Surface 3 Clean Bios? (noob)
  • Chaos-Acid
    • Jun 2020
    • 9
    been lurking for a couple of weeks now, managed to get my hands on a cheap surface 3, UEFI password locked though..
    I'm a complete noob at this and i think i've dumped the bios, anyone able to show me how to get the password or upload a clean bios for me to update with?
    Many thanks to you all!
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: Surface 3 Clean Bios? (noob)
    Your rar file is 2.9KB thus invalid. Use flash programming tool (fptw64.exe -bios -d surface3.bin) to read bios region. Then upload it and I can get the password from there.
    I think you need TXE2 flash programming tool for that.
    • Chaos-Acid
      • Jun 2020
      • 9
      Yah, i think i'm getting that issue at the moment, using \Intel ME System Tools v10.0 r7\MEInfo\WIN64>MEInfoWin64.exe
      i get the error Error 9460: Unknown or unsupported hardware platform
      So i assume i have to go right back a version, the TXE2 version?
      Also thank you for your help and sorry - i'm such a noob.
      Havent been a windows user since XP..
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        Yes, as I said, TXE2 should work.
        • Chaos-Acid
          • Jun 2020
          • 9
          Thank you - I think i found the correct version and the command you gave me worked!
          ___________
          Intel (R) Flash Programming Tool. Version: 2.0.5.3107
          Copyright (c) 2007 - 2015, Intel Corporation. All rights reserved.
          Platform: Cherry Trail
          Reading HSFSTS register... Flash Descriptor: Valid
          --- Flash Devices Found ---
          MX25U6435F ID:0xC22537 Size: 8192KB (65536Kb)
          - Reading Flash [0x800000] 4096KB of 4096KB - 100% complete.
          Writing flash contents to file "surface3.bin"...
          Memory Dump Complete
          FPT Operation Passed
          _________________
          Thank you again for your help, i'm learning a lot researching all these
          • Chaos-Acid
            • Jun 2020
            • 9
            Attachement:
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              1234567890
              • Chaos-Acid
                • Jun 2020
                • 9
                Originally posted by RethoricalCheese
                1234567890
                hhahahah, ofcourse that worked!! why didn't i try that when i was trying to guess it in the first place!!!!
                Thank you as always my friend - if i may ask, how did you find it out - i assume by looking through the dump and finding a hex key?
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  It is located in AMITSESetup section but it is slightly encrypted so some decryption is needed.
                  • Chaos-Acid
                    • Jun 2020
                    • 9
                    oh amazing! wow, you sir are a god among men and i cannot thank you enough!!
                    • keczuk
                      • 84
                      • WWW
                      wow i try check this file, and don't see AMITSESetup section. Can you tell more about this ?
                      • lapfix
                        • Mar 2020
                        • 2764
                        • my workshop
                        You can use search on UEFI Views , but as RethoricalCheese say : it's encrypted !
                        • KingBonecrusher
                          • Jun 2020
                          • 28
                          • Netherlands
                          Hi!
                          If i`am correct AMI uses an XOR key to encrypt the SHA1 hash of the stored password (maybe scancode)? Would you provide some more infos how to recover the sha1 hash or password?
                          • KingBonecrusher
                            • Jun 2020
                            • 28
                            • Netherlands
                            Originally posted by KingBonecrusher
                            Hi!
                            Ok, found the solution...
                            Code:
                            3132333435363738393000000000000000000000
                            Rest is simple
                            • RethoricalCheese
                              • Mar 2013
                              • 1519
                              • Estonia
                              Well done!
                              • keczuk
                                • 84
                                • WWW
                                Code:
                                Rest is simple
                                Still cant find in this bios file encrypted password. Some one can show where is lockated this encrypted password ?
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1519
                                  • Estonia
                                  Open with uefitool. Open search, write AMITSESetup. You will get maybe 10 of those. Usually only 1 or 2 of them have content.
                                  • KingBonecrusher
                                    • Jun 2020
                                    • 28
                                    • Netherlands
                                    Check the AMITseSetup variable body with UEFITool, there is:
                                    Code:
                                    00000000000000000000000000000000
                                    00000000000000006A93842622BA584D
                                    F2E014744A07E09A0A2EBEC1E95444E8
                                    9F7BFA0E55A2B0350BC9665CC1EF1C83
                                    01
                                    You need only:
                                    Code:
                                    6A93842622BA584D
                                    This needs to be decrypted with the known AMI XOR Key...
                                    • keczuk
                                      • 84
                                      • WWW
                                      Code:
                                      01
                                      You need only:
                                      Code:
                                      6A93842622BA584D
                                      https://md5decrypt.net/Xor/
                                      This site working for decrypt ??
                                      • keczuk
                                        • 84
                                        • WWW
                                        no one help ?
                                        • FalconPunch
                                          Surface Pro X 1876 Bios corrupted
                                          by FalconPunch
                                          Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                                          Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                                          08-09-2025, 03:56 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • muhuruu
                                          Surface pro 4 bios request
                                          by muhuruu
                                          Hey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
                                          01-22-2024, 05:38 AM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
