Asus x202e stuck at asus logo
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need help on this can someone fix this dump it stuck on asus logo, can someone fix this please
  • peste
    • Dec 2016
    • 13430
    • ROMANIA
    Re: Asus x202e stuck at asus logo
    try...
    • String2016
      • Nov 2015
      • 2238
      • philippines
      Still the same, when i tried to reinstall os it stuck on windows logo not continues
        • 21679
        What part number do you have on the white/green stickers on the motherboard and on the base. X202E ,X202EP,X202EV
        • peste
          • Dec 2016
          • 13430
          • ROMANIA
          try that too
          https://drive.google.com/drive/folde...lh1R2hPSmphbUk
          • String2016
            • Nov 2015
            • 2238
            • philippines
            here it is
              • 21679
              Thats on the IO daughter board, i meant the ones on the motherboard.
              • String2016
                • Nov 2015
                • 2238
                • philippines
                ok here it is i pullout the board
                  • 21679
                  Is there a sticker on the RAM slot "What part number do you have on the white/green stickers on the motherboard and on the base."
                  Post a picture of the sticker on the RAM slot,if there is one, and the sticker on the Base cover with the serial
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    no sticker on the ram slot because its onboard, here is another info i took a pic
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      on the back cover
                        • 21679
                        Ok, so the white sticker at post #10 says X202EP and the serial matches the one in the bios,so it is the original bios,the bios by @peste didn`t work so you need to merge the asus X202EP bios update and copy the DMI info and win key .
                        • String2016
                          • Nov 2015
                          • 2238
                          • philippines
                          i cannot update because its stuck on the logo and windows logo
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            can you please upload a working one please
                            • Claudiomfa
                              • Nov 2015
                              • 455
                              • Portugal
                              x202ep repaired file with your info and win key.
                              try and report
                                • 21679
                                If the bios by claudiomfa doesn`t work try this one.
                                  • 21679
                                  Yes i know that, post #10 is there for others who are more willing to try and learn .
                                  • String2016
                                    • Nov 2015
                                    • 2238
                                    • philippines
                                    tried both still the same issue could it be cpu is the prob of this?
                                    • Bonzas
                                      • 472
                                      • Indonesia
                                      Have you checked this capasitor sir ?
                                      i've got a few days ago with same problem, first think bios or hdd problem. but after tried with another hdd & flash other bios problem not solved.
                                      i replaced 220 capasitor with 330, that solved my problem
                                      sorry for my english
                                      • String2016
                                        • Nov 2015
                                        • 2238
                                        • philippines
                                        @martha februarini thank you for the idea i will try to replace. did you replaced two capacitor to 330uf?
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • x_orange90_x
                                          Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                          by x_orange90_x
                                          I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                          12-28-2023, 06:26 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                          ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                                          This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                          09-07-2024, 02:50 AM
                                          ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
