MacBook Pro 2012 A1398 : Battery BMS circuit repair OR can it boot WITHOUT a battery ?
  • Ancient1
    • 275
    • Israel
    Hi
    I received such Laptop as junk. Opening it I saw a lot of whitish water residue , but no corrosion really ( few coils have small brown rust marks, no green copper ).
    I cleaned all thoroughly and interestingly , its the Battery BMS board that has the real corrosion spots.. under the protective clear Goo !!
    I want to try and power up the laptop
    Battery is swollen. But I don't want to buy a new battery right now , of course .
    I started work on the BMS by zooming in on green spots . 2 VIAs are filled with rusted copper goo - who knows if they still exist.. too small.
    2 resistors under the clear goo were actually disconnected : the pads and the resistors rot away mostly .
    Question : it looks like the SMD Resistors are a copper track stuck on top of ceramic box 🗃 - is that all it is ?
    They are 0402 I think , very small , Perhaps I can just use copper wire ?
    The IC in the photo is on the BMS circuit board, the ONLY damaged circuit ( and a few VIAs , status unknown ) , is Texas Instruments Battery Voltage Protection chips: BQ29410DCTR
    The example circuit , has only 100k ohm Resistors , so I conclude I need such two ?
    But , perhaps the Laptop can boot from a charger ONLY ? thus I don't need to mess with the Battery. I don't have Apple (compatible) Charger , only USB-C to MagSafe adapter ( I can ofc provide 19V directly , bypassing the USB-C V selection issue )
    What do you think ?
    P.S images taken at x25
  • trepachka
    iPad Air A1475 Boot loops after replacing battery
    by trepachka
    This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
    The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
    I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
    11-08-2024, 03:17 PM
  • code share
    Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
    by code share
    I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
    Here's what I've tried so far:
    • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
    • Booted successfully on AC power only with the battery disconnected
    • Visual inspection of the battery — no swelling, burn marks, or connector damage
    • Battery
    04-21-2025, 12:50 PM
  • piernov
    Laptop battery charging circuit
    by piernov
    1. Some theory
    1.1. Introduction
    Almost every laptop has a charging circuit of some sort, that does a few things:
    • Manages switching between AC adapter and battery power
    • Manages battery charging and generates power rail to charge battery
    There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
    • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
    • Narrow VDC (NVDC)
    Texas instrument has a nice overview of these technologies with some more details at https:...
    11-15-2020, 01:31 PM
  • Crrose
    How to test circuit board battery connection.RS-4i sequential stimulator
    by Crrose
    Not sure where to post this but I have an RS-4i sequential stimulator that runs off rechargeable batteries and also has a VL2330 coin cell battery that retains the memory. If that battery doesn't hold charge or connection is bad then the unit will power on and say to recharge. Once it is charged it indicates it is charged but when you turn unit on it powers off saying to charge batteries. I replaced that coin cell battery and now it won't even indicate batteries need to be charged. I have tested the battery pack and it is fully charged at 6V but the coin cell only shows 2.97V which is a brand...
    03-21-2023, 03:55 PM
  • techfreak9356
    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
    by techfreak9356
    09-14-2023, 11:10 PM
