HP Probook 640 G2 bios dump
  • Milovanovic1992
    • Aug 2024
    • 26
    • Serbia
    #101
    #solomost
    Is that dump originaly from your laptop? That file contains different SN, not the same you provided here. Anyway, try this two ( first with changed SN because that is SN you wrote in your post. Second one is with SN which already was in your bios dump).
    • amitswami
      Delhi
      • Aug 2021
      • 44
      • rajasthan
      #102
      HP ProBook 640 G2
      Serial No: MXL64814P6
      Product No : W8F39UP
      Board No : CIRCUS-6050A2723701-MB-A02
      plzz repair this bios​
      • solomost
        • Sep 2021
        • 39
        • agadir
        #103
        Originally posted by Milovanovic1992
        #solomost
        I tried both files and it didn't work for me, Maybe I gave you the wrong serial number, The writing on the back of the laptop that contains the serial number has been erased, Where can I find the real serial number ? thank you
        • amitswami
          Delhi
          • Aug 2021
          • 44
          • rajasthan
          #104
          Originally posted by amitswami
          HP ProBook 640 G2
          plz repair this bios
          • hoaca388
            Badcaps
            • Jan 2022
            • 11736
            #105
            HP ProBook 640 G2 N76 Notebook PC
            • amitswami
              Delhi
              • Aug 2021
              • 44
              • rajasthan
              #106
              thank you sir
              • misiek_michal
                • Sep 2023
                • 11
                • Poland
                #107
                Hello.
                Is there anyone who can fix this bios? After starting the laptop, the display lights up, but not even the HP logo appears. Another clean bios works without problems.​
                  • 20898
                  Don`t forget to post the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
                  • misiek_michal
                    • Sep 2023
                    • 11
                    • Poland
                    #109
                    Sorry,
                    HP Probook 640 G2
                    Serial: 5CG6421CYJ
                      SMDFlea commented
                      Editing a comment
                      Posts moved to 640 G2 thread topic.
                  • baghdad9510
                    • Feb 2017
                    • 14
                    • algerie
                    #110
                    Hello can anyone repair the original bios i have no Display HP 640 G2
                    S/N MXL7031FYV
                      SMDFlea commented
                      Editing a comment
                      post moved from 650 G2 topic to 640 G2
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11736
                    #111
                    S/N MXL7031FYV
                    HP ProBook 640 G2 Notebook PC
                    • baghdad9510
                      • Feb 2017
                      • 14
                      • algerie
                      #112
                      Nothing. only caps lock key light
                      • Rahim Kachere
                        • Jun 2024
                        • 7
                        • Malawi
                        #113
                        Hello brothers, Help me i need bios file
                        HP ProBook 640 G2
                        CICUS-6050A2723701-MB-A02
                        Serial number : 5CG62468QN
                        Product: L8U33AV
                          SMDFlea commented
                          Editing a comment
                          Post moved to 640 G2 thread topic
                      • xe_d_sono
                        • Aug 2013
                        • 24
                        • Portugal
                        #114
                        I try to clean Intel ME, unlock but same result, fan on top and blackscreen.
                        Can someone try to fix my bios?
                        SN: 5CG7251ZJS
                        • xe_d_sono
                          • Aug 2013
                          • 24
                          • Portugal
                          #115
                          SN: 5CG7251ZJS
                          Solved! There is a 3x capacitores burned. Thanks anyway.
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • Citymin
                            by Citymin
                            S/N : 5RNK9FFT70...
                            Yesterday, 05:12 AM
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
                          • solomost
                            need bios dump for HP ProBook 640 G2
                            by solomost
                            HI I need bios dump for HP ProBook 640 G2 PLZ☺☺
                            prblm: black screen caps lock blinking 5 times then fan spening
                            CT: PFKCT00WB69310 REV : 1.20
                            motherboard : HSB J Mv-6 94v-0 E89382
                            03-21-2025, 06:22 AM
                          • salim5566
                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                            by salim5566
                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                            06-26-2025, 03:25 PM
