I've tried almost all the combinations and I still get the 0285 error with black screen, with/without hard drive, with/without holding the tamper switch, with/without the CMOS battery plugged in, the only thing I have not tried is removing the RAM. Does that matter? I also cleared the 1.2 TPM from the app and using Power Shell.Comment
Hey Y'all
I have an issue with my X280.
At "STEP 2: Boot the machine" i got no display, and I get beep code 0285 (TCG-compliant functionality related error / Might be TPM initialization failure).
If i re-flash my BIOS chip with the original unpatched BIOS, it boots normally.
Can anyone please help me with this issue?
Thanks.
Hardware Specifications |
Machine Type Model : Lenovo X280 20KE-SCMU00
System Unit S/N : PC-1AMPEC
BIOS Chip : 25Q128JVSQ winbondAttached Filesif you find these attachements useful please consider making a small donation to the site
Try with this method :
https://www.badcaps.net/forum/troubl...ss#post3237235
99% it will do the job if you're patient
Will try and come back. Thank you!!!
lenovo thinkpad T14s patch file need please share if have
NM-D326 REV 2.0
issue : superviser password
Just want to say thank you to @Knucklegrumble for this patch. Managed to unlock my x270 bios after getting the patch to run. Amazing work!Comment
hello, this solution does not work on Lenovo e490 TP00094D, 20N9-S16L00 S/N PF-1PAA5L, NM-B911. After starting, nothing is displayed, a black screen and there is a sound as if the BIOS is damaged (TPM module fault). Do you have any idea?Attached Filesif you find these attachements useful please consider making a small donation to the site
The LPC approach worked for X1 Yoga 3rd Gen, Type 20LE (i7-8650U CPU). Thanks for the hint!
BIOS Version N2CET71W (1.54)
Embdedded Controler Version N2CHT26W (1.16)
ME FIRMWARE 12.0.90.2072
Machine Type Number 20MCS27300
System Unit Serial number PF1RGGQP
System Board serial number L1HF93S0025
(ili tryin flash U9 MX25L25673G)
also get success with lot of p50 ant t480, but p72 stomped me ;0Comment
It's not about the model...
It's about CPU type, if your CPU is i7-8850H then the autopatcher wont work.
Try LPC method described here : https://www.badcaps.net/forum/troubl...ss#post3237235
Good luck!Comment
I do have ThinkPad P72 (20MB, 20MC) [32MB] in my list of compatible ThinkPad models, meaning that I had patched it myself and confirmed working. I usually patch the earliest BIOS version downloaded from Lenovo website using Serial Number, then I use this patched BIOS Region and replace it in the Original BIOS, doing it this way I virtually eliminated any possible beep codes on patched files. You may have to add some padding at the beginning of the BIOS extracted from BIOS update to match the size of BIOS Region in your Original BIOS.Comment
I am having an issue with the script, it always tells me that there's a dumping error.
I have dumped 4 times with power cycles in between and all the files are (MD5) the same, so i don't think its a bad dump.
Could anyone please check?
The model is a T10 Thinkpad TabletAttached Filesif you find these attachements useful please consider making a small donation to the site
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
Product ID: RZ09-0421
Motherboard: CH580
Bios File Size: 32,768 KB
Dear Forum Readers!
!!! MY RAZER BLADE...-
Yesterday, 05:52 PM -
- Loading...
