Re: ME Firmware Cleaning Guide
Hello SMDFlea,
sorry for my mistake, I guess I loaded the wrong FIT from the internet.
I used the version from the Win-Raid Forum CSME System Tools v11 r44 and it works without any problems.
Many greetings
Install lenovo thinkvantage and let it do the driver updates,you`re probably missing something like the serial io driver,have a look in device manager and see if theres any yellow triangles.Don`t trust windows to install all the driversLeave a comment:
Hello, that's the amazing thing under Ubuntu 20.04 or Debian 10 the touchpad works without any problems.
Now I don't understand why not under Windows 10, the driver has already been reinstalled, nothing.
Many greetingsLeave a comment:
under windows many things not work. did u try ubuntu or other?Leave a comment:
i know that page, but now it looks like it really grow in pages. i must read it all again. thanks againLast edited by ktmmotocross; 02-02-2022, 11:28 PM.Leave a comment:
Scroll down the page to: C2. (CS)ME System Tools .Click on one of those tools links and it`ll take you to mega. Check back there every few months to see if there`s a newer version of the tools.
You can run into a few issues sometimes trying to open a bios with an older version of FIT than what it was built with,ME 11 and under seems to be ok,its 12 and above that can be problematic.MEAnalyzer will tell you which version of the tool it was built with,that exact version might not even be available. Ive got 3 different versions of the "Intel CSME System Tools v12" ,r10 r14 and r21 ,each one has a "Tools Version Info.txt" file with a build number for each tool. The r10 FIT version is 12.0.6.1120 ,r14 FIT version is 12.0.22.1310 and r21 FIT version is 12.0.49.1536 .
If i have a bios doesn`t open with one version i try the others,if it doesn`t open with any then its probably because the bios or ME firmware is corrupt.Leave a comment:
I can tell by looking at your picture that you`re trying to open a G50-70 bios with the wrong FIT version. See the attached picture the G50-70 bios opened with MEAnalyzer,the ME firmware is version 9.5 ,so you need to use FIT from the "Intel ME System Tools v9.5" .The T460s does have ME 11 ,so open it with FIT from the Intel CSME System Tools v11
so i need to first check me version and by that use correct FIT version?Leave a comment:
Ive left the bios at post #84 and added a note not to use it. This new bios cleaned with FIT looks ok to me,it has kept the original configuration.Leave a comment:
I created this file again on your white.
Now I don't know if it's correct.
Please delete my wrong file so no one gets hurt.
Many greetingsAttached FilesLeave a comment:
.Last edited by SMDFlea; 02-02-2022, 09:57 AM.Leave a comment:
EDIT: Do NOT flash this bios !! . Firmware cleaned with Intel ME/TXE injector does not keep the OEM`s original ME/TXE configuration. Open this bios with Flash Image Tool (attached) and the bios at post #87 with FIT 11 (copy FIT to 2 seperate folders with each bios) and compare the differences.
.Last edited by SMDFlea; 02-02-2022, 11:03 AM.Leave a comment:
Operation is extremely simple.
Good luckLeave a comment:
My problem was solved. Actually FIT version really doesn't matter.
I thought that FIT will check only 8MB bios, but actually 4MB part of EC rom was missing, so it did some stupid things inside bios instead of repair it..
Thanks for hint.Leave a comment:
PRD_RGN is stock FW .Its recommended to always use PRD_RGN ,even if you can`t find an exact version,if there`s one thats a little bit older or a bit newer ,and has the same major and minor version its ok.Leave a comment:
Whats is difference between stock and extracted? Will stock ME work on BIOS that contains extracted?Leave a comment:
I think the wording on Win-Raid was due they are tired after so many years of help with not much return knowledge. Nice they found someone who could continue great job there.
I have problem with my bios i described here in post #10
https://www.badcaps.net/forum/showthread.php?t=70264
ME don't show it, but im sure this is corporate version (business laptop with Win 8 pro for government district) 5mb, but final size after FIT showed in ME analyzer is unproper, even i change 1vs1 ME prd_rgn (found exactyle same numbers in repository).
The idea was to try older FIT and check what will happen. Laptop works on bios from same working unit, but with 15s delay, as typical for ME.
I read that US Army made big order for PC's but completely without Me region. This would be interesting how they switched it of completelly..Leave a comment:
by SMDFleaIf you have to clean the ME firmware on **some microsoft surface models the touchscreen can stop working.
** Some models do not need this fix.
*You should install the latest updates from microsoft,including the driver packs before assuming there is a hardware problem.* - See Post #2
EDIT: If nothing else works try this fix - https://www.badcaps.net/forum/showpo...8&postcount=40
Always check a working dump from the same model using FIT.If the working dump default setting for "Integrated Sensor Hub Supported" is set to "NO"...-
Channel: BIOS Requests ONLY!
by Wachenaggoi know a tool https://github.com/MuertoGB/MacEfiToolkit is capable of SN change and Clean ME but not updating EFI Version of the BIN file. is there a guide or a BIOS structure to update the firmware??...03-06-2024, 01:34 AM
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...02-10-2024, 02:07 PM -
by gurj1979Hi guys.
I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
Got New chip and writes good.
THE PROBLEM...
It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
Does anyone have a Good Firmware I can have?...-
Channel: Troubleshooting & Designing Networks
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
- Loading...
