Hi have a lenovo e595 with a supervisor password lock. I have tried the auto patcher from bios dump but my bios comes out to 32mb not 16 and wont fit on the flash.
can anyone help?
Laptop serial number is PF-2233EX
type : 20NF-0006UK
Attached FilesComment
Hello I have Yoga 11e 20 LN S06E00 SN R9-0V7ZYP and i cant remove password with autopatcher beacause after flash im getting black screen. If someone could help me with password delete on this bios i would be gratefulAttached FilesComment
I have a laptop with supervisor password set which I don't remember. I tried the autopatcher (both versions), but it seems it doesn't work with my model. The keyboard status LEDs light up, turn off again, then nothing, and after about 20 seconds I get multiple beeping tones.
ThinkPad X1 Extreme (v1)
Type: 20MF-000TGE
S/N: R9-0RVL8E
Can you help me remove the password?
Can someone help me? When I use the autopatcher, the computer starts beeping and does not start the BIOS.Attached FilesComment
I have a Lenovo T490S, can you help me REMOVE THE SUPERVISOR PASSWORD? Type: 20NY-S34L00 S/N PC-1FV4Q1 20/03 Thank you in advanceAttached FilesComment
I managed to solve this by myself. Using the BIOS from https://www.badcaps.net/forum/troubl...15#post3579915 worked with the autopatcher.Hello,
Type: 20MF-000TGE
S/N: R9-0RVL8E
Can you help me remove the password?Comment
hi everyone, my laptop Lenovo Thinkpad X1 Nano Gen 1 Bios screen is stuck at 100%, I found some dumps and flashed the bios, it works but the SuperVisor password is stuck. Can someone help me? This is the dump I used, not the original dump of the machineComment
Type the laptop serial number, full name and model, motherboard model, etc.
post the contents of the original bios chip even if it is corrupted..
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
I'm sorry. This my model and original bios
Serial Number R9-10W8WV
Type Number 20UN-0001JPAttached FilesComment
This system does not work for 32Mbytes. This system is only valid for 16MB. I have done it many times.Comment
AMD or Intel ?? intel not workHi Maxpower3
I have Lenovo L15 with part number GL4A0/GL5A0 NM-C631 and I followed your guidance for NPCE68APA0DX by make a short connection pin 1 or 128 with ground for two second when I can see Lenovo logo but problem is that laptop stuck in Lenovo logo. what am I doing wrong?
L14 L15 complicated model
look at the other posts in
https://www.badcaps.net/forum/troubl...-ec-pwd-bypass
it's intel, ok I will try second solution. thank you
impressive, well done, great job
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
when he will discover your method he will realize he waste his time researching and writing his thesis. Imagine: after reading his thesis in front of colleagues and professors, the dumb of the class rises 2 fingers and says: I know a faster and better way!
On a serious note, I bet you didn't discover your method by accident, you searched a way to interrupt communication between UEFI and EC and you found it.Last edited by volinakis; 06-30-2025, 02:33 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
