Lenovo T570 20JX
  • alfredodinolfo
    • 128
    • N/A
    Lenovo T570 20JX
    I need bios dump.
    Help me
  • peste
    • Dec 2016
    • 13451
    • ROMANIA
    Re: Lenovo T570 20JX
    put the bios backup here
    • alfredodinolfo
      • 128
      • N/A
      • peste
        • Dec 2016
        • 13451
        • ROMANIA
        try...
        • alfredodinolfo
          • 128
          • N/A
          try...
          thank you, i can't try because my MX25L12873F don't work now . i order new one
          • CraterM
            • Mar 2018
            • 180
            • Moldova
            How do you mean it doesn't work?
            • alfredodinolfo
              • 128
              • N/A
              not detect by programmer.
              • peste
                • Dec 2016
                • 13451
                • ROMANIA
                desolder the bios chip from the motherboard and clean the pin wells, read and write the bios with the chip removed from the motherboard.
                • aleksandaralex
                  • Jan 2016
                  • 10
                  • Serbia&Montenegro
                  Thinkpad T570 20jx bios need
                  I accidentally erased the spi-flash bios mix25l12873f by mistake, and I don't have a backup file,
                  does anyone know a safe way to get my t570 back from the dead?
                  Thanks in advance
                  tYPE: 20JX-S03E08
                  S/N: R9-0QDF15
                  • peste
                    • Dec 2016
                    • 13451
                    • ROMANIA
                    Re: Thinkpad T570 20jx bios need
                    Thanks in advance
                    tYPE: 20JX-S03E08
                    S/N: R9-0QDF15
                    try..
                    • aleksandaralex
                      • Jan 2016
                      • 10
                      • Serbia&Montenegro
                      Tnx,
                      now everything works fine!!!!!
                      • aleksandaralex
                        • Jan 2016
                        • 10
                        • Serbia&Montenegro
                        thanks a lot again
                        • Sami Wahid
                          • Oct 2015
                          • 77
                          • Morocco
                          Thank you my friend
                          • traveler_ua
                            • Jan 2021
                            • 17
                            • Netherlands
                            thanks
                            • ajbernasko
                              • Mar 2022
                              • 229
                              • ghana
                              Hi, I tried these files and gives me bad CRC of security setting in EFI variable, my old files does not support legacy or efi. i cannot install windows
                              • ajbernasko
                                • Mar 2022
                                • 229
                                • ghana
                                try...
                                try..
                                this is my dump
                                • hardware1
                                  • Sep 2021
                                  • 2946
                                  • N/A
                                  this is my dump
                                  Try this one and let me know the result.
                                  all donations are welcome,
                                  • ajbernasko
                                    • Mar 2022
                                    • 229
                                    • ghana
                                    I believe all the files were working so well, I was missing a bad F1 key on my keyboard
                                    • JustX
                                      • Feb 2019
                                      • 69
                                      • iran
                                      hello i have this laptop the bios ic is curropted cant back up
                                      T570
                                      type 20j-s03v00
                                      s/n : R9-0PGVRT
                                      • danito
                                        • Jun 2016
                                        • 1075
                                        • Romania
                                        T570
                                        type 20j-s03v00
                                        s/n : R9-0PGVRT
                                        post the original bios of the laptop even if it is corrupted
                                        • AHmad_Salal
                                          Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                          by AHmad_Salal
                                          Hello all,
                                          I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                          11-28-2023, 05:28 AM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • hyperwood
                                          [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                          by hyperwood
                                          I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                          The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                          I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                          āœ… What I need:
                                          • A working 2MB BIOS dump
                                          • Matching NM-E471 Rev. 2.0, e.g. JY575
                                          06-25-2025, 02:28 PM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Joluvillas
                                          Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                          by Joluvillas
                                          Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                          06-18-2024, 10:35 PM
