Lenovo T570 20JX
  • alfredodinolfo
    • 128
    • N/A
    Lenovo T570 20JX
    I need bios dump.
    Help me
  • peste
    • Dec 2016
    • 12254
    • ROMANIA
    Re: Lenovo T570 20JX
    put the bios backup here
    • alfredodinolfo
      • 128
      • N/A
      • peste
        • Dec 2016
        • 12254
        • ROMANIA
        try...
        • alfredodinolfo
          • 128
          • N/A
          try...
          thank you, i can't try because my MX25L12873F don't work now . i order new one
          • CraterM
            • Mar 2018
            • 174
            • Moldova
            How do you mean it doesn't work?
            • alfredodinolfo
              • 128
              • N/A
              not detect by programmer.
              • peste
                • Dec 2016
                • 12254
                • ROMANIA
                desolder the bios chip from the motherboard and clean the pin wells, read and write the bios with the chip removed from the motherboard.
                • aleksandaralex
                  • Jan 2016
                  • 10
                  • Serbia&Montenegro
                  Thinkpad T570 20jx bios need
                  I accidentally erased the spi-flash bios mix25l12873f by mistake, and I don't have a backup file,
                  does anyone know a safe way to get my t570 back from the dead?
                  Thanks in advance
                  tYPE: 20JX-S03E08
                  S/N: R9-0QDF15
                  • peste
                    • Dec 2016
                    • 12254
                    • ROMANIA
                    Re: Thinkpad T570 20jx bios need
                    Thanks in advance
                    tYPE: 20JX-S03E08
                    S/N: R9-0QDF15
                    try..
                    • aleksandaralex
                      • Jan 2016
                      • 10
                      • Serbia&Montenegro
                      Tnx,
                      now everything works fine!!!!!
                      • aleksandaralex
                        • Jan 2016
                        • 10
                        • Serbia&Montenegro
                        thanks a lot again
                        • Sami Wahid
                          • Oct 2015
                          • 77
                          • Morocco
                          Thank you my friend
                          • traveler_ua
                            • Jan 2021
                            • 17
                            • Netherlands
                            thanks
                            • ajbernasko
                              • Mar 2022
                              • 229
                              • ghana
                              Hi, I tried these files and gives me bad CRC of security setting in EFI variable, my old files does not support legacy or efi. i cannot install windows
                              • ajbernasko
                                • Mar 2022
                                • 229
                                • ghana
                                try...
                                try..
                                this is my dump
                                • hardware1
                                  • Sep 2021
                                  • 2896
                                  • N/A
                                  this is my dump
                                  Try this one and let me know the result.
                                  all donations are welcome,
                                  • ajbernasko
                                    • Mar 2022
                                    • 229
                                    • ghana
                                    I believe all the files were working so well, I was missing a bad F1 key on my keyboard
                                    • AHmad_Salal
                                      Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                      by AHmad_Salal
                                      Hello all,
                                      I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                      11-28-2023, 05:28 AM
                                    • Habble7
                                      by Habble7
                                      Suspected Cause:
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
                                    • Joluvillas
                                      Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                      by Joluvillas
                                      Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                      06-18-2024, 10:35 PM
                                    • Captaincrap420
                                      Lenovo Tiny8 triple NVMe IQ6X0IL1 HQ670 NM-D581 Rev 0.5 M90q Gen 3 / P360 Tiny prototype board BIOS dump
                                      by Captaincrap420
                                      Hi, I hope this is the right place to post this. This is my first post on this forum.
                                      A friend helped me get a prototype Lenovo motherboard from China, it's got a hole drilled in it but I'm working on trying to revive it to some degree. I dumped the bios in hopes that it might be useful to someone, since this board is configured with the 3rd NVMe SSD slot and maybe it is useful as a reference for modding another bios to support this function. For example the M90q Gen 2 / P350's unpopulated 3rd NVMe slot footprint maybe.
                                      This bios dump is straight from the chip, nothing has been...
                                      11-29-2024, 05:40 PM
                                    • mrkmpn
                                      Lenovo X1 Carbon 7th Gen Type 20R1 BIOS DUMP
                                      by mrkmpn
                                      SN: PF1Y5BBJ
                                      Board: GX490 NM-C661 Rev: 1.0
                                      I have made two dumps of this bios, with the bios chip removed from the board and the hashes match on both dumps, but I cannot find the DMI information in the dumps except for the Windows product key, so I think it is corrupted. I have downloaded two bios updates from the Lenovo support site, but they contain small .PAT file, and 4 subfolders containing .FL1 and .FL2 files, which I don't understand enough to figure out how to use to fix my dump.
                                      The problem with the laptop is that...
                                      05-21-2024, 09:14 AM
