I have mac not boot on os only booting with windows can every body help me
macbook pro a1398
Tags: None
Re: macbook pro a1398
Try to clean ME region.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView -
BIos Clean meAttached Filesif you find these attachements useful please consider making a small donation to the site
Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?06-14-2023, 11:45 AM
by Ancient1Hi
I received such Laptop as junk. Opening it I saw a lot of whitish water residue , but no corrosion really ( few coils have small brown rust marks, no green copper ).
I cleaned all thoroughly and interestingly , its the Battery BMS board that has the real corrosion spots.. under the protective clear Goo !!
I want to try and power up the laptop
Battery is swollen. But I don't want to buy a new battery right now , of course .
I started work on the BMS by zooming in on green spots . 2 VIAs are filled with rusted copper goo - who knows...8 Photos04-17-2024, 12:46 AM -
by No LanHey everyone,
Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise
I've seen what this community can do, so I'm pretty sure you guys can help me out.
Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only... -
by twonk9098I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
This model has the newer trackpad which is not clickable when turned off.
At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but... -
by veedoHi All
I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
I found component UD290 ( SF0101-I2C) little... - Loading...
