Dell E5570 - Bios / Clean ME ADM80 LA-C642P R1.0
https://www.badcaps.net/donate -
Re: Dell E5570 - Bios / Clean ME ADM80 LA-C642P R1.0
Please, claer me ME RegionAttached FilesComment
Here's your Clean file, hope it works fine.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hello. The bios is flashed, but it turns on twice. Can you extract the bios from the site? File attachedAttached FilesComment
I don't understand what you mean but if you want a new file from the official one, here it is.
Your Service Tag in case you need it: 94WZ1G2Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
This bios working %100
For Dell E5570,ADM80 LA-C641P Rev 1.0 (A00)Comment
Bios request for dell e5570- starts up but black screen
Dell e5570.
m/b-ADM80 - LA C641P-REV 1.0 (A00)
S/No- CBPSNC2
The laptop starts up but nothing on screen, black screen.
cpu is getting warm.
Black screen on external thru vga,hdmi.
Lcd screen is tested working on another laptop.
I think this may be bios related issue.
Please can you help me sort this problem.
I have enclosed my faulty bios.
ThanksAttached FilesComment
Re: Bios request for dell e5570- starts up but black screen
Try the bios at post #2.Dell e5570.
S/No- CBPSNC2
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Try ...Dell e5570.
S/No- CBPSNC2
Hello.
I have a problem with Dell E5570 (La-C 641 PREV. 1.0(A00).
At the beginning laptop has no answer to power button.
Then I flashed W25Q128 with clear ME firmware from #2 post.
Laptop began start and work normally.
After installing Windows10 - LAN (I219-LM) can't installed, Wi-Fi device is no visible.
I tried to flash another firmware with clear ME, but nothing changed.
Could it be relate with incorrect firmware or it's a hardware problem?
Original dump is attached, please help to repair it, if it possible.
In addition. I got laptop without hard drive, Windows 10 was installed on new SSD.Attached FilesComment
Hello try this me clean file and let me know what happen ...Hello.
At the beginning laptop was no answer to power button.
Then I flashed W25Q128 with clear ME firmware from #2 post. Laptop began start and work normally. After installing Windows10 - LAN (I219-LM) can't installed, webcam and Wi-Fi device is no visible. I tried to flash another firmware with clear ME, but nothing changed.
If you want to edit or add something just use the edit button and do it, there's no need to make new posts one after the other!!!
Markus1741, Lan/Wi-Fi troubles are indeed indication of ME Firmware problems but usually when the bios is not working at all (no boot) bios region gets corrupted rather then the ME region (or at least more often) so the bios rgn must be repaired/replaced first (before the ME Firmware cleaning) to make sure the bios will be OK at the end.
.Last edited by Vesko356; 07-02-2023, 05:43 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
