Hello friends someone help me, I need bios and ec asus GL503V the owner says that I took it to Asus because I turned off the equipment in the middle of an automatic update of the bios since or knew what it was, when checking it I see that there is a chip that it is not the original one they put a bigger one where the ec goes, the query is can you use another chip different from the one that originally came? the equipment does not give an image they only turn on the keyboard lights nothing overheats attached images ...
PLEASE NEED BIOS AN EC ASUS GL503V MAIN dabklmb1aa0
Re: PLEASE NEED BIOS AN EC ASUS GL503V MAIN dabklmb1aa0
Hello Claudio, do you speak Spanish or English? this is the fileComment
Si hablo español, português e english.
This is your file repaired.
Try and report..
Este es tu archivo reparado.
intenta e informa..Comment
No funciona Claudio me parece que el problema esta en el chip ec ya que lo reemplazaron y colocaron otro chip winbond de otro tipo y voltage me parece que es ese el problema arriba puse imagenes... lamentablemente no tengo ningun chip de ese tipo (25q40ewnig) crees que sea ese el problema?Comment
Please write in english or otherwise you will be warned for that. This is an english forum. Use google translate if you need.No funciona Claudio me parece que el problema esta en el chip ec ya que lo reemplazaron y colocaron otro chip winbond de otro tipo y voltage me parece que es ese el problema arriba puse imagenes... lamentablemente no tengo ningun chip de ese tipo (25q40ewnig) crees que sea ese el problema?
The ec chip replaced are the same specs? It´s a new (blank) chip or used from other laptop?
This chip "25q40ewnig" maybe it´s a VGA bios (your laptop have a gtx1060).
EC chip is the ITE SIO
I attached the EC file for your laptop.Attached FilesLast edited by Claudiomfa; 04-14-2020, 03:30 PM.Comment
Ok, I understand I thought I could write you in Spanish, No it does not have the same specifications so I put the images so the team arrived, instead of arriving with the 25q40ewnig chip someone removed it and put a larger chip as I showed in the images. .. and I don't have a 25q40ewnig chip, I thought that the ec was that chip (25q40ewnig) but you tell me that it is the vga chip that gives meaning to the failure, but I don't have an identical chip to write this chip .. .Comment
This chip that you talking, they don't be the same as original. It can be larger or other manufacturer, but need to have same specs as original.Ok, I understand I thought I could write you in Spanish, No it does not have the same specifications so I put the images so the team arrived, instead of arriving with the 25q40ewnig chip someone removed it and put a larger chip as I showed in the images. .. and I don't have a 25q40ewnig chip, I thought that the ec was that chip (25q40ewnig) but you tell me that it is the vga chip that gives meaning to the failure, but I don't have an identical chip to write this chip .. .
Post backup from this chip if you can.Comment
Ok, Claudio thank you very much I appreciate your help, finally I ordered the chip on aliexpress here in my country I could not find it so I will wait for it to arrive, do you have the firmware of the graphics card that goes on this chip or do you know where to get it?Comment
I don´t have this firmware. If it's realy nvidia graphics bios, I think the only way is backup from another laptop. Perhaps anyone on this forum could have.Comment
Ok, friend, I already solved this problem, your repaired file works perfectly, finally I bought the vga bios chip on aliexpress, and I found the firmware of the NVidia GeForce GTX 1060 6GB, in another forum, I programmed it and finally it went on and it was ok, I will leave the file here in this thread, this file was from an asus GL703GE, and it worked on my GL503V. note this file is from the graphics card (GTX 1060 6GB)Attached FilesComment
TRY THIS, Clear me configuredAttached FilesComment
sorry, I forgot to put 0 in the middleAttached FilesComment
how you prgram that chip i got same modelwhen press power keyboard light comes on red then green then blus then off again press power same but my board doent have any bios for graphic i guessOk, friend, I already solved this problem, your repaired file works perfectly, finally I bought the vga bios chip on aliexpress, and I found the firmware of the NVidia GeForce GTX 1060 6GB, in another forum, I programmed it and finally it went on and it was ok, I will leave the file here in this thread, this file was from an asus GL703GE, and it worked on my GL503V. note this file is from the graphics card (GTX 1060 6GB)Comment
Hello, mine was a special case, someone had removed the original chip from the bios of the graphics card... you must reprogram the bios with a functional file, first you must identify the exact model of your motherboard and look for the file.Comment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
by lrouw84Hi there,
I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....-
- Loading...
