Surface 3 Clean Bios? (noob)
+ More Options
Posts
  • cdma-india
    • May 2010
    • 35
    #41
    Re: Surface 3 Clean Bios? (noob)
    hallow max still i dont understand , can u share your tool?
    • cdma-india
      • May 2010
      • 35
      #42
      Cb56bab4b9de4734ff88a19781a44531
      5e3d236883295cd7196fdb733939dbad
      37e229393fb7027b3f5cb2b875d719fc
      217591c1b91d2599a0acfb74a3deb492
      11b9c1358b
      some one will decode this?
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1226
        • France
        #43
        post your dump here ,the key finish by 1c 83 (01)
        • cdma-india
          • May 2010
          • 35
          #44
          i am realy sorry i was serching surface 4 got dump from Aword
          is it possible same process for surface 4
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1226
            • France
            #45
            test with this file
            it's not possible to recover the password on surface 4 with same method .
            • keczuk
              • Dec 2019
              • 83
              • WWW
              #46
              Originally posted by Maxpower3
              Search a little, you will find
              I can't find this site in google. I try many combination with: MxP, Bios password, surface 3 etc..... can you give a link ?
              • OmegaPrime
                • Jun 2020
                • 22
                • Bulgaria
                #47
                Have you got a XOR key ? Cant calculate without key. But why you need to calculate , just fill all of this string in dump with 00 (zeroes).
                Try HERE (you`ll need a XOR Key), but in almost all cases password is HASHED.
                • keczuk
                  • Dec 2019
                  • 83
                  • WWW
                  #48
                  Please give a link for this site:
                    • 20961
                    https://toolslick.com/math/bitwise/xor-calculator
                    EDIT: The ASCII result is reversed .
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1226
                      • France
                      #50
                      https://www.microsoft.com/fr-fr/microsoft-365/excel
                      • keczuk
                        • Dec 2019
                        • 83
                        • WWW
                        #51
                        u FEEL better ? or ?? it's not funny.
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1226
                          • France
                          #52
                          There is nothing funny
                          just use her brain and the info on the page.
                          Everything is indicated here.
                          You have all the links to find and understand the principle of operation.
                          Too easy to share my files that I took hours to create.
                          They are provided in another tool which is not yet available.
                          If you want to understand, search a little.
                          Otherwise just ask for your password
                          Originally posted by AAAC
                          @keczuk
                          Just Google search for β€œRecovering the BIOS password from a Panasonic CF-U1 mk2”, you’ll find a GitHub post with details.
                          • RethoricalCheese
                            • Mar 2013
                            • 1518
                            • Estonia
                            #53
                            Why you need to calculate is because otherwise you would need to remove the screen to do that. I doubt anybody would want to do that on a surface if decrypting is this easy.
                            • keczuk
                              • Dec 2019
                              • 83
                              • WWW
                              #54
                              Someone can read for me password from this dump Panasonic ??
                                • 20961
                                Start a new thread,its unrelated to this thread topic.
                                • joshuah459
                                  • Mar 2021
                                  Hello all. I recently acquired a small army of surfaces and they're functional, but they have a bios password. I've been trying to figure out how to do it myself since there's so many of them, but I'm stuck at the actual decrypting part. I followed the guide from the Panasonic bios recovery on github, but I'm unsure of where the author got the second hex string from. Thanks for any and all help and I have attached a bios file from one of the devices.
                                  Code:
                                  00000000000000000000000000000000
                                        00000000000000001A93F22641BA2C4D
                                        8BE071743E07D89A332E8EC1E95444E8
                                        9F7BFA0E55A2B0350BC9665CC1EF1C83
                                        01
                                  • AAAC
                                    • Jan 2020
                                    • 458
                                    • Mexico
                                    #57
                                    @joshuah459
                                    If you have a bunch of these, there's a probability that the supervisor password may be the same in all of them, for this one it is (pswrd is case-sensitive):
                                    password = ADP@LSC
                                    There's a GitHub post with the information you are looking for, it's related with a Panasonic ToughBook laptop, you need the XOR key and all you have to do is XOR the "password-block" (you extracted from AMITSEVAR) versus the "xor-key", you will get the result which will be in Hexadecimal numbers (0-9, A-F), then just do the HEX conversion to ASCII to get the password.
                                    • przemek_79
                                      • 28
                                      • Poland
                                      #58
                                      hello Andrewsd how did you get the hex hash is
                                      7200006a000034000035000062000031000030000035 ????
                                      • AAAC
                                        • Jan 2020
                                        • 458
                                        • Mexico
                                        #59
                                        @przemek_79
                                        Discard the 00h NULL bytes and this translates to:
                                        password = rj45b105
                                        ...just XOR the contents of AMITSESetup variable block contents versus the XOR-key.
                                        • przemek_79
                                          • 28
                                          • Poland
                                          #60
                                          hello again, tell your colleagues how to calculate from this code 4E5641526800FFFFFF8221414D495453455365747570000000 00000000000000000000000000000000000000000000000000 000000000000000000000000002993DC2625BA594D07E891AE9532D07E891AE9532DA5E96CBE9532D07E891AE954DA5E891AE954D07E9E9AE95324
                                          for this code 7200006a000034000035000062000031000030000035 ????
                                          • FalconPunch
                                            Surface Pro X 1876 Bios corrupted
                                            by FalconPunch
                                            Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                                            Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                                            Yesterday, 03:56 AM
                                          • macabook
                                            πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • muhuruu
                                            Surface pro 4 bios request
                                            by muhuruu
                                            Hey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
                                            01-22-2024, 05:38 AM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                            Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-06-2024, 08:10 PM
