mec 16xx dump with info block
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    Re: mec 16xx dump with info block
    But these programmers don't have MEC1663 in support list. Do you use MEC1633 setting instead?
    Anyway, tried writing again, then disconnecting power for a while. Still has password.
    • keczuk
      • 83
      • WWW
      In X390 i have same result. I try read / write was errored veryfi and different file. But when i extract EC from .exe and try again was upload succesfull and laptop working. Now i try same in T490 but still same errors with read chip (with error, i read X time and all file are simillar but different in HXD and when write chip i have same - error veryfii.
      I have resistor 10k in PIN 1, 2, 3, 4 , 6 ? Good ? in schematic yours i dont see resistor on pin 6?
      And the second question i take 3.3 V from this motherboard ? is good ? or i need supply 3.3 V from other source ??
      I put AC adapter to motherboard - is good ?? or i should use 3.3 from other sorce and should be enought?
      I have RT809H programmer also and is same result like in svode but in svod 1 times works on X390 lenovo.
      edit. i was find schematic for T490::
      So in this case i need only 1 resistor 10k for pin 6 ?? and put only there 3.3 V ?? i good understand ? ?
      • AAAC
        • Jan 2020
        • 458
        • Mexico
        @RethoricalCheese
        We edited the INI file holding the different MEC chips and added an entry for MEC1663 chip, with appropriate capacity (256kB).
        If using EC update extracted from Lenovo update, just delete first 32 bytes from update and it will match the file read from MEC1663 chip.
        @keczuk
        Question1: I have resistor 10k in PIN 1, 2, 3, 4 , 6 ? Good ? in schematic yours i dont see resistor on pin 6?
        Answer: Pin6 has a 49.9 Ohm resistor to +VCC3M.
        Question2: And the second question i take 3.3 V from this motherboard ? is good ? or i need supply 3.3 V from other source ??
        Answer2: Pin6 is connected to Vcc through a resistor, you can get +3.3 from this other point where the 49.9 resistor is connected to.
        For X390 you can program using keyboard connector, thorugh FPC cable.
        • keczuk
          • 83
          • WWW
          Originally posted by AAAC
          @RethoricalCheese
          @keczuk
          So now i still don't understand.
          - Now i use direct connection - i don't have resistor etc... programmer detect ID. I can read / write but all read / write are corrupt. When i read and compare i don't write all information or have different in many place.
          When the motherboard is connect to AC - on pin 6 i have 3.3 so i think i don't need take from board and other source next 3.3 to this PIN. (in this case) like on schematic ??
          I try 3-4 different type of cable and i have same result in SVODE 3 and RT809H programmer.
          • black0hackers
            • Jul 2020
            • 365
            How about this one? on thinkpad P1 9th
            how to device and read?
            • RethoricalCheese
              • Mar 2013
              • 1517
              • Estonia
              #26
              Got my problem solved. Used RT809H now instead of SAS JIG.
              Edit:
              Now, to write back data, it seems I need U1 tool. The old maintenance disk threw an error about locked eeprom.
              U1 update tool throws a "download error".
              Can anybody make and upload ISO of that tool?
              • keczuk
                • 83
                • WWW
                #27
                Edit:
                In my case now Write / read good. BUT He cut in upload my file in 192KB. I have choose 256 or 290 KB but always upload 192KB .... in svode and rt809h ..
                • AAAC
                  • Jan 2020
                  • 458
                  • Mexico
                  #28
                  @RethoricalCheese
                  This is probably the tool that you need to write data back, you will need a USB flash drive.
                  • RethoricalCheese
                    • Mar 2013
                    • 1517
                    • Estonia
                    #29
                    Thank you very much! This works perfectly.
                    • keczuk
                      • 83
                      • WWW
                      #30
                      @RethoricalCheese
                      Any solution of my problem ?
                      • JOHNLAG7
                        • Nov 2014
                        • 19
                        • Greece
                        #31
                        In my case with svod3 done read the t490 1663mec file and save it is 256kb ok then erase it and write an unlocked file after that i boot to bios and supervisor password gone all ok then i repeat the process and write back the original file that i save the first time and i can confirm t490 unlocked.
                        No PULL-UP resistors to JTAG signals needed or 3.3v power suply as pin 6 has 3.3v only connect direct to svod3 all 6 jtag pins.
                        PULL-UP Resitor must move to PULL-DOWN like attached photo and put back after every step.
                        • RethoricalCheese
                          • Mar 2013
                          • 1517
                          • Estonia
                          #32
                          I just moved reset signal resistor and used keyboard connector to do all the programming. Worked well.
                          • cgtec
                            • Feb 2014
                            • 54
                            • algeria
                            #33
                            i try read T490 with SVOD3 / MEC1663 / boot block not protected
                            how to unlock boot . MEC1663 . emergency ,mass erase is there any tool to unlock boot i cant read or wright .
                            • mek007
                              • Mar 2015
                              • 13
                              • Zambia
                              #34
                              I keep getting invalid serial number messages even after adding unit serial number and board serial numbers am I missing something... T490s thinkpad with a new board
                              • cgtec
                                • Feb 2014
                                • 54
                                • algeria
                                #35
                                Originally posted by superhansi
                                anyone can share a (256kb) MEC dump with info block? (containing SER#,CON#,USR#...) or share the SVP offset (e.g. for DXE mapped its 0x1F400)? With SVP would be great.
                                thanks
                                yes we have the ful dump eeprom for all thinkpad . and also mec1663 .
                                • spbios
                                  • Dec 2015
                                  • 16
                                  • morocco
                                  #36
                                  would u plz share dumps?
                                  • imranromi
                                    • Jan 2015
                                    • 1288
                                    • Pakistan
                                    #37
                                    If you have password then you dont need dump.Read chip save and program back and done.After need dmi add and complete.
                                    • spbios
                                      • Dec 2015
                                      • 16
                                      • morocco
                                      #38
                                      how it could be?, reading mec and rewrte back same dump and will be done!
                                      i cannot get your point
                                      plz
                                      can u explain better?
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1517
                                        • Estonia
                                        #39
                                        You can't read protected area. So if you read dump, you only will get unprotected area. But when you write, you also write on the protected area. This clears the protected area, thus clearing password, serial numbers etc.
                                        • -Yevhen-
                                          • Mar 2015
                                          • 14
                                          • Ukraine
                                          #40
                                          In my case it doesn't work. The T490s laptop, read MEC1663, saved the dump. Programed new MEC dump from update. When start, the laptop gives the opportunity to enter the BIOS, but with limited rights. SVP remains active! DMI data remains(serial, model...)
                                          What am i doing wrong?
                                          p.s. svod3 programmer
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • Andreas_de
                                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                            by Andreas_de
                                            Hello!
                                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                            04-12-2025, 10:38 AM
                                          • re-atari
                                            Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                                            by re-atari
                                            Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                                            Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                                            02-03-2025, 06:49 PM
