gateway bios password help
  • yonu
    • Nov 2007
    • 138
    hey I am hoping someone can help me out I am trying to reset the bios on a gateway solo 9300 but am having no luck i have tryed the copy of unlock 6 I have for acer but it doesn't work. if anyone can help it would be much appreciated.
    Thanks,
    yonu
  • NxB
    • Feb 2009
    • 1595
    Re: gateway bios password help
    pull cmos -> check service manual -> dump eeprom. Keep trying unlock programs that work on your bios version if you can boot up. If its a power on password then the previous progression still applies.
    • yonu
      • Nov 2007
      • 138
      ok i take it there is no way to do it without pulling the cmos? I have tryed every program I can find and none of them work and ideas if anyone has any would be great
      • NxB
        • Feb 2009
        • 1595
        The password for these things usually is on external eEprom not in the CMOS itself. For security it is sometimes encrypted. Of course it varies by maker and model. Hence usually with a password locked laptop you are screwed.
        • i4004
          • Oct 2006
          • 2029
          can't he just clear the cmos by jumper, or by removing the battery for a period of time?
          hm..
          http://forums.windrivers.com/showthread.php?t=1001
          seems these laptops are weird in that sense...huh...
          nice design...eh..
          • kaniki
            • 514
            no. on newer laptops all the passwords for the bios are stored on the EEPROM chips.. the only thing that you could do was reset the bios configurations to factory by pulling the battery.. and that includes both the bios battery and main battery.. but the passwords for access are not power sensitive so do not get erased like on a desktop..
            • NxB
              • Feb 2009
              • 1595
              sometimes it still works but usually it does not.
              • SmartAceW0LF
                Yoni, are you still working on this issue? I just lost almost an hours work in posting some things regarding this thread that might help. So, if you are still dealing with it, please let me know and I will post it again. FRICKIN-FRACKIN-TIMING-OUT-BASTIDGES! :-)
                • insomnia
                  • Jan 2010
                  • 17
                  still works on new laptops need to bridge to pads on the motherboard most of time success here
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
                  • traxformania
                    TONGFANG "GM7TG7P" Bios Password Problem?
                    by traxformania
                    I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                    But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                    I'm trying to reset my bios without success.
                    I tried :
                    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                    11-15-2023, 07:32 AM
                  • tlindi
                    Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                    by tlindi
                    Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                    >Read BIOS guides, methods, resources and tools
                    Ack
                    >Try the method at BIOS guides, methods, resources and tools before requesting help
                    Ack
                    >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                    python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                    01-30-2025, 04:26 AM
                  • Nopslide
                    HP Omen 15-dh0052nf power-on & bios password
                    by Nopslide
                    Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                    My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                    Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                    04-01-2024, 04:27 PM
                  • BlackVisor
                    How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                    by BlackVisor
                    RedmiBook Pro 1542022 6800H
                    SKU: TM2113-39463
                    Model Number: RMA2204-AB
                    CMIIT ID: 2022AP1835
                    SN: 39463/22WD01355
                    BIOS version: RMARB5B0P1010 20230628
                    1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                    2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                    3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                    01-14-2024, 06:35 AM
