBA2AF5]
              Service Tag [3X17LR2]
              hts failad 3 times
              • AAAC
                • Jan 2020
                • 459
                • Mexico
                #27
                Try each of the passwords 2-3 times using NEW INSTRUCTIONS, then proceed with OLD instructions if password still remain.
                NEW Instructions:
                IMPORTANT: Give it at least 3 tries before continuing with old instructions, as some newer models require this alternate procedure to properly clear the system passwords.
                OLD Instructions:
                master password = 29936009
                master.password = 98272704
                Dell, System Disable: [DB4CAA026BBA2AF5]
                • Sickboy311
                  • May 2022
                  • 8
                  You my friend are a life saver I appreciate you more than you could imagine....
                  • Sickboy311
                    • May 2022
                    • 8
                    Can you do this with a latitude 5520?
                      • 24176
                      Off topic. The latitude 5520 password thread is here -> https://www.badcaps.net/forum/showthread.php?t=103534
                      • Pascal Komlassan
                        • Jan 2017
                        • 808
                        • TOGO
                        #31
                        Originally posted by onizzbox
                        Password : 98231710
                        In laptop: Type the unlock password and press <Enter>.
                        please generate a password for me
                        dell 16 digit hex bios password
                        3E1FEE8D57633DCA
                        Service Tag: C6C11X1
                        thank you in advance
                        • imranromi
                          • Jan 2015
                          • 1296
                          • Pakistan
                          #32
                          3E1FEE8D57633DCA
                          Password:51642496
                          • Pascal Komlassan
                            • Jan 2017
                            • 808
                            • TOGO
                            #33
                            Originally posted by imranromi
                            Password:51642496
                            THANK YOU CHIEF YOU'RE THE BEST
                            • vignesharivuslm
                              Vignesharivu
                              • Nov 2014
                              • 33
                              • India
                              #34
                              System Disable F08FB43D6A8789A2
                              Service tag JTLRBV2
                              dell 5575 unlock password please
                              • volinakis
                                • Jan 2021
                                • 3231
                                • N/A
                                #35
                                Originally posted by vignesharivuslm
                                system disable f08fb43d6a8789a2
                                service tag jtlrbv2
                                82305612
                                please support this forum
                                • MegaKela
                                  • Nov 2023
                                  Hi! It's a real pleasure to discover this post! So many times I try to find the solution to this lock on my computer. I don't understand why the BIOS is locked because I made Bios updates before but after this release, no more possible.
                                  System Disable: 33D3DABC0974B8DE
                                  Service tag: JSBJXQ2
                                  regards!
                                  • MegaKela
                                    • Nov 2023
                                    dell 5575 unlock password please!
                                    Service tag: JSBJXQ2​
                                    • hlokhand
                                      • Apr 2016
                                      • 17
                                      • india
                                      #38
                                      PLZ HELP BIOS PASSWORD UNLOCK NEED MASTER PASSWORD URGENT
                                      DELL CAL51 LA-F121P
                                      SYSTEM DISABLE :- D0F9E9D4B222F203
                                      SERVICE TAG:- CX5TDP2
                                      • hlokhand
                                        • Apr 2016
                                        • 17
                                        • india
                                        #39
                                        EF00D0C74BD81403
                                        Service Tag: CX5TDP2
                                        thank you in advance​
                                        • theck40
                                          • Nov 2024
                                          • canada
                                          #40
                                          Hi! Need help for unlock me password bios for me :
                                          Dell Insiron 15 model : 33308
                                          EXPRESS SERVICE CODE : 18477000758
                                          SERVICE TAG(S/N): 8HKQ912
                                          Thx very much !
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • TopPop
                                            Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                            by TopPop
                                            Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                            I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                            12-14-2025, 09:40 PM
                                          • clrscr
                                            HP BIOS on AI-Generation Platforms: MPM Unlock and DMI Reprogramming Challenges ?
                                            by clrscr
                                            On recent HP platforms commonly referred to as AI-generation systems, unlocking MPM (Manufacturing Programming Mode) in order to reprogram DMI information has become significantly more difficult compared to earlier generations.
                                            The level of firmware security has been raised substantially, and solutions that were previously effective on older platforms (for example, G11 and earlier generations) are no longer applicable or reliable on these newer systems.
                                            1. Increased Firmware Security Archi...
                                            12-24-2025, 09:56 AM
