  • Polar Bear
    Polar Bear
    • Jun 2025
    • 5
    A friend of mine approached me with request for help to recover access to a few electronic devices left after tragic death of his son. One of the devices is a Lenovo T480s laptop with UEFI Supervisor laptop. I did my research on internet for possible methods and couple of them lead to BadCaps forum.
    Laptop: Lenovo T480s
    MB: ET481 NS-B471 Rev: 1.0 2017-10-30
    Type: 20L7-002CUS
    S/N: PC-0WWFM7 18/08
    BIOS IC: 25Q128JVSQ
    Method #1: Lenovo autopatcher
    Video: https://www.youtube.com/watch?v=s9XlN2Hl0ag
    lenovo_autopatcher_0.2
    The BIOS has been read and stored 3 times in a files, CRC is the same for each file. The BIOS was processed by lenovo_autopatcher_0.2 successfully. The result bin file was written into the BIOS chip. At next laptop's boot a procedure to disable TPM was completed successfully. Then original BIOS was written/restored into BIOS chip. Following boot of the laptop still asks for password input.
    The procedure was completed/repeated a few times (with connected/disconnected batteries) with exactly same result.
    Method #2: Supervisor password decryption
    Video: https://www.youtube.com/watch?v=IhRw7ePhLKs
    Followed the video in attempt to decript Supervisor's password. Using UEFItool was found padding value (00700000h) and BIOS file was scanned for an offset (0003FC20h). Looking at 0073FC20h in BIOS file the password has 168 bites and bytes values way beyond keyboard scan codes. It is considered that this attempt/method is not applicable to Lenovo T480s.
    Keyboard scancodes: https://aeb.win.tue.nl/linux/kbd/scancodes-1.html
    Method #3: JLPC ADC shorting to GND
    Video: https://www.youtube.com/watch?v=D-PFVJpBcTY
    URL: https://www.badcaps.net/forum/troubl...-ec-pwd-bypass
    Followed the video, in many attepts to GND any pin 4,6,8,10 (ADC0:3) on JLPC pads and only once I was offered to press F1 go get into BIOS settings, for some unexplicable reason keyboard refused to respond on key presses. All following attempts was unsuccessful so far (to catch a right timing to corrupt data exchange and get into BIOS settings).
    Please suggest how Supervisor password can be remove.
    Your help is greatly appreciated.
    • peste
      peste commented
      Editing a comment
      post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
  • abrnb
    • Apr 2023
    • India
    #3862
    when i try to autopatch a file the fill generated and immediately deleted, pls assist me for this problem, Thanks
    • Polar Bear
      Polar Bear
      • Jun 2025
      • 5
      Hello Knucklegrumble,
      per your suggestion I would like to report unsuccessful case with Lenovo T480s. I followed your procedure and everything was going according plan except that after restoring original BIOS and reboot laptop asks for a password.
      I've made a post for my case with a details. I would appreciate if you take a look at it.
      Thank you for your work and help
      Polar Bear
      • Polar Bear
        Polar Bear
        • Jun 2025
        • 5
        Originally posted by Vincehu
        Just bought a CH341A programmer for Thinkpad T480s, IC chip is 25Q128JVSQ,
        I used the AsProgrammer 2.1.0 .13 Version, But I cannot find this chip model in CH341A chip list, there are only 25Q128BV and 25Q128FV.
        Can someone help how to handle this IC 25Q128JVSQ?
        Thanks very much.
        you can use any of 25Q128BV or 25Q128FV they share same chip ID as your IC 25Q128JVSQ (see page 21).
        Or you can add your chip into list of supported chips yourself. Just edit file chiplist.xml,
        find line
        Code:
        <W25Q128FV id="EF4018" page="256" size="16777216"/>
        add after it
        Code:
        <W25Q128JV id="EF4018" page="256" size="16777216"/>
        save the file.
        Now try identify chip in AsProgrammer and you will see your chip in the list.
        Note: you can download more recent AsProgrammer 3.7 or AsProgrammer 2.1.2
        Polar Bear
        • CesrDroid
          • Jun 2025
          • Lima
          #3865
          Originally posted by CesrDroid
          Can someone help me? When I use the autopatcher, the computer starts beeping and does not start the BIOS.
          I just saw that I uploaded the file, but it's 6MB. The original BIOS is 16MB, but when I run the autopatcher, it doesn't work and the siren is activated.
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1205
            • France
            #3866
            serial number, type etc ... respect rules please
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1205
              • France
              #3867
              method 1 should work
              Method 2 doesn't work. Password is in EC. Can't decrypt. It's not registered in the BIOS.
              Method 3: You must use a USB keyboard because the shunt disables the keyboard. Watch the other videos to understand, the timing of the shunt is important
              f1 is pressed before the shunt.
                by Vesko356
                08-11-2023, 03:27 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • Bloodhoundje
                by Bloodhoundje
                03-16-2024, 03:12 PM
