Surface 3 Clean Bios? (noob)
  • vagrants
    • Sep 2022
    Re: Surface 3 Clean Bios? (noob)
    Originally posted by AAAC
    @vagrants
    If you used UEFITool NE version, when you do a search for AMITSESetup, the match it finds in the UEFI variable section is just a link, so click on the variable and then right-click on it and select the menu option "Go to data", it will take you strait to the variable data contents. Then you can extract the variable and use the tools to decode the password.
    AMITSESetup var = 0993D7267FBA3B4DA2E051744D07EB9A152E8EC1E95444E89F7BFA0E55A2B0350BC9665CC1EF1C83
    Helllo, AAAC. Thanks for the help. I initially used that one, but it looked complicated, I passed. I used HxD instead. I was seeing the same thing on the UEFITool NE A61 win32 initially, but I finally found what you pointed out. It was under NVRAM/AmiTseSetupGuid at header-offset "some Hex".
    Thanks much, lapfix & AAAC.
    • xlzr404
      • Apr 2023
      Hello. I have a surface 3 with a locked bios pw and was wondering if anyone could put together a step by step explanation on where to get txe2 or whatever programmer I need, then a step by step to dump the bios using said programmer. I have attempted reading the guide here, but i need to understand if I am using powershell or if there is an executable file. I appreciate the help.
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #123
        Originally posted by xlzr404
        ...was wondering if anyone could put together a step by step explanation... then a step by step to dump the bios...
        I'll have to quote myself:
        Originally posted by Vesko356
        And why not pizza and Diet Coke too? Anything else?
        TXE2 is not a programmer but software. There's no need to use any programmer for this particular device. Read the thread carefully, all you need is already explained.
        Become a Badcaps supporter
        Thanks to all supporters.
        • xlzr404
          • Apr 2023
          Still reading. Did I do this correctly?
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #125
            No.
            Continue reading carefully from the beginning.
            Hints:
            https://www.badcaps.net/forum/showpo...9&postcount=94
            https://www.badcaps.net/forum/showpo...31&postcount=2
            Code:
            C:\Flash Programming Tool\WINDOWS64>fptw64.exe -bios -d surface.bin
            • FalconPunch
              Surface Pro X 1876 Bios corrupted
              by FalconPunch
              Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
              Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
              08-09-2025, 03:56 AM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • cr4zychriss
              by cr4zychriss
              • Rebrand: PC Specialist
              11-14-2025, 04:04 PM
            • muhuruu
              Surface pro 4 bios request
              by muhuruu
              Hey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
              01-22-2024, 05:38 AM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
