i need Dell XPS 7390 2 in 1 Gen 10 bios.bin file
  • hoaca388
    Badcaps
    • Jan 2022
    • 11773
    #41
    Re: i need Dell XPS 7390 2 in 1 Gen 10 bios.bin file
    Originally posted by danlopez1222
    hi,
    i'm having issues with xps 7390 2-in-1-
    board: La-g172p
    service tag: 7phfq13
    computer would not boot, just dim amber light whenever power button was pressed. I downloaded a bios online and inserted the bios region of original bios with service tag info to the new donor bios with new ec and me firmware.
    Now it will post but will not read from usb, or internal nvme drive. Sd boot still works.
    Must i use the original ec section? I tried with just using the donor me, but would not boot.
    I've attached my original non-functional backup, my half-functioning backup with new ec and me, and the donor bios.
    I also tried just the donor bios with the same symptoms as my modified bios.
    1111111
    • andresi
      • Nov 2020
      • 153
      • INDONESIA
      #42
      help me to fix this bios, cant display
      • hardware1
        • Sep 2021
        • 2936
        • N/A
        #43
        Here's your New BIOS, try it and give me the results.
        Service Tag: GDXV0X2.
        all donations are welcome,
        • ACHRAFJIRANI
          • Apr 2018
          • 65
          • MOROCCO
          #44
          pls repair
          • Markus1741
            • Sep 2020
            • 843
            • N/A
            #45
            Originally posted by ACHRAFJIRANI
            pls repair
            Try this file me be it helps ...
            Good luck ...
            • ACHRAFJIRANI
              • Apr 2018
              • 65
              • MOROCCO
              #46
              Good luck ...
              thinks bro
              • suanhanh247
                • Oct 2021
                • 3
                • Việt Nam
                #47
                Re: Help me
                HI Bro ! Please fix this file full Fan and Alt F. Thank All Bro
                • Markus1741
                  • Sep 2020
                  • 843
                  • N/A
                  #48
                  Re: Help me
                  Try ...
                  • suanhanh247
                    • Oct 2021
                    • 3
                    • Việt Nam
                    #49
                    Re: Help me
                    Try ...
                    This file you sent not power
                    • gtuser
                      • Sep 2023
                      • 5
                      Where is the BIOS chip located on this motherboard Dell XPS 13 7390 2-in-1? From what I see visually there are two Winbond 25Q64JVIQ chips in this motherboard. Which one is the BIOS chip.
                      • gtuser
                        • Sep 2023
                        • 5
                        I found it in another thread. Should have searched first. Thanks.
                        • SI3MAR2000
                          • Apr 2018
                          • 49
                          • MOROCCO
                          #52
                          Dell XPS 13 7390 2-in-1 DDP31 LA-G172P stuck on dell logo.
                          • qayyum786
                            • Aug 2018
                            • 1933
                            • INDIA
                            #53
                            ❤️YOU MUST:
                            ❤️Post a BIOS BACKUP if 1 or more than 1 (if you have)❤️
                            ❤️Provide the full machine model number, serial number (or Service tag, SNID)❤️
                            ❤️Motherboard part Number and revision (except QR codes)❤️
                            ❤️Must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.❤️
                            ❤️Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                            • SI3MAR2000
                              • Apr 2018
                              • 49
                              • MOROCCO
                              #54
                              I don't have serial number, Service tag.about BIOS BACKUP​ i tried several time to upload but without success
                              • RJ_TECH
                                • Jan 2022
                                • 19
                                • India
                                #55
                                compress it in winzip or winrar than attach
                                • SI3MAR2000
                                  • Apr 2018
                                  • 49
                                  • MOROCCO
                                  #56
                                  • darckreign1984
                                    • 260
                                    • Romania
                                    #57
                                    Can you fix this bios?
                                    thanks
                                    Dell xps 7390 dead, no start with this bios
                                    1JPMM13
                                    3368685063
                                    CN-05M9KH-CMK00-03C-010F-A02
                                    DDP31 LA-G172P
                                    RE1 A00
                                    - i tried with other bios, laptop start, buth random detect ssd, and no usb c device detected (verry slow start)
                                    • qayyum786
                                      • Aug 2018
                                      • 1933
                                      • INDIA
                                      #58
                                      Service Tag: 1JPMM13
                                      try a new one
                                      • darckreign1984
                                        • 260
                                        • Romania
                                        #59
                                        try a new one
                                        laptop started (i have to disable C-state power management from bios.)
                                        now the usb c ports are working.
                                        -touchpad still not working, and no led working (touch pad have error in diagnostic program from dell)
                                        -bios cant update intel tbt retimer 2
                                        Important its that its working better than before. thanks
                                        • trepachka
                                          • Oct 2022
                                          • 429
                                          Hi, I have this Dell XPS 7390 2-in-1 stuck @ Dell logo. Could you, please help me fix corrupted BIOS?
                                          Service Tag# D9J73Z2
                                          Bios file is attached. Thank you.
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                          • hazem3636
                                            need Bios Bin file Dell server 220
                                            by hazem3636
                                            hi everyone
                                            i need dump file for dell server r220
                                            i have download Flash BIOS executable file but i dont know how to conver it to Bin file
                                            i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
                                            if anyone has this method please need his supporting .
                                            all the best
                                            EXE file is attched and Original Bin file from the Bios Chip is attached also
                                            and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
                                            11-05-2022, 06:20 AM
                                          • mrrubik
                                            Dell Optiplex 7010 micro bad BIOS flash?
                                            by mrrubik
                                            Hi folks,
                                            I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                            After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                            Steps I took:
                                            1. Read BIOS with CH341a, verified hash twice
                                            2. Patched
                                            12-23-2024, 04:11 PM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
