Asus x202e stuck at asus logo
I need help on this can someone fix this dump it stuck on asus logo, can someone fix this pleaseTags: None -
Re: Asus x202e stuck at asus logo
try...Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs. -
Still the same, when i tried to reinstall os it stuck on windows logo not continuesComment
What part number do you have on the white/green stickers on the motherboard and on the base. X202E ,X202EP,X202EVComment
try that too
https://drive.google.com/drive/folde...lh1R2hPSmphbUkDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Thats on the IO daughter board, i meant the ones on the motherboard.Comment
Is there a sticker on the RAM slot "What part number do you have on the white/green stickers on the motherboard and on the base."
Post a picture of the sticker on the RAM slot,if there is one, and the sticker on the Base cover with the serialLast edited by SMDFlea; 03-22-2020, 08:12 AM.Comment
Ok, so the white sticker at post #10 says X202EP and the serial matches the one in the bios,so it is the original bios,the bios by @peste didn`t work so you need to merge the asus X202EP bios update and copy the DMI info and win key .Attached Filesif you find these attachements useful please consider making a small donation to the site
i cannot update because its stuck on the logo and windows logoComment
x202ep repaired file with your info and win key.
try and reportAttached Filesif you find these attachements useful please consider making a small donation to the site
If the bios by claudiomfa doesn`t work try this one.Attached Filesif you find these attachements useful please consider making a small donation to the site
tried both still the same issue could it be cpu is the prob of this?Comment
Have you checked this capasitor sir ?
i've got a few days ago with same problem, first think bios or hdd problem. but after tried with another hdd & flash other bios problem not solved.
i replaced 220 capasitor with 330, that solved my problem
sorry for my englishAttached Filesif you find these attachements useful please consider making a small donation to the site
@martha februarini thank you for the idea i will try to replace. did you replaced two capacitor to 330uf?Comment
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
Channel: BIOS Requests ONLY!
by conghuymsHey everyone,
I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned... -
by x_orange90_xI just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
- Loading...
